Like Tree23Likes
Old 05-23-2014, 06:20 AM   #14536
Waflet's Avatar
Trader Rating: 30 (100%+)
Originally Posted by ekt View Post
Sounds like you may have old c-hubs, they were revised to stop the steering knuckle from travelling too far and locking up
Hideeho
Was it a running change so same part # I just need to order new ones?
"Just leave me alone, I know what I'm doing."-Kimi Raikkonen
Mugen MBX7R Eco/Tekin RX8g2/Savox 2274/SMC 1900kv/Aitronics mt-4/promatch
Mugen MSC7(1/10 pro4 sct)/Tekin RX8g2/Savox 2274/Tekin Pro4HD 4300kv/Airtronics mt-4/SMC
Waflet is offline   Reply With Quote
Old 05-23-2014, 12:13 PM   #14537
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
Dino_D: I was comparing your setups for the dimec +8mm chassis equipped vehicle and the one that is based on the dex210v2 and its alloy chassis.
Based on the shock setups and what I have here, I believe I can pull off the setup you have shockwise for the dex210v2 setup (1.6mm x 3) on my vehicle though I have dimeC chassis. Do you think I could still see some benefit? I personally feel like I want a big more pack on the rear end of the car.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 05-23-2014, 02:47 PM   #14538
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally Posted by T-BirdJunkie View Post
ASC91406
TDRTD330382
And B4 rear hexes
Yes, B4 rear hexes. Look at your axle and note how it steps down from 5mm just a little bit to the wheel mounting area...it's a 3/16" axle! Use the B4 clamping rear hexes used in the B4.2...I tried to find a PN on Tower really quick, but couldn't. I suppose one could use PL or Jcon's, but I had the Jcon ones on my T4 and bent one (no BS, it was BENT)
Thanks. Those are the parts I put on order at the shop the other night. I will order the car in a few more weeks.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 05-23-2014, 07:22 PM   #14539
Waflet's Avatar
Hideeho
One drawback about using the Durango hub (TDRTD330382) is you can't change the trail on the hub. It is fixed in the "3" position. I measured the height & offset & the b5 hub (http://www.amain.com/product_info.ph...ring-Block-Set) looks like it work with minimal modification. It is to tall & will need 1mm trimmed from each end (top & bottom) to fit or 2mm to be able to adjust hub height. The offset seems to be a little less than .5mm short each side (the same for the b4 rear hexes). Avid sells shims (http://www.avidrc.com/product/5/acce...cessories.html) to adjust track width to get it back to spec. With this setup you can still adjust the trail of the front axles.
One word of warning, I have not installed this on my car yet. I have only measured things out with the parts loose in my hand. There may be fitment issues I missed looking over things.
Old 05-23-2014, 11:55 PM   #14540
ekt
ekt's Avatar
Originally Posted by Waflet View Post
Hideeho
It was a running change, same part number.
*edit* Picture of the difference
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 05-24-2014, 11:04 AM   #14541
Waflet's Avatar
Hideeho
Yep, I have the old blocks. One more thing to add to the list of parts I need
Old 05-24-2014, 02:12 PM   #14542
Quick ? Guys does the diff nut go on right side or left looking from rear of car?
jg24rw is offline   Reply With Quote
Old 05-24-2014, 07:33 PM   #14543
rcjunky1's Avatar
I'm pretty sure the passenger side
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 05-24-2014, 09:06 PM   #14544
ekt
ekt's Avatar
Technically it doesn't matter.
Leo Lorenzen
Old 05-25-2014, 09:15 PM   #14545
T-BirdJunkie's Avatar
Location: Norwood, OH...and CCRCR and The OhioRCFactory
Send a message via AIM to T-BirdJunkie Send a message via MSN to T-BirdJunkie
I love the 210 platform. You should enjoy the car...you were the guy that was running the snot out of that Losi SCT (whatever the hell it was called, before the XXX-SCT) right?
Hideeho
So...move one shim to the front of the caster block and adjust your ackerman...It's not rocket surgery If solving these problems quicky is not within your skill set, this is certainly not the car for you anyway.
If you don't allow yourself to make mistakes, you'll never allow yourself to succeed
T-BirdJunkie is offline   Reply With Quote
Old 05-25-2014, 09:22 PM   #14546
Oasis's Avatar
Trader Rating: 36 (100%+)
Is the durango still a viable platform ? The reason why I'm asking this is the V2 doesn't see to be a big change form the first..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 05-25-2014, 09:34 PM   #14547
The first was/is a great car. They fixed my gripes about the V1 on the V2 (gullwing arms are too gullwingy, rear shock tower I've always thought was too tall).
Old 05-25-2014, 09:38 PM   #14548
rcjunky1's Avatar
The v2 is much nicer to work on. Otherwise it was dialed, now it is dialed. The v2 and v4 are both dialed and refined cars now. I love these cars
Team Durango Canada
Old 05-25-2014, 10:40 PM   #14549
Oasis's Avatar
The one I have (just picked it up) is pretty modded..not sure if that's a good thing..but the mods that are on the car seem to be ok..I have the new front & rear a arms but I haven't put them on because the front shocks are not available yet..any suggestions on shock pistons..oil..rear motor. .med to high traction, indoors..
Old 05-26-2014, 07:12 AM   #14550
Dino_D's Avatar
The shock setups I have using the 1.5 or 1.6 pistons is based upon the shock o-ring. Standard orange one using the 3x1.5 and split rears 27/25 or purple o-rings using 3x1.6 35/30. The low friction o-rings offer less resistance, thus you need to increase oil weight to compensate, which in turn you need to alter pack also to compensate for the increase in oil wt. You can adjust the oil weight higher based on temperature as the oil wt reference I use is for 20 degrees C temps. You will need to go a step or 2 higher in the summer.
Whether you use the plastic or aluminum chassis there is a weight difference, but it is not that much. The biggest difference is the flex. A chassis with more flex is preferred on a low bite bumpy track. A stiffer chassis is better on a med to high bite track.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
