Like Tree24Likes
Old 05-02-2014, 09:06 AM   #14371
Azagar's Avatar
Kyosho front hexes will work, only ones I personally have so I know for sure. But in theory all front hexes for any 2wd buggy will work as long as they use a 5mm bearing. B4 of course can not because that uses a standard size bearing. I do want to stress the wheel thread amount isn't that great. I'll post a picture so you guys get an idea. There's enough thread, just not enough for my liking. The wheel nut i'm using are these.
Durango DEX210 Thread-kyosho-axel.jpg   Durango DEX210 Thread-xray-axel.jpg   Durango DEX210 Thread-kyosho-axel-1.jpg   Durango DEX210 Thread-xray-axel-1.jpg
Team Durango DEX210
Avid | AKA | Exotek | Jconcepts | KO Propo | Lunsford | Tekin | Turnigy Nano-tech
Azagar is offline   Reply With Quote
Old 05-02-2014, 09:39 AM   #14372
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
sigh, any reason durango is not wanting to make a conversion other than the wheel deal. Seems could sell a ton of that stuff. Or maybe another company can just make a direct one like exotek.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 05-02-2014, 01:34 PM   #14373
white03's Avatar
Send a message via Yahoo to white03
As you all know I have a dex210 v1. Now I'm slowly converting to a v2. The question I have is that does the v2 front arms make a difference other than ground clearence compared to the v1 arms? I personally like the gullwing arms. Thanks!
white03 is offline   Reply With Quote
Old 05-02-2014, 01:41 PM   #14374
fq06's Avatar
I don't mind the fronts without hex, just gotta pop a couple bearings out when you wash them but no big deal. The reason I have 12mm hex's for the rear (thanx 13mashine) is because I want to try the typo in the rear.
Other than wanting a tire that requires a certain wheel I think the bigger hex in the rear is a good... I wish my Tekno had a hex that large for the weight of the truck and the ludicrous power that it has.
BCE SCT410 / Hobbywing 3656sd ~ RX8.2
DEX210 / Trinity 17.5 ~ RS.2
Westcoast Raceway (R.I.P.) | SMC | PowerLab
fq06 is offline   Reply With Quote
Old 05-02-2014, 05:08 PM   #14375
Devin's Avatar
My rear A arms are loose and wobbly. I think the play is located in the in the unit that holds the giant pins into the chassis (that goes through the A Arm). Either the anti squat/toe in block is worn out and needs to be replaced, or I did not put this section back together properly when I was changing to 4 gear.
Any ideas on what I could have done wrong in the assembly? Would adding a small shim to each of the long pins solved my slack in a way that wouldn't break my car?
Devin is offline   Reply With Quote
Old 05-02-2014, 06:15 PM   #14376
ekt
ekt's Avatar
Adding some shims will fix forward/backwards play in the arm, just don't add too many that it binds.
Here's a pic from Team Durango's site
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 05-02-2014, 07:21 PM   #14377
Devin's Avatar
Fantastic info my man, I really appreciate it.
Now I just need to scour around for some shims. Snow is 90% gone, anxious to get this beast wired and rolling.
Old 05-02-2014, 08:55 PM   #14378
Lone Star's Avatar
Just finished v2 build. Much better plastics than b4.2, shocks are butter. Tried 13mas's recomendation of proline hexes on the rear to run ae rims. Works like a champ. Just put in the b4 rollpin and put on the hexes. No shims or spacers needed. Ae and proline rims have plenty of threads left. Losi 22 rears only leave 2-3 threads so i would use them with caution. Maybe thats why exotek and dingo haven't made a convert kit, no need too. Thanks 13.
DEX210V2, Toxic Tops Shuttle body for DEX210v2, lightened 7075-t6 3mm chassis.
Lone Star is offline   Reply With Quote
Old 05-03-2014, 05:10 AM   #14379
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
I have been running 12mm for a while and have spun a few of the hexes in my JConcepts inverse wheels. They seem just a little too soft especially for mod and this has pushed me back into using stock Durango wheels and 14mm hexes when I can. You just don't have access to the EVO tires. Looks like Pro Line is going to do an EVO style line of tires too.
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 05-03-2014, 05:21 AM   #14380
ekt
ekt's Avatar
AKA released a conversion kit allowing the use of standard wheels with their EVO tires http://www.raceaka.com/110-EVO-CONVE...T-_p_1076.html
Leo Lorenzen
Old 05-03-2014, 05:37 AM   #14381
13Maschine's Avatar
As far as the front hex goes, I highly recommend the Kyosho axle setup, as you can adjust your front track. Although I think I already mentioned earlier I am going back to regular wheels so I can mess with trailing vs in line…..It's REAALLY nice to be able to steal tires from the associated and Kyosho guys.
My initial thoughts on the EVO Typos is that they are very similar to the Pro Line IONS. I've only tried them at SCVRC though. I want to try them at OCRC and see. That being said I'd rather have Durango wheels and 14mm hexes. I'm considering taking a set of Durango wheels and shaving the outside ridge to make it more like an EVO wheel, perhaps I will also need their conversion kit to make it work. I'll post my findings in my Tire tech talk thread….
Tire Tech Talk - Compounds, Wheels, Inserts, Sauce!
Old 05-03-2014, 05:37 AM   #14382
13Maschine's Avatar
@EKT! hahaha so funny. Fq06 and I were discussing this recently too
Old 05-03-2014, 05:39 AM   #14383
13Maschine's Avatar
I've also noticed when you compare the EVO wheels to a Durango wheel the EVO wheels are quite a bit softer, probably due to the single low profile ridge instead of two. Seems like they could go out of round easily.
Old 05-03-2014, 08:51 AM   #14384
13Maschine's Avatar
Cool Kyosho 12mm Axle MOD
Another great reason to do the Kyosho axles in front is that you can use 12mm Losi 224 front wheels for an extra wide front tire setup. I'm not sure about legality in terms of ROAR on this but since you can adjust the width perhaps you can make it work. They fit using only 2mm of spacers as I have pictured here:
Durango DEX210 Thread-img_0496.jpg   Durango DEX210 Thread-img_0497.jpg   Durango DEX210 Thread-img_0498.jpg
Old 05-03-2014, 01:38 PM   #14385
Azagar's Avatar
How many mm in spacers are you using in between the hex?
Team Durango DEX210
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
