Like Tree24Likes
Old 05-30-2014, 09:55 AM   #14596
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
What do you use to measure droop on your rides? Do you also use a setup system like the Hudy or Integy? Setup board?
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 05-30-2014, 10:06 AM   #14597
Dino_D's Avatar
Droop is how much the suspension can lift from ride height. Lets say max droop is 30mm, running 22mm ride height give you 8mm of droop.
If you raise the ride height to 24mm, you get 6mm of droop.
Normally I like to run between 20mm for smooth tracks and 22mm for bumpy tracks. You can go higher if necessary. Ride height will alter droop. So if you lower your height you should adjust accordingly.
Front droop controls how much steering you have. Reducing droop give you more steering as it reacts quicker to change, while giving more droop makes the car easier to drive, slower it initiate a turn and pushes on corners exit . Also more front droop gives you more traction on acceleration, more weight transfer to the rear, hence why it pushes.
Rear droop. The more rear droop, the more steering you have into corners, so if you start wiping out under braking or entry, you might have too much weight transfer to the front. You need more droop on bumpy tracks, and less on smooth tracks.
Most of the drivers in off-road just measure the length of the shock or distance between the 2 shock mounting points.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 05-30-2014, 11:09 AM   #14598
Waflet's Avatar
Trader Rating: 30 (100%+)
Hideeho
While I agree with everything you said, I think there is an easier way to explain it. Droop defines the amount of weight, & therefore traction, that can be transferred from 1 end or side to the other. The end that extends transfers traction to the end that compresses. During acceleration the front comes up & the back goes down, leading to push. During deceleration the front goes down & the back goes up leading to oversteer or loose.
Reducing droop at 1 end allows less traction to be transferred to the other end. Reducing front droop means you will have less traction available for acceleration but more available for steering during acceleration. Whether this is good or bad depends on the rest of your setup & your driving style.
This can also be applied during cornering. In a left turn the right goes down & the left comes up. If this is excessive it can lead to traction rolling.
"Just leave me alone, I know what I'm doing."-Kimi Raikkonen
Mugen MBX7R Eco/Tekin RX8g2/Savox 2274/SMC 1900kv/Aitronics mt-4/promatch
Mugen MSC7(1/10 pro4 sct)/Tekin RX8g2/Savox 2274/Tekin Pro4HD 4300kv/Airtronics mt-4/SMC
Waflet is offline   Reply With Quote
Old 05-30-2014, 03:57 PM   #14599
13Maschine's Avatar
Awesome explanations guys. I ask about measuring tools since we have droop screws, I think when using these screws to adjust it's important to make sure it's accurate left to right. Otherwise the chassis will have a bit of "tweak" and that's why I wonder if anyone is using a tool to measure the droop.
Old 05-30-2014, 03:59 PM   #14600
13Maschine's Avatar
Still curious about setup boards too, I've found it hard to get a setting of front toe, camber and all that can be hard to do even with setup wheels. I like setup wheels because I can roll the car and see how straight it is and it's a little more "real world" but setting toe in with setup wheels is difficult.
Old 05-30-2014, 05:08 PM   #14601
Waflet's Avatar
Hideeho
There are 3 ways I know to set your toe without a setup station.
1. By eye, which has obvious draw backs.
2. Hold your car vertically, nose down, & measure the negative camber. This will be your toe out. My problem with this is it is not repeatable because you are holding the car it will be at a slightly different angle every time. Also because you are holding the car the amount of weight being supported by your hand will affect how much droop you have & therefore (assuming you have some bump steer, which you will have) the toe.
3. Roll the car till it just touches a wall or some other object that is relatively perpendicular to the surface the car is resting on. Turn a camber gauge sideways & rest it on the wall. Measure the positive camber in relation to the wall. This will be your negative toe. This guarantees the car is at its nominal ride height with out outside interference, so it is repeatable. This is the method I use.
