Like Tree32Likes
Old 06-11-2014, 06:06 PM   #14686
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
@Jcopeland: I hear you on after layout changes slickness. Wowsa!
usually I get 2x3 days of practice out of a set of Typos at OCRC. I run a 5.5 in my 410 and a 6.5 in my 210. I think I'm much easier on the throttle than most are though. Feather fingers!
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 06-11-2014, 06:08 PM   #14687
13Maschine's Avatar
Since my local shop stopped carrying Durango parts (not that they ever had a good selection) I've put a lot of time and effort into looking at DIY and CNC and 3D printers. I've always dreamed of designing my own car and I had designed several parts in high school when I was learning Autocad for the first time. (1996!!) All that being said has led me to create this forum in which I would like to invite all the Durango kids
Team Durango Open Source Parts :D
Old 06-11-2014, 07:20 PM   #14688
Originally Posted by CaseyDDR View Post
I hate you
Run the v2 for the first time at a carpet track that i would call medium grip, ohh myy the v2 has soooo much rear grip, my v1 rotated really well and the steering was twitchy! this car, the rear was just stuck and the steering wasnt as good :/ i made a lot of changes which helped but i would still like more although the rear was a little light on oil i feel.
Does anyone think that there isnt as much lock on the v2 or am i doing something wrong? I have all the linkages set up and the transmitter!
Team Durango - DNX8 - DEX8 - DEX410v4 - DEX210v2 - Alpha Lutz WE - VP PRO - Futaba - Hudy - Orion
av4625 is offline   Reply With Quote
Old 06-11-2014, 07:42 PM   #14689
ekt
ekt's Avatar
The c-hubs were updated a while back to prevent excess steering throw that could lock up the steering assembly. It's probably a case of your v1 having the old style c-hubs. Pic showing the differences between the hubs.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 06-11-2014, 09:14 PM   #14690
Trader Rating: 138 (100%+)
That's why I only go to OC/RC for big races. Track thrashes cars and tires. LRH is a great little track to experiment with setups on. Usually needs very little to no setup changes to translate to OC/RC very well. and a set of typos last forever there. For the DEX210 I plan on running dirt web fronts with bar code rears, and a full set of dirt webs on the DEX410V4. I like my 4 wheel drive cars to have super aggressive steering.
TLR 22T 3.0, 2X Yokomo YZ-2 DTM, B64D (Temporary 4 wheel) YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 06-11-2014, 09:27 PM   #14691
Lone Star's Avatar
I am also looking for more steering on my v2. I run rm4 on outdoor loose,dusty clay. Tazers or bowties are the tires. Power on is ok, juat need more initial turn in without getting on the brakes much if at all. Rear is locked just need steering.
DEX210V2, Toxic Tops Shuttle body for DEX210v2, lightened 7075-t6 3mm chassis.
Lone Star is offline   Reply With Quote
Old 06-11-2014, 10:56 PM   #14692
Trader Rating: 110 (100%+)
Anyone know the weight difference between the new v2 chassis vs the dimec and dimec20? Plan tinrun indoor clay small track blinky 17.5 mm shorty pack inline electronics.
*MIP/SCTE*
+FTM GRIP+
socal23 is offline   Reply With Quote
Old 06-11-2014, 11:37 PM   #14693
Do not know by actual weight but the dimec20 chassis is noticeably lighter when I switched over.
Old 06-12-2014, 12:37 AM   #14694
Pittster's Avatar
Just changed from the v1 alloy chassis (182g)to the dimec20 8mm+ type b (149g)
And from v1 kit 210 RM to v2 210 MM with dimec20 type b was 1650g to 1587g
Team Associated B6D, Speed Passion Reventon Pro 1.0, Hobbywing V10 7.5t
Team Associated B64D, Speed Passion Reventon Pro 1.1, Hobbywing V10 G2 6.5t
Team Associated B5M CE, Tekin Rs Gen2, Fleta ZX 17.5t
Pittster is offline   Reply With Quote
Old 06-12-2014, 08:57 AM   #14695
I see your using the angle ball for the bump steer link as well. That would help for it not locking up as well.
chet is offline   Reply With Quote
Old 06-12-2014, 09:38 AM   #14696
rcjunky1's Avatar
I think thats DESC vs DEX
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 06-12-2014, 10:18 AM   #14697
Azagar's Avatar
To those that have switched to the dimec20 chassis, just switched myself, did you notice a loss of droop for the rear if using the LRC hangers? When I tried the 1.5 LRC the rear arms would stop on the chassis. I had to switch to the HRC 0 RF hanger in order to gain some of it back. Right now I have 0 HRC RF combined with the LRC RR which makes 3 degrees of anti squat correct?
Team Durango DEX210
Avid | AKA | Exotek | Jconcepts | KO Propo | Lunsford | Tekin | Turnigy Nano-tech
Azagar is offline   Reply With Quote
Old 06-12-2014, 10:30 AM   #14698
That would be a noticeable difference. Also running 14 gauge motor and battery wires saves more then you would think and helps in lightening the car.
Old 06-12-2014, 10:57 AM   #14699
Azagar's Avatar
You should be able to free some more weight too somehow. My MM weighs in at 1560, and that's with about 20g of 13g wire that I used because I wanted my esc down the center. Regular 200g shorty, stock wheels, v1 +8 body. Oh nevermind its the RS that's saving me a lot of weight, that's about 20g less then most esc.
Team Durango DEX210
Old 06-12-2014, 11:34 AM   #14700
Dino_D's Avatar
You can try running less trailing. Use the 3mm or 2mm insert, and shim according. That will make the steering more aggressive. It you still need more, you can try using a shorter front upper link by moving the camber link holes closer.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
