Like Tree43Likes
Old 05-21-2014, 05:39 PM   #14521
303slowdown's Avatar
Trader Rating: 24 (100%+)
Originally Posted by CaseyDDR View Post
So because of Cain, I have a DEX210v2 in my cart on Tower. Are there any immediate upgrades I should include to the purchase? And is there a mid motor conversion? Our buggies run first at our track after a fresh watering (as he has said) so I'm on the verge of jus going mid motor to take advantage of the massive amounts of traction we get from that.
It will come with the parts needed to do rear and mid motor. It does it all with one kit.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 05-21-2014, 09:16 PM   #14522
T-BirdJunkie's Avatar
Location: Norwood, OH...and CCRCR and The OhioRCFactory
Send a message via AIM to T-BirdJunkie Send a message via MSN to T-BirdJunkie
Originally Posted by wyd View Post
If it is that simple I guess I'm placing my order for the new buggy on our hobby shops GP order. Damn this is what I was waiting for before I pulled the trigger on the new V2. Did you use the B5 axles with the built in hex or the optional B5 axle?
Could you include part numbers? I'm about to checkout of Towerhobbies with my DEX buggy kit
ASC91406
TDRTD330382
And B4 rear hexes
Yes, B4 rear hexes. Look at your axle and note how it steps down from 5mm just a little bit to the wheel mounting area...it's a 3/16" axle! Use the B4 clamping rear hexes used in the B4.2...I tried to find a PN on Tower really quick, but couldn't. I suppose one could use PL or Jcon's, but I had the Jcon ones on my T4 and bent one (no BS, it was BENT)
If you don't allow yourself to make mistakes, you'll never allow yourself to succeed
T-BirdJunkie is offline   Reply With Quote
Old 05-21-2014, 09:18 PM   #14523
Speaking of which, I now have a ton of 14mm wheels/tires and front tires for the 210 I wouldn't mind unloading. I'd rather not bake them all off...the wife doesn't go out of town, so I'd never get away with it.
Old 05-22-2014, 08:11 AM   #14524
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
if you have tires that are for dirt conditions ( holeshots and bigger treads up to step pins) I could be interested depending on price. Would want super soft compounds, or M3 and softer if proline.
So for this conversion, am I missing something or will this work pretty much on any dex210 version?
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 05-22-2014, 10:50 AM   #14525
I see there is sway bar mounts but what sway bars fit this kit?
JustinL7294 is offline   Reply With Quote
Old 05-22-2014, 11:16 AM   #14526
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
Does the conversion listed above leave the car with the same wheel offsets/width as stock? Would make someone that has some B4/B5 wheels/tires a little more interested in the 210.
Jeff Werner is offline   Reply With Quote
Old 05-22-2014, 11:20 AM   #14527
Azagar's Avatar
Not exactly. These were my findings when measuring all the offsets. It's not a simple conversion if you want to maintain the stock offsets.
Team Durango DEX210
Avid | AKA | Exotek | Jconcepts | KO Propo | Lunsford | Tekin | Turnigy Nano-tech
Azagar is offline   Reply With Quote
Old 05-22-2014, 01:22 PM   #14528
Should work for the V2, since the axles and front end parts are the same. The DEX210 is, by nature, a bit narrower than the B5M, but it's right, as far as stock vs conversion goes. Remember, Durango used a B4 during development for the DEX210
Are you interested in Calibers, IFMAR studs, IFMAR pins, and the like? PM me.
I have a B4.2 and a B5M, which is why I did what I did.
Old 05-22-2014, 01:24 PM   #14529
Trader Rating: 51 (96%+)
Just bought my 210v2, next day shipped it so I can race it this Sunday. GJ Cain :P
CaseyDDR is offline   Reply With Quote
Old 05-22-2014, 01:46 PM   #14530
Tech Legend
Cain's Avatar
lol. Let me know how it goes, looking forward to hearing how that setup works out you are looking to try.
Old 05-22-2014, 01:49 PM   #14531
I think I'm going to set it up as MM since we get preference on the track, with all the traction I bet it works great.
Old 05-22-2014, 02:04 PM   #14532
Dino_D's Avatar
The v2 comes with parts to run either RM or MM. If you have the grip, then MM. If not RM maybe more consistent if the grip changes thru the day.
One option part you may want to consider is running a brass 1.5 rear front suspension holder from RDRP. It places more weight near the rear axles which will give you more grip if traction is Med or if the track starts to dry during your heat. You don't need it if you run RM.
Maybe pick up Dark Green Fronts, and Black Rears as a tuning option. - one rate harder than stock (Stock comes with black front, light blue rears)
And run the plastic HRC block, not the supplied aluminum LRC -2 block. The LRC is good for sugared outdoor tracks or indoor med/high grip clay tracks.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 05-22-2014, 02:55 PM   #14533
If you would, elaborate on your reasoning for the hrc rear block. I get it if your running the 1.5 front, but what if you run the 0 front and the -2 lrc rear block.
Team Durango DESC 410V2,Team Durango DESC 210R
Team Durango DEX 410V5,Team Durango DEX 210V2
Mike Maniscalchi www.team-durango.com
knowitall156 is offline   Reply With Quote
Old 05-23-2014, 01:34 AM   #14534
Waflet's Avatar
Trader Rating: 30 (100%+)
Hideeho
I recently got a used dex210v1. I have 2 problems with it.
1. When I set my EPA to get full turning every now & then the inside wheel locks into place. The steering arm on the hub gets bounced past a straight line with the turnbuckle. Is there a simple way to fix this? I have the axles in position 4 (full back) & the hub full forwards. I have no bump steer washers on the arm & 2.5mm on the Ackerman + 2mm order the steering blocks. This setup gets me zero bump steer, but I'm wondering if this is the source of my binding.
2. The chassis has at week in front of the steering blocks (could this be the source of my problem from #1?) & a couple of the screw holes in side pods are strpped out. Does anyone have an old v1 chassis &/or side pods they could let go for cheap?
I also have a question. How tight does the dif & slipper need to be set? I used to set my b4 dif to 1/8 turn off full tight & the slipper tight enough to lift the front wheels 3". Will this be a good starting point for the 210 as well?
"Just leave me alone, I know what I'm doing."-Kimi Raikkonen
Mugen MBX7R Eco/Tekin RX8g2/Savox 2274/SMC 1900kv/Aitronics mt-4/promatch
Mugen MSC7(1/10 pro4 sct)/Tekin RX8g2/Savox 2274/Tekin Pro4HD 4300kv/Airtronics mt-4/SMC
Waflet is offline   Reply With Quote
Old 05-23-2014, 03:25 AM   #14535
ekt
ekt's Avatar
Originally Posted by Waflet View Post
Hideeho
Sounds like you may have old c-hubs, they were revised to stop the steering knuckle from travelling too far and locking up
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16575 Yesterday 12:44 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
