Like Tree24Likes
Old 07-21-2014, 03:02 AM   #14896
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
Originally Posted by thefan View Post
Anybody experience the driveshaft popping out of the balldiff outdrives after a bad landing, its getting very annoying the driveshafts should be longer, damn you durango
Make sure you have these (long diff outdrives) not the stock short ones.
http://www.team-durango.com/part-inf...artNo=TD310417
Fishhook
ewashburnaf is offline   Reply With Quote
Old 07-21-2014, 05:30 AM   #14897
Pittster's Avatar
I have had a V1 for over 8 months and always ran full droop and never had a shaft pop but I have since ugraded everything to a v2 and went to the -2 LRC RR Block and had it pop out twice.
After getting the above part I ran a full race day with some large incidents and no drive shaft pop out issues
Team Associated B6D, Speed Passion Reventon Pro 1.0, Hobbywing V10 7.5t
Team Associated B64D, Speed Passion Reventon Pro 1.1, Hobbywing V10 G2 6.5t
Team Associated B5M CE, Tekin Rs Gen2, Fleta ZX 17.5t
Pittster is offline   Reply With Quote
Old 07-21-2014, 01:56 PM   #14898
Pittster's Avatar
First front tower failure I have ever had and it was with the v2 tower 3 races old.
To its credit I didn't notice till I got home and it didn't really lose any stiffness.
Old 07-21-2014, 03:37 PM   #14899
rcjunky1's Avatar
well done
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 07-21-2014, 04:54 PM   #14900
Originally Posted by ekt View Post
A drop of thread lock holds them in position for me.
I tried that once and yes it holds them in but i couldnt get it out again lol i broke a 1.5mm driver trying to get it out, i didnt use a lot of thread lock i used a driver to put it on instead of straight out of the bottle
Team Durango - DNX8 - DEX8 - DEX410v4 - DEX210v2 - Alpha Lutz WE - VP PRO - Futaba - Hudy - Orion
av4625 is offline   Reply With Quote
Old 07-21-2014, 09:30 PM   #14901
rcjunky1's Avatar
if it doesn't slide out nicely, heat it up with a soldering iron. That also sounds like a reason to get some quality MIP tools as well
Team Durango Canada
Old 07-22-2014, 04:33 PM   #14902
haha i think it was a hudy driver that i broke i really had to hammer it out lol
Old 07-23-2014, 07:34 AM   #14903
without reading 1000 pages~
I just got a kit ver. RTR with a HobbyWing 80esc and a Castle 5700kV motor, receiver and cheap servo in a trade for an RX8 with a Tenshock motor.
I'd been eyeing up the B5 for a while... but this seemed like a good idea.
Is there ANYONE who makes 12mm hex hubs for this thing? If not.... is anyone interested in it? (PM me if you are, I'll post pics and a FS thread.)
Thanks,
Ben
erevo1*16 is offline   Reply With Quote
Old 07-23-2014, 07:56 AM   #14904
Trader Rating: 47 (100%+)
Nobody makes actual 12mm hexs specifically for the durango cars.... BUT, some simply use 12mm AE rear hexs and pins (direct fit with no modification needed), and then either b5 or kyosho front hexes + spacers, combined with a steering hub from a durango desc210 or dest210. :edit: With this setup your stuck at 3mm trailing, which is where most run anyway
porter is offline   Reply With Quote
Old 07-23-2014, 08:34 AM   #14905
Thanks for the info!
I think I'll keep this thing and mess around with it for a while.
A buddy of mine offered the trade, so I took him up on the offer.
I've never had a 2wd buggy; it seems that there are plenty of guys who like the kit. I was kind of thinking about getting a b5 anyway.
(the reason I was asking about the 12mm hubs is because I have a D413, and a few sets of rear wheels/tires for that that I'd like to swap out rather than buy new wheels and tires if I'm not going to keep the kit~)
Old 07-23-2014, 09:39 AM   #14906
T-BirdJunkie's Avatar
Location: Norwood, OH...and CCRCR and The OhioRCFactory
Send a message via AIM to T-BirdJunkie Send a message via MSN to T-BirdJunkie
Thanks,
Ben
B4/B44 rear hexes, NOT B5 rear hexes, since the Durango has 3/16" axles; just to make sure you know. The B5 hexes won't fit.
If you don't allow yourself to make mistakes, you'll never allow yourself to succeed
T-BirdJunkie is offline   Reply With Quote
Old 07-23-2014, 10:26 AM   #14907
Lol. There's a good bit of info.
Thank you!
Old 07-23-2014, 12:41 PM   #14908
Glad I could help!
Fishhook
Old 07-23-2014, 04:45 PM   #14909
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
If anyone needs a BB spring set fr/rr I have one in f/s along with other stuff I found cheap/
kwiksi is online now   Reply With Quote
Old 07-26-2014, 01:20 PM   #14910
Dray01's Avatar
Hi Guys,
Looking for a little advice.
I have built up a new v2 and have the gearbox in mm4 config.
The gearbox however has a pretty nasty tight spot in it.
I tried changing the shimming, flipping all the gears every which way but to no avail.
If anyone has any tips on things i can check or do it would be great.
Cheers
Dray01 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