Old 05-30-2014, 06:25 PM   #14602
ekt
ekt's Avatar
I use droop blocks and a ruler/ride height gauge for measuring droop, measuring at the axle.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 05-30-2014, 08:18 PM   #14603
Azagar's Avatar
You need to remove the rubber bump stop to use the older shocks with the V2 tower and v2 flat arms. The rubber stop is around 2mm long. Thus the difference in shock bodies is 2mm so you don't really gain or lose anything. But having a longer shock shaft you need to adjust front droop accordingly with the screws, or you can use a 2mm plastic spacer inside
Little confused on this. The rubber stopper is designed to limit up travel not down travel right? The new v2 shocks are 3mm shorter, so the only way to properly limit them on the new v2 arms are with internal spacers inside the shock body, or using the front bulk head droop tabs which will limit the down travel of the shock by default.
Team Durango DEX210
Avid | AKA | Exotek | Jconcepts | KO Propo | Lunsford | Tekin | Turnigy Nano-tech
Azagar is offline   Reply With Quote
Old 05-30-2014, 08:29 PM   #14604
Dog bones popping out might be a result of too much down travel. Adjust with droop screws. Bottoming out may be the result of a piston and oil combination
Try 3x1.5 and 25wt or 27wt in the rear
Low grip use RM4.
Having a shorter front shock tower makes the car react faster to driver input. Great on a higher grip track with not to many jumps and bumps.
I'm talking bout the rear shock tower being 4mm shorter
TEAM DURANGO CARBON DEX210 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
TEAM DURANGO CARBON DEX410 - POWERED BY TEKIN RS PRO/REEDY SONIC 17.5
TEAM ASSOCIATED B5 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
LiL_JaSoN is offline   Reply With Quote
Old 05-30-2014, 11:33 PM   #14605
Trader Rating: 137 (100%+)
Have a V2 n the way. Has anyone been able to fit electronics inline down the center of the car?
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 05-30-2014, 11:53 PM   #14606
Trader Rating: 51 (96%+)
you can if you use a shorty pack with smaller electronics JP.
CaseyDDR is offline   Reply With Quote
Old 05-31-2014, 07:30 AM   #14607
303slowdown's Avatar
Trader Rating: 21 (100%+)
I tried running the v1 shocks with the v2 arms and shock tower and down travel wasn't the problem the problem I had was at compression the piston would hit the shock cap before the chassis would hit the ground , so I went back to v1 arms until I can get the shorter shock body's and shafts.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 05-31-2014, 01:36 PM   #14608
13Maschine's Avatar
What size droop blocks did you go with?
Old 05-31-2014, 09:24 PM   #14609
ekt
ekt's Avatar
20mm blocks
Originally Posted by Waflet View Post
Hideeho
I'm still new to durango & didn't realize the desc210 came with front hexes. That's what happens when you assume things
Can you adjust the trail on the desc210 front axles the way you can on the dex210?
Follow up question about front hexes:
Could someone with a dex410 measure the offset of the front wheels? The easiest way to do it is place something straight & sturdy something (i.e. a ruler) across the back of the wheel & measure down from the top of that to the inside of the hex. Most calipers will have piece that sticks out the back as you open it, this can be used to measure depth. Then measure the width of the strait edge you measured from & subtract the from your total.
Looking at the 410 wheels, I'm betting it will be close. If these off sets are the same, people that have a 410 & a 210 will be able to run the same wheels on both (you probably don't want to run the same tires, but that is another subject ).
Not sure how accurate my calipers are but I measured it to be 23.7mm
Leo Lorenzen
Old 06-01-2014, 02:16 AM   #14610
Trader Rating: 74 (100%+)
Im using Tresery MOS bodies for the V1 and they are the perfect fit for the V2 arms. And the Proline body fits my +11 chassis perfectly.
Serpent USA www.serpentamerica.com, King Max Servos, Gens Ace, MIP, www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
