RC8e motor problem
RC8e motor problem
I am having trouble getting the castle 2650kv motor to fit in the rc8. it rubs on the chassis hard when trying to slide it over to line up the gear mesh. anyone else have this problem?
Matt
http://67.199.85.166/main/productdet...ory=3020.rc8xx
this will help to rise your center diff mount!!
Put 1mm washers under the center diff and you won't have any problems. This is a known problem and this solution has not had any complaints. Make sure you use loc-tite when re-installing.
thanks for the help guys
