Old 03-27-2004, 09:36 PM   #1
Default motor tuning, major problems, expert needed!?
("So it goes" slaughterhouse 9)
I have a 24.7 xtm motor
I torn down the entire engine to clean it out and then rebuilt it.
The problem:
after the motor was rebuilt I started it and got it to run ok, but the next day everything was terrible
The motor will start with the throttle half way open, but when you return the carburator to the idle position the motor will rev up to about 20,000 rpms. There wasn't even a 1mm gap on the carb barrel and it was acting like it was open 3/4 the way.
The setting are all factory 3 on top and 7.5 on the bottom.
Does anyone have any ideas what is going on.
Any kind of input will be greatly appreciated.
Another thing, it all started after i pulled the pull start of and began to use the starter box. Maybe I may have assembled the engine incorrectly?
Thanks in advance
dirt demon is offline   Reply With Quote
Old 03-27-2004, 10:25 PM   #2
It's hard to say you may have an air leak
check all ur bolt's are up tight
even try sealing ur engine with ultra copper
Looops is offline   Reply With Quote
XX4 expert advice needed Intotheblade Electric Off-Road 3 11-03-2007 01:57 PM
expert needed for model airplane adelyahya Other Items: For Sale/Trade or Wanted to Buy 0 05-21-2006 12:32 PM
Motor Tuning expert needed TAW Onroad Nitro Engine Zone 6 06-16-2004 12:34 AM
Major Servo/receiver Problems...help dirtbike Rookie Zone 2 12-25-2003 07:51 PM
Expert Stock Racers: Opinion Needed popsracer Electric On-Road 40 03-18-2003 07:48 PM
SEO by vBSEO 3.5.0
