LOSI TEN-T e
#1561
I went with an SC8 120A ESC and an EZRUN 4700kv motor, will I be OK running 14/40 on 2s or will I want to get some more pinions?
#1562
13 is probably a safer starting point, but you might be ok with 14.
#1563
Hi guys
I have a losi ten-t with HOBBYWING WP-SC8 120A ESC and 2800 kv motor : an hobbywing KD36-74-06XL 2800kv.
With this setup wich lipo is better to use and witch gearing can I choose ?
This motor is a good choice ?
#1565
i'd start out with a 3S battery and a 15T pinion.
i run my 2400kv 1415 castle motor on 3S and a 17T pinion. so a 15T should be a nice, safe starting point for you.
#1566
ok thanks for your answer. And with 2s lipo battery wich gearing can I take to use on race track ?
#1567
17 or 18 if it will fit.
#1568
18t fits, could probably go up to 20 before its too big.
#1569
I change the program. I have a losi ten-t with HOBBYWING+WP-*SC8+120A and want to run with 2s lipos. Wich motor is the better to run safely. I want to have a good autonomy with 5000 mah 2s lipo. If I can have 20 minuts of running, no hot motor, good acceleration I take it
#1570
I have a 10T roller, elite rc conversion with the LOSI motor mount and stock chassis, everything was rebuilt on the truck and used only 3 times since. I have the new elite chassis that goes with it but never used.
If interested I have all the parts to make it an SCTE and all of the Nitro parts. Shoot me a PM
#1571
BLACK FRIDAY & CYBER MONDAY SALE AT ELITE RC
*BLACK FRIDAY & CYBER MONDAY SALE* All In Stock Motor Mounts for $50ea
Sale Starts Nov, 23 12am - Ends Nov, 27 12am GET READY!!!!!
#1572
Hi
I have a Ten-t brushless with losi 8ight shocks.
This chassis is heavy for a 1/10 scale. The rear of the truck don't go up if I press the wing in example. I have the green spring on it but I want to try to change the rear shocks oil. Wich one can I put please ? 35,45, 55 ? I d'ont really know...............
#1573
Wat tires and wheels are on this fully decked out ten t
#1574
Are there any bodies which fit this ancient truck? As losi fan I just bought one to save it
#1575
The small exception is that the wheelbase on the Ten-MT is a little longer than on the Ten-T and so the body post holes on the Ten-MT body do not line up perfectly with the body mounts on a Ten-T.
The way to fix this is to take a second Ten-T front shock tower and cut off everything that doesn't touch the diff case. Then use that stub left over to space the front shock tower forward by the thickness of the cut-off shock tower. I used the original cheap black anodized aluminum Ten-T shock tower for this. I would not want to cut up a hard anodized aluminum or carbon fiber one for this purpose.
