Like Tree23Likes
Old 08-06-2014, 09:00 PM   #14941
ekt
ekt's Avatar
Originally Posted by RBraswell View Post
anyone use the lunsford turnbuckles? any pro's /con's to using them?
The Lunsford's kit uses a different size ball stud/cup and has 3.5mm turnbuckles, if you want to call that a con. I used their 3mm turnbuckles on my old buggy, just buying the lengths closest to the kit turnbuckles, with no issues.
Originally Posted by Devin View Post
Question about the ball diff assembly from Durango on their blog right here: http://www.team-durango.com/blog/201...ild-guide-pt1/
They say to make it tight enough so that when you have two screw drivers in the gear slot, that you can barely spin them with your fingers.
Is that insane? Holding the two outdrives in my hands, I can't spin the diff.
I bought a used roller DEX in the past and it is nowhere near as tight. Looking for confirmation from anyone who has used this method.
Just to clarify. With drivers in the outdrive slots, you adjust the tightness so the gear doesn't spin under hand pressure, not so that you can't spin the outdrives.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 08-07-2014, 07:36 AM   #14942
Devin's Avatar
That is my question ekt.
I can still (with resistance) spin the diff gear with handpressure, but I cant spin the outdrives with my hands.
Devin is offline   Reply With Quote
Old 08-07-2014, 06:23 PM   #14943
ekt
ekt's Avatar
I would say to check your thrust washers, the smaller of the 2 should be closest to the diff screw head.
Leo Lorenzen
Old 08-09-2014, 06:21 AM   #14944
And so it begins again i broke a v2 rear tower on my v1 dex so do i call it a once off and buy another v2 tower or do i go for a carbon fibre or alloy tower?
thefan is offline   Reply With Quote
Old 08-09-2014, 11:33 AM   #14945
SteveM's Avatar
Trader Rating: 134 (100%+)
I have a DEX210 that I bought used from these forums that came with some nice bling upgrades. I've gone through the buggy nose to tail and replaced shock oil, checked all bearings, gear diff serviced, etc. and it seems to run fine. Only issue I have is that it makes a squeal at times, mostly when in the air off jumps or sometimes making fast turns after a long straight into a sweeper. I've checked everything twice but can't find the source of the squeal. I've even replaced the slipper pads. Any ideas on what to look for?
SteveM is online now   Reply With Quote
Old 08-09-2014, 12:38 PM   #14946
rcjunky1's Avatar
You have the gear diff in it? I can take a look Wednesday if you're at the track, otherwise I can't think of what it could be. Had you cranked down the slipper to see if that solves it?
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 08-09-2014, 12:59 PM   #14947
SteveM's Avatar
Yes, gear diff in the tranny. I had Bill take a look and I believe be backed-off the slipper a bit. Still squeaks :-(
Old 08-09-2014, 05:55 PM   #14948
fq06's Avatar
Usually a squeak or squeal is a bearing. Can you get it to do it on a car stand so you can narrow down where it's coming from?
BCE SCT410 / Hobbywing 3656sd ~ RX8.2
DEX210 / Trinity 17.5 ~ RS.2
Westcoast Raceway (R.I.P.) | SMC | PowerLab
fq06 is offline   Reply With Quote
Old 08-09-2014, 06:13 PM   #14949
Lone Star's Avatar
Anyone try to use a captured kingpin on the rear outer like a 22? I broke a pin and have split 2 rear arms so far. Just think that a captured system wouldnt let the arm split.
Lone Star is offline   Reply With Quote
Old 08-10-2014, 04:15 AM   #14950
So here is the broken V2 rear tower, i was considering the Revolution Designs aluminium tower as a replacement, or carbon fibre the decision will come down to whether i want the tower to bend or snap. Feed back would be appreciated, by the way the buggy is a V1 i only tried the V2 tower after breaking 2 V1 towers.
Old 08-10-2014, 04:35 AM   #14951
Lone Star's Avatar
Had the same problem on my B4. Ran it until it was obvious. It turned out to be the front end bell bearing on my Vulcan. Changed the bell, silent.
Old 08-10-2014, 05:18 AM   #14952
RC10Nick's Avatar
I've been running the same CF tower for over 1.5 years now. I wouldn't think it matters much which one you get.
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 08-10-2014, 07:33 AM   #14953
ASH93A's Avatar
Had the exact same issue with mine, it ended up being the spur gear cover was broken at one of the screw points and occasionally rubbing on the pinion / spur gear!!
ASH93A is offline   Reply With Quote
Old 08-12-2014, 08:12 AM   #14954
Get a lowered carbon rear tower, Diggity Designs makes a -4mm in the v1 style. The v2 is lower then the v1 but with different shock locations. Put 1mm spacers on the back of a carbor tower to space it away from the transmission case.
Remember you will need the correct rear shock shafts for it, 52mm, the stockers in a v1 are too long. too long even for a v1 tower.
If you run either a dimec or v2 chassis you most likely will need some limiting in the rear shocks or the long outdrives. the newer chassis have a bevel that allows more droop and you probably will throw the bones from the outdrives if you don't do one or the other. I learned this the hard way.
ooberman is offline   Reply With Quote
Old 08-12-2014, 12:25 PM   #14955
Tunatsol's Avatar
The squeal could be from the tire rubbing the wing.
Josh Youngs
Team Durango: DNX8, Dex8, 408, 210, 410v3,
Sponsored By: Dialed Hobbies
Tunatsol is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
