Like Tree23Likes
Old 06-21-2014, 07:17 PM   #14731
Azagar's Avatar
Originally Posted by socal23 View Post
I tried the rear alum axles and wow was there a big weight difference, then about 2 packs in one side snapped in 2 right behind the hex .
Run the stock plastic hexes, will help in preventing the axles from breaking. I stopped using them after I noticed they bent really easily too but that's to be expected. I wish they would release aluminum driveshafts instead, maybe if we are lucky MIP will also give us the puck system.
Anyone purchase the recently released TD RF hanger yet? Saw it on tower but not much information is given about it. Here's the part# TD330565
Team Durango DEX210
Avid | AKA | Exotek | Jconcepts | KO Propo | Lunsford | Tekin | Turnigy Nano-tech
Azagar is offline   Reply With Quote
Old 06-22-2014, 07:04 PM   #14732
Devin's Avatar
Recurring problem:
Anyone have a problem keeping the front top deck spacer (Part # 320123-2) screwed into their car? My left one keeps popping out. Is there a trick to it? None of the other Durango owners have had any problem with this.
I am wondering if the problem could be a stripped screw hole on the side of the servo side-wall thingy (I think it is part # 320124-1) that it screw into.
It's a plastic on plastic situation so I am afraid to use threadlock.
Devin is offline   Reply With Quote
Old 06-22-2014, 07:22 PM   #14733
303slowdown's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Devin View Post
Recurring problem:
I've had the same problem so I put a little longer screw with the smallest amount of locktite and havnt had an issue since.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 06-22-2014, 07:30 PM   #14734
Devin's Avatar
It calls for a 10mm screw, I'll try with a 12mm and a small dab of locktite and see how that works.
Thanks.
Old 06-22-2014, 07:43 PM   #14735
Pittster's Avatar
Just a note for anyone that has upgraded to LRC -2 block on there V1.
I had a driveshaft pop out twice racing yesterday and it seems the 210V2 runs the newer slight longer out drives to stop issues of Driveshafts popping at with Max droop in the rear.
TD310417
Also ran MM4 on a loose wet dirt track with 50g of weight on the rear and it handled awesome as grip came up it got better.
Certainly changed my opinion on RM vs MM, it definitely had less rear grip vs RM but the extra steer and the more balance in the car give me higher corner speeds and easier change of direction, I was also running the shock's front mounted.
Fastest laps were set by MM and RM setups.
Team Associated B6D, Speed Passion Reventon Pro 1.0, Hobbywing V10 7.5t
Team Associated B64D, Speed Passion Reventon Pro 1.1, Hobbywing V10 G2 6.5t
Team Associated B5M CE, Tekin Rs Gen2, Fleta ZX 17.5t
Pittster is offline   Reply With Quote
Old 06-22-2014, 11:12 PM   #14736
just tried the 210 v2…it's perfectly stable
but the rear shock bottom eyelet comes off easily even i set the downstop screw already,
anyone have the same problem ? any solution ?
Marco926 is offline   Reply With Quote
Old 06-22-2014, 11:37 PM   #14737
re-do73's Avatar
Anyone interested in a carbon fiber motor plate? Trying to shed a bit more weight. They weigh in at 12g, stocker is 22g. Almost half the weight. I have 10 that will be ready monday!
re-do73 is offline   Reply With Quote
Old 06-22-2014, 11:38 PM   #14738
re-do73's Avatar
Another pic
Old 06-23-2014, 01:34 AM   #14739
I know carbon fibre is strong but im a little concerned it would snap around the motor screw slots as it gets thin there
thefan is offline   Reply With Quote
Old 06-23-2014, 04:14 AM   #14740
Lone Star's Avatar
Yep. Either c/a glue it back on or get traxxas ones. The part number is a few pages back. Ive been running the traxxas ones for weeks with no problems.
Lone Star is offline   Reply With Quote
Old 06-23-2014, 05:03 AM   #14741
Thanks.
The V2 Manual calls M3x12mm.
If your Plastic is stripped out, may u can use one of these thread-inserts!?
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 06-23-2014, 05:22 AM   #14742
Devin's Avatar
Good to know about the updated length in the manual.
What are those inserts and how do they work? I tried googling them but I just get forum threads talking about various DEX inserts.
Old 06-23-2014, 05:42 AM   #14743
Sorry, but i don't know the exact word in english!?
I bought those inserts in an metal/hardwear store.
As an example, for a m3 thread, you have to drill a m5 thread in your plastic part and than screw that insert into that part, the inner diameter thread of the insert is than again m3.
I hope i could describe it correct, as my english is not the best!
Here is a link to a shop in austria, may this can help a bit more?
http://shop.kvt-fastening.at/katalog...ewindeeinsätze
Ps.: description edit
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 06-23-2014, 09:01 AM   #14744
Azagar's Avatar
Are you referring to the shock end popping out of the tiny bushing that holds it to the arm? If you are just add a 1mm washer in between the screw and the shock end to keep it from ever poping out.
Old 06-23-2014, 10:18 AM   #14745
GregerL's Avatar
Recurring problem:
Anyone have a problem keeping the front top deck spacer (Part # 320123-2) screwed into their car? My left one keeps popping out. Is there a trick to it? None of the other Durango owners have had any problem with .......
Most times it is possible to use an even longer screw and fit a nut on the inside, I've done this on several 210 buggies.
GregerL is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
CARD
