Like Tree1Likes
Old 02-11-2010, 07:30 AM   #16
Davidka's Avatar
Trader Rating: 75 (100%+)
Traction compounds all cause increased tire wear. Softer rubber almost always wears faster unless the traction compound makes the difference between wheelspin and no wheelspin (rare). If the sauce is causing the foam to wear out then it's likely because the softer tire is deforming more allowing the foam to take more of a beating. Unless you have vent holes in the tires (shouldn't in 1/10th indoor) it should not come in contact with the foam.
Old 02-11-2010, 08:06 AM   #17
raydog's Avatar
Trader Rating: 146 (100%+)
Thanks, Heavy. That's a great tip. Heck, I use it to clean my body : )
-Raydog
Team Associated - Reedy - Schelle Racing - Pro-line Racing - Upgrade-RC - Thunder Designs
www.StickyKicksRC.com - R/C Tire Conditioner and Traction Compound
raydog is offline   Reply With Quote
Old 02-11-2010, 07:21 PM   #18
raydog's Avatar
Chris and Mike, I shipped yours out today...
-Raydog
Old 02-12-2010, 04:51 AM   #19
It's too bad you guys only ship to the continental USA. I would have ordred some for sure... Oh well...
CODMAN
CODMAN is offline   Reply With Quote
Old 02-12-2010, 09:34 AM   #20
raydog's Avatar
Sorry my man.
-Raydog
Old 02-12-2010, 03:02 PM   #21
raydog's Avatar
Codman, if you can get a quote for Fed Ex shipping and want to order several we can discuss further. PM me.
-Raydog
Old 02-12-2010, 03:29 PM   #22
DANE_TRAIN's Avatar
Trader Rating: 20 (100%+)
You would be surprised if you actually knew what your talking about. Even though traction compound does not touch the foam directly, it does "absorb" through the tires or the "fumes" will soften and deteriorate open cell foams faster that normal. Next time you cut open tires that you have used traction compound on, smell the foam....eww
I don't know about Sticky Kicks personally, so I would go by what Raydog says.
Pro4mance Hobbies
DANE_TRAIN is offline   Reply With Quote
Old 02-14-2010, 08:54 AM   #23
raydog's Avatar
Thanks, Dane. Those that have actually ran the product will tell you about tire wear (or lack thereof)
-Raydog
Old 02-14-2010, 03:34 PM   #24
Ray, I'll PM you as I get a chance. Just a quick question while I'm at it. Obviously, traction compound is most efficient when you apply it every run. But if for some reason you can't, is there still some benefit after a few runs?
Just wondering. Where I race there is no rule against Traction compound, but it is indoors and wouldn't want to be fuming everybody with this stuff every round. I could probably make it outside to apply some every few runs though... Just wondering...
CODMAN
Old 02-14-2010, 08:47 PM   #25
raydog's Avatar
Right on. Sticky Kicks is the only sauce the owners allow us to use indoors at OC/RC Raceway.
Many will not believe it til they try it but it really is not fumey at all (is that even a word ). Try it, you'll like it.
-Raydog
Old 02-14-2010, 08:56 PM   #26
Ray Kindstrom's Avatar
Trader Rating: 147 (100%+)
I've found it's best to run it every round...and no it doesn't stink (not even a little bit)...not like some of the other stuff that smells so bad you apply it and run away. It's super easy to use. Twist the lid off insert old tooth brush and apply to tires.
Ray Kindstrom is offline   Reply With Quote
Old 02-14-2010, 09:08 PM   #27
wayboarder's Avatar
Trader Rating: 14 (100%+)
Ran sticky kicks Rojo tonightand got the most hooked up lap for me on the layout in modified SC aka Short bus, faster than last weeks by almost a full second! Thanks Ray
wayboarder is offline   Reply With Quote
Old 02-15-2010, 09:00 AM   #28
raydog's Avatar
Thanks Ray and Way(hookedup)Boarder
Yes, we run it every round. You will notice after using it for a couple race days that your tires are perma-tacky (yes, another new word)
The tires will actually stick together after washing them and stacking them (hence the name Sticky Kicks)
-Raydog
Old 02-16-2010, 04:02 PM   #29
Casper's Avatar
Trader Rating: 33 (100%+)
To answer a question from the last page. I have used belt dressing before. It worked AWESOME on those losi blue spec tires. I have heard of people having success with it on SPEC SC tires as well. I only used in on outdoor blue groove though.
Sticky Kicks is some pretty awesome stuff. Smells yummy but DON'T DRINK IT!
Apply it every run to clean tires and it will give you much better traction indoor. It is awesome for indoor clay surfaces for giving you an unfair advantage.
Ray has a great product here!
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 02-16-2010, 05:39 PM   #30
biggins's Avatar
i got my order of sticky kicks today i cant wait to try it this weekend i got all three which one should i use on losi pink slicks on clay?
Kyosho
Peak Racing
Vinly Graphics Unlimited
Team Tekin
BFastRC, Paint Monster Airbrushing
biggins is offline   Reply With Quote
Losi Pink compound + Traction additive? dr_speed Electric Off-Road 15 03-25-2010 03:21 PM
