Like Tree23Likes
Old 05-05-2014, 12:39 PM   #14401
fq06's Avatar
And yet another way to skin the cat, V1 +0 kit chassis RM. Didn't change it for the V2 chassis.
Inline FTW!
BCE SCT410 / Hobbywing 3656sd ~ RX8.2
DEX210 / Trinity 17.5 ~ RS.2
Westcoast Raceway (R.I.P.) | SMC | PowerLab
fq06 is offline   Reply With Quote
Old 05-05-2014, 01:46 PM   #14402
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
nice pic!
Alright still waiting to hear back from the guy I bought the more loaded car from about the springs he showed me in the pics that were not included in the package.
Assuming I don't get those in, using the DIMEC chassis in RM configuration for loose track conditions what do you recommend having in the pit box for spring rates?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 05-05-2014, 01:52 PM   #14403
fq06's Avatar
Black rear and dark green, dark blue and maybe dark red fronts.
That's the springs I have been using in RM.
Old 05-05-2014, 01:54 PM   #14404
Dino_D's Avatar
Originally Posted by Cain View Post
nice pic!
To start I would do RM4 transmission
Black or Light Blue Front
Light Blue Rear
3.5 or 4 toe
1.5 antisquat
Once you figure out how much grip you have, then you can go about changing springs or trying the RM3 if you like. But I would always start with RM4 just to be sure.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 05-05-2014, 01:57 PM   #14405
fq06's Avatar
Oh yeah, dimec, he will be lighter than me so a step down in spring rate makes sense.
Old 05-05-2014, 03:47 PM   #14406
Tech Legend
Cain's Avatar
thanks everyone appreciate the info. This will also have stock class 17.5 blinky duty and 10.5 mod as well.
Old 05-05-2014, 05:27 PM   #14407
Pittster's Avatar
Another RM3 inline ESC setup here I have run it like that for a while I like it.
Also ran my v1 210 with all the v2 upgrades excluding the +8mm and the RR LRC block for the first time on the weekend.
I had shocking under steer on power so changed the front spring from Dark green to black and added some droop so the front arms are nearly level and this gave me a really dialled in car good turn in and I could really control the attitude of the car through throttle control, but it was harder to drive.
Managed to get 4th which surprised me as I was driving to aggressive and crashing a fair bit.
This was on a blue groove dusty surface with holeshots Rear and AKA 3 rib fronts.
Current setup is:
4x1.3mm all round 30wt F 25wt R 22mm ride height all round.
L Blue rear Black front.
4 Deg rear toe -1.5 Anti squat -2 camber all round
Battery placment as per photo.
Stock link and shock positions as per V2 manual
I run 17.5 and current race weight is 1650g (bit on the heavy side :O)
Really liking how Durango allow's me to upgrade my cars over time as my V3 410 has nearly all the V4 parts in it also and that thing handles like a dream.
Team Associated B6D, Speed Passion Reventon Pro 1.0, Hobbywing V10 7.5t
Team Associated B64D, Speed Passion Reventon Pro 1.1, Hobbywing V10 G2 6.5t
Team Associated B5M CE, Tekin Rs Gen2, Fleta ZX 17.5t
Pittster is offline   Reply With Quote
Old 05-05-2014, 05:37 PM   #14408
Pittster's Avatar
Quick question would it be worth Going to the newer LRC RR -2mm block or machining down my current v1 RR block -2mm? It should achieve the same thing shouldnt it?
Old 05-05-2014, 09:12 PM   #14409
Azagar's Avatar
That's a good idea, shaving 2mm from the bottom of the old RR hanger especially if you're still using a v1 chassis. But which RF are you using?
Team Durango DEX210
Avid | AKA | Exotek | Jconcepts | KO Propo | Lunsford | Tekin | Turnigy Nano-tech
Azagar is offline   Reply With Quote
Old 05-05-2014, 09:51 PM   #14410
Pittster's Avatar
Just the V1 original plastic RF -1.5 block.
So I would assume I would have to mill down the RF block also by -2mm otherwise i will have -3.5mm anti squat?
Old 05-05-2014, 09:56 PM   #14411
Azagar's Avatar
Just use the 0 so you're at 2 degrees. Or upgrade to the new v2 ones. The plastic that those are made of is so much better, less soft and gummy.
Team Durango DEX210
Old 05-06-2014, 09:54 PM   #14412
Tech Legend
Cain's Avatar
what circlip pliers are you guys using. started to work on a ball diff but can't get that clip out for the life of me with anything I have here so looking for the pliers to do the job unless someone else has a recommendation.
also. how many shims do you use and on what side with the gear diff?
Old 05-06-2014, 11:12 PM   #14413
rcjunky1's Avatar
I use no shims on the gear diff if I remember right, and got my cir clip pliers from Lee Valley Tools, its was like $8 and pretty solid.
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 05-07-2014, 03:47 AM   #14414
This diff does not need any shimming.
goszu is offline   Reply With Quote
Old 05-07-2014, 09:26 AM   #14415
Tech Legend
Cain's Avatar
you have a direct link? tried a few search options but nothing came up.
Thanks for the info.
As it sits right now I think I need only the rear motor guard specific for the type B Dime chassis based on what my daughters vehicle had.
going to do a rebuild on the other car, mainly the rear end as it look slike just need to confirm what parts I have for that and be good to go, and will then place an order for parts needed.
Does anyone know of a retailer other than amain that carries both the avid clutch and durango parts? wanting to order another one as well as the durango parts, and then need to ship fast.
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
