Like Tree23Likes
Old 06-26-2014, 06:09 PM   #14761
I'm really stuck now because in changing out the gear box (TD310459) I realize that the sway bar mount is higher then the stock gear box. Now the brace (TD320121-1) isn't able to work because it too has sway bar mount when before the original gear box fit under the brace. Do I have the wrong gear box?
daveb is offline   Reply With Quote
Old 06-26-2014, 06:13 PM   #14762
Trader Rating: 137 (100%+)
Originally Posted by Marco926 View Post
sorry for confuse…i'm meaning the rod end pull out from shock shaft
I bought a couple of sets of the older
Ball cups and used those ball
Ends on my shocks and none have failed yet. Also do not over tighten. The new turnbuckle plastic is much more susceptible
To stripping out. I thread until one thread is still
Showing.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 06-26-2014, 07:20 PM   #14763
Originally Posted by daveb View Post
After driving for over a year, my son finally broke a gear box. After ordering the Type B box and tearing it down I noticed my sons chassis is slightly bent in the back. With all the braces should I worry about this much? I'm thinking with the brace that holds the rear body mount will pull it back into shape. I don't want to spend much more money for a new one since converting to a V2 is not reasonable in price. My son is getting better and should be running stock 17.5 soon and having to buy a chassis is dumb but if I did have to which one? RTR +8, aftermarket aluminum or V2
i had a similar thing happen to the front of mine i just bent it back straight it drove badly when bent but is fine now after fixing it, use pliers or multi grips or similar tools
thefan is offline   Reply With Quote
Old 06-26-2014, 09:20 PM   #14764
ekt
ekt's Avatar
To use the type B gear box in RM you need the type B rear brace TD320270 and top deck TD320269 otherwise you want the old gear box TD310257.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 06-26-2014, 10:52 PM   #14765
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
can some of the peeps using the dex410 high wing mount mod please post some pics? I wanna see how it came out. I bought some extra mounts so I can try it. I'm also using the lowered tresrey CF rear shock tower...I'll post pics when I'm done as well
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 06-26-2014, 10:59 PM   #14766
Oasis's Avatar
Trader Rating: 36 (100%+)
I'm running the revolution +11 and I like it..handles very well..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 06-27-2014, 07:35 AM   #14767
303slowdown's Avatar
Trader Rating: 21 (100%+)
+1
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 06-27-2014, 08:53 AM   #14768
13Maschine's Avatar
I'm also running the +11 from RDRP. Seems much more stable than the previous shorter chassis.
Old 06-27-2014, 11:12 AM   #14769
Not really you can just cut the plastic on the brace out around the gearbox, works fine but you cant go back to the old gearbox is all
Old 06-27-2014, 11:15 AM   #14770
What is the weight compaired to stock? Once Surf City is over I will be moving to Mog Buggy and Mod SC. Need to put all the weight back in I took out when I built my all plastic car lol... Its at 1498 right now body and electronics. Plan on putting the 15gram weight under the servo to keep the nose down.
Old 06-27-2014, 11:18 AM   #14771
Sent you a PM on setup help for our tracks.
Old 06-27-2014, 11:22 AM   #14772
+1
Old 06-27-2014, 01:13 PM   #14773
Trader Rating: 110 (100%+)
Anyone running 12mm hexes? Which ones did you use and did you have to shim between them and the bearing to keep it from falling out?
*MIP/SCTE*
+FTM GRIP+
socal23 is offline   Reply With Quote
Old 06-27-2014, 01:26 PM   #14774
Trader Rating: 14 (100%+)
I am also curious to know which 12mm hex is the better system.
RBraswell is offline   Reply With Quote
Old 06-27-2014, 03:26 PM   #14775
Lone Star's Avatar
Proline for the b4. Just use regular ae roll pin and install just as on a b4. Fits fine, no shims.
DEX210V2, Toxic Tops Shuttle body for DEX210v2, lightened 7075-t6 3mm chassis.
Lone Star is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16562 Yesterday 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Speed Chaser
