**Venom Short Course Truck?!**
#46
#47
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 42 (100%+)
that could probally be fixed with a mod or 2 to the wheel hexes to get it within spec., so that's really no biggie having to trim 1mm per side.Heck you may even be able to do it by moving some axle shims around or something easy like that.
#49
Location: Norwood, OH...and CCRCR and The OhioRCFactory
ROAR is probably measuring the wheels. Venom is probably measuring the body.
#51
I believe that Venom would know the rules or wouldnt have said what they said.
For 2 months Kyosho's website had their new SC truck with the same specs as a RT5. This truck will be ROAR legal.
#54
doesnt it look like you could put the motor mount plate on the other side in the mid motor configuration,then run the motor the opposite direction,so that the torque of the motor wouldnt fight weight transfer? or am i one cog off? it might not let you run sensored motors that way,but at least the motor would be spinning the right direction.
#56
Is there a release date for this?
#57
Suspended
#58
Cool, thanks. I've seen it listed as low as $169.99 albeit Out Of Stock but still. I just may pre-order this vehicle.
