Old 04-03-2004, 06:01 PM   #1
tony montana's Avatar
Trader Rating: 64 (100%+)
Default novarossi p5 question
I have a novarossi p5 in my k3, the problem is after starting it once I get on the gas it idles pretty high and stays that way. I have tried all kinds of different things such as riching the low and high speeds didnt work, then I tried leaning them that didnt work. The temp is ok thou. Also I have tried adjusting the idle screw, and yes there is about 1mm in the slide at netural. If have been running odonnell 99 plugs as well as odonnell 30%. Think it could be a air leak some were? Also were can I get p5 instructions at online
K.C. Guy- Tekno rc - Lunsford Racing- FTM Grip
tony montana is offline   Reply With Quote
Old 04-03-2004, 07:57 PM   #2
speedydave's Avatar
Send a message via AIM to speedydave Send a message via Yahoo to speedydave
Is it erratic, or just high? If it's erratic, and the engine is difficult to tune, it's an air leak, otherwise it's a combo of tuning. FYI, richening the LSN lowers idle speed, leaning it raises idle speed.
speedydave is offline   Reply With Quote
Old 04-08-2004, 10:49 AM   #3
warpig's Avatar
did you seal your engine?
warpig is offline   Reply With Quote
Novarossi Carb question FG101C Nitro Off-Road 9 07-22-2008 11:39 PM
Novarossi .12 Question. TKCastle Nitro Off-Road 1 03-31-2008 03:00 PM
Novarossi Engine Question BRDRACING Nitro On-Road 4 08-13-2007 08:35 AM
Novarossi PLUS 12-3CT carb question schufflerbot Nitro On-Road 4 11-30-2006 07:00 AM
Question on Novarossi C12 jimbonj Nitro On-Road 3 09-28-2003 05:48 AM
SEO by vBSEO 3.5.0
