Venom LIPO Fire
#16
The castle 2650kv motor is only rated for 4s lipo not 6s as stated above!
IMO the venom batterys are for the people that don't know any better and are just getting into the hobby just like the other venom products, nothing special.
I think you have learned from your mistake, when it comes to batt's get Thunder Power or Hyperion or Nue ect....ect.... If you look around at the track, the fastest guys there won't be running venom anything and now you know why!
Although CC says the 2650Kv is intended for 4S, it doesn't mean you can't run 6S. Correct gearing would certainly be key, as well as car weight, etc. They also recommend Elite batteries, and the minimum C ratings contradict themselve on the website and in their printed materials.
ben
#18
The Pres of Castle is somewhat of a regular poster on RCM and he's said more than once they do not recommend lipo brands. What you were told was the person you were talking to personal recommendation. Last post by Patrick on the subject said he would be pretty upset with any employee recommending a particular brand.
Elites are Chinese and if they're as good as their NiMh cells, there shouldn't be any probs with the lipo if you get a higher enough amp capacity to meet the motors demand and keep the stress off the esc.
There's a number of guys running turnigy and zippy lipos in Fluxes that post about excellent results with them also on RCM.
#19
2650KV is very fast for racing on 3S batteries. On 4S even faster.
3200mah 14.8v 4-Cell - at 30C, that is roughly 90A draw + 14.8v = about 1400watts. The 2650kv motor can peak out higher than that and you either overdrew the battery or it crushed the internal solder tabs causing a short.
Try running a 5000mAh 3S 30C lipo - they work well and with the right gearing, are fine for racing the 2650KV.
One issue with the technology is braking power - when on the brakes, the battery needs to take the impulse very fast - it's like extreme fast-charging the battery. If you hit the brakes hard a lot with the battery, it could also fry the ESC's electronics if the battery cannot take the charge fast enough. Castle president had a great thread on this in the forum on monster-rc.com a while back.
#20
under amp'ed
you were under amp'ed. you need to run no less than 120amps. "C" times mah=amp. If you were under 100 which you were at 96amps you cooked the battery. Yeah I would count on venom unless that all youcan afford and then gear accordingly. I run the same motor combo, but with a 13/46. No less than 25c and 5000 mah. I never had one issue or even a puffed pack yet, with three diff brands that I run. SMC, MaxAmp, MRC. Keep your packs to that or you can go lower in mah but you then need to go higher in "C' to like a 35-40C. Good luck
#21
Castle techs still say my battery specs were fine. This picture says differant
http://burnnitro.net:2429/DSC01372.JPG
#22
motor=good
esc=good
gearing=ok
batter= POS!!!
or you just got a bad battery, mabey it was out of ballance, or mabey its just a POS battery....
#23
glad i saw this thread, i too had a venom 5000 30c hard case lipo catch fire on me last night in my sc10 within 5 minutes of run time. using a novak havok and 17.5 motor with 28/75 gearing temps never over 130. 3rd time using this battery and poof. made sure my truck was good and threw in my check point battery the rest of the evening for practise and no problem. i always balance my lipos during charge too. waiting to hear back from venom about their pos lipo.
#24
i have been using Venom Lipos recently in racing conditions with ZERO problems. I have also used some of the cheapest most crappy lipos out there and have only had 1 go poof and that was my fault (starter box and letting it get way too low, swelled up and popped). I use them in 1/8 electric buggy, 1/8 nitro reciever packs, 1/8 nitro starter box, 1/10 sc10, 1/10 4wd buggy, and 1/10 touring. I have been balance charging my packs at 10amps also. I have had zero issues and they are always within a tenth of a volt per cell. People that have packs pop regardless of brand generally it is due to some other problem: binding somewhere causeing excessive load, packs not rated to handle the high current draws of big motor 1/8 systems, poor gearing choices, motors going bad, poor wiring connections, etc.
