Old 01-20-2010, 07:21 PM   #1
Questions?? Losi Pink compound + Traction additive?
I have read that the Losi pink compound is chemically different than the others and seems to work best on a damp track, but takes well to traction additives.
Is this correct? Does this compound take well to traction additives? Soften the rubber up for running on a dry track?
dr_speed is offline   Reply With Quote
Old 01-20-2010, 07:34 PM   #2
Trader Rating: 23 (100%+)
on a dry track, the pink compounds last like two runs in mod. we fun dry and slightly dusty clay here and two runs and done with pink k bars. on softer tracks where its watered or holds water well, where you can easily all up dirt, or it's collected on the tire after a run, the pink compound last a very long time.
Mike Adamec
TEAM HACK-HACK OR BE HACKED
Trackside Hobbies
not home is offline   Reply With Quote
Old 01-20-2010, 07:53 PM   #3
Buggy grip 2 about 10min before the heat makes them last even less long But it does help
Jeremey is offline   Reply With Quote
Old 01-21-2010, 04:27 AM   #4
Jason_R's Avatar
Send a message via MSN to Jason_R
We run them a lot at an indoor track here (taper pins) in both damp and relatively dry conditions (nearly blue groove, light dust) and they adapt pretty well to both imho. Buggy Grip, Paragon, Red Dot, Reino's Ragu, you name it and we've tried doping them with it.
We'll commonly go through a couple sets of foams before we'll completely wear out the tire in 13.5. Personally, I prefer tapers on JConcepts or Trinity Bomb 1 foams, not the stock losi foam as it seems to break down pretty quickly with the additives.
RC America / XRAY / HUDY / KO PROPO / Advantage Racing Products
Jason_R is offline   Reply With Quote
Old 01-21-2010, 04:34 AM   #5
you're lucky, our clay gets a slight blue groove where two runs and done with any pink losi tire. and they do take traction compound very nicely, when we used to run slicks, i would drench mine in zip free, aka foam eater. they last very long too.
Mike Adamec
Trackside Hobbies
Old 01-26-2010, 03:37 PM   #6
Casper's Avatar
Trader Rating: 33 (100%+)
That must be some abrasive clay. The tires will not last as long with sauce but it should not kill them. It will attack the foam before it will usually wear out the tire. I recommend sticky kicks. Works great and smells great.
http://www.sticky-kicks.com/
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 01-26-2010, 06:50 PM   #7
Davidka's Avatar
Trader Rating: 75 (100%+)
It's not like that. I race at the same track, and haven't ever heard of tires wearing like that. Keep in mind, before this year the track was always one where we used Losi pinks ground to slicks. If the track is dry then tires wear a little but I've had the same set of tapers on truck for the last 6 races and haven't had much wear at all. The track is dry enough that people are complaining.
Old 01-26-2010, 07:14 PM   #8
kvrc's Avatar
Casper please give us some more info on this sticky kicks sauce. I went to the site and they have 3 different blends but they dont give any info as to what the differences are.
kvrc is offline   Reply With Quote
Old 01-26-2010, 07:25 PM   #9
i think it perfect now, and even better when we see a rebuild. tapers on my 2wd died in two runs
but losi tires are awesome, they just didnt last long here at my local track.
Mike Adamec
Trackside Hobbies
Old 01-26-2010, 07:53 PM   #10
Davidka's Avatar
Gotta learn to reign in that trigger finger Mike.
You racing next week when the new layout goes in? I assume yes.
Old 01-26-2010, 07:56 PM   #11
Jason Pelletier's Avatar
flame them grip them put them in a bag.
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
Old 01-26-2010, 08:02 PM   #12
I've read about this several times, not sure how to do it though.
How do you flame them?
Old 01-26-2010, 08:15 PM   #13
Yep, I have to say I did that before and I had holes in my tire, due to that
side of the tire hitting on the turns. That's what caused it. On slicks it would help, just not on full treaded ones. You will get holes in your tire because it's ripping itself. I use buggy grip on just pink taper slicks and that's it.
Associated B44 Novak brushless/Yokomo YR4 MII 4wd Dirt Oval Car
Tamiya 501x "Worlds Edition" Tekin Redline brushless
Traxxas Slash-Bone Stock, Losi XX-4 (85% completed project)
Elite/East Power/GP batteries/Futaba 3PM 2.4GHZ
electricguy007 is offline   Reply With Quote
Old 01-26-2010, 08:19 PM   #14
should be, maybe prac if the track is open wednesday. you?
i saw the losi guys doing it, take a hex driver or something similar, spin wheel on it fast and spray it in motor spray. then spin it again and light it and then blow off the flame.
Mike Adamec
Trackside Hobbies
Old 01-26-2010, 08:38 PM   #15
Casper's Avatar
I use the verde with good results. All three of the sauces are very close. He claims the verde is a little better on wet, the roja is better on drier tracks and the Blanco is kind of an inbetween. To be honest I have not tried them all but verde works great!
RC10B4/T4 Forum DerekL Electric Off-Road 14334 10-04-2017 09:29 AM
Losi BK2/MF2 thread DerekL Electric Off-Road 2850 07-18-2010 10:59 PM
