bearing maintenance
bearing maintenance
Just wondering what kind of lubricant etc you guys recommend for bearings. I believe mine are rubber sealed (whatever comes stock on the 1/10th 2wd slash). Also would you use the same type of lube for the vxl motor? Just wondering what to use and an easy place to find it.
Thanks in advance.
Thanks in advance.
I USE CORROSION X ITS THE BEST USE IT ON EVERYTHING NO PROBLEMS
http://www.corrosionx.com/marine.html
Just soak them in WD-40 for a couple mins then put a drop of 3-in-1 oil on them.
