Like Tree24Likes
Old 05-01-2014, 05:07 AM   #14356
snowman_evil's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to snowman_evil
Is there a Aluminum servo horn that will fit in the dex210 without modification?
Thanks!
DEX410V3 - Tekin - Spektrum - Panther
GCRC Raceway - "Lightning"
snowman_evil is offline   Reply With Quote
Old 05-01-2014, 06:05 AM   #14357
ekt
ekt's Avatar
Thanks!
The TLR 22 servo horns are a good fit
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 05-01-2014, 06:06 AM   #14358
Pittster's Avatar
Thanks!
Get the tlr alloy servo horn that suits the tlr 22 fits great with the correct offset just had to add a washer under the ball on the horn.
http://www.tlracing.com/Products/Def...ProdID=TLR1557
Edit: damn EKT beat me by 1 min haha
Team Associated B6D, Speed Passion Reventon Pro 1.0, Hobbywing V10 7.5t
Team Associated B64D, Speed Passion Reventon Pro 1.1, Hobbywing V10 G2 6.5t
Team Associated B5M CE, Tekin Rs Gen2, Fleta ZX 17.5t
Pittster is offline   Reply With Quote
Old 05-01-2014, 09:44 AM   #14359
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
@Cain: I've had my hubs pushed forward since essentially the 12mm conversion puts the wheels 3mm back if you were to compare to the inline setup. So all my spacers are behind the hub. I plan to do some testing with inline axles now to compare (I have way too many tires now though!)
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 05-01-2014, 09:44 AM   #14360
13Maschine's Avatar
+1 for TLR servo horn. DATS WHAT I GOT!
Old 05-01-2014, 11:48 AM   #14361
foxracer117's Avatar
With the Avid 12mm hexes, how does the track width compare to stock?
foxracer117 is offline   Reply With Quote
Old 05-01-2014, 11:51 AM   #14362
rcjunky1's Avatar
Originally Posted by thefan View Post
What are you doing for inline steering are you putting the 4 1mm spacers in front or leave them behind, i know durango say to move the spacers forward however most setup sheets show the 4 behind still, it kind if seems counter productive to move the axle forward a mm only to move it back with the spacer
The 4 spacers are to match the trailing adjustment. The point of adjusting the trailing has nothing to do with the wheelbase, you want it to stay that same, as well as maintain the angles on the steering tie rod. The adjustment is soley to adjust the position of the axle relative to the pivot point. Paying with those spacers otherwise plays with the wheelbase and steering geometry, completely separate fro the trailing adjustment.
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 05-01-2014, 03:09 PM   #14363
13Maschine's Avatar
Here's the quote from Durango on the trailing adjustment:
"The DEX210 as per kit set-up comes with the front axles in maximum trailing. This gives the front of the car the most feel and is the easiest to drive. The further forward you put the front axle to more aggressive the car becomes on initial turn in, this can help you to make the car ‘pivot’ more on entry to a corner when grip is low and steering is at a premium. When you move the axle forward in the block by use of the inserts, remember to move the 4 wishbone inserts which space the c-hub in the wishbone.
The Rule of thumb is however much trail you have you must have the same number of 1mm spacers behind the C-hub."
Old 05-01-2014, 03:32 PM   #14364
13Maschine's Avatar
I think you also have to take into consideration that moving the hub forward lowers the front end a little bit so if you wanted to keep the orientation you should probably move the hubs down with the spacers as well.
Old 05-01-2014, 03:34 PM   #14365
13Maschine's Avatar
So far since I've been running the 12mm conversion which is similar to having a 3mm trailing setup, I've noticed it can be hard to get the car to turn in, it has good ON power steering but that initial turn in isn't there like I would prefer it to be. This is why I'm switching to the inline axle to try the forward setup. I also think I prefer to have the adjustability and I don't care much about having my bearings in my wheels.
Old 05-01-2014, 04:34 PM   #14366
wwddww34's Avatar
Trader Rating: 9 (91%+)
Does anybody know if it's possible to make the DEX210 a mid-motor buggy? Is there a conversion kit, or something?
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 05-01-2014, 05:07 PM   #14367
rcjunky1's Avatar
Absolutely. This is (IMO) the best convertible buggy out there. The kit includes everything you need for 4 layouts, 3 and 4 gear mid and rear motor. If you have the RTR, the mid motor parts are included, just not the 4 gear parts (idler gear, idler shaft, 2 5x10 bearings and 2 5x8x0.5mm shims)
Team Durango Canada
Old 05-01-2014, 09:05 PM   #14368
Azagar's Avatar
Default 12mm Front Hex Mod
Well good news for those interested in converting to 12mm hex for the front wheels. These axels are a perfect fit, no need to add spacers or do any cutting and the offset for the wheels will match. Just be aware you need to buy two of those and 5mm diameter hexes. In the photos below i'm using the B4.1 Avid hexes but I used my Dremel to bore out the diameter to 5mm.
One thing to note though is the wheel thread is about 2mm shorter then if you go the Kyosho route. I personally prefer the Kyosho axels because I can play with front track width, so it's just another tuning option. If you go this direction you will need 3 packs of these, 3 per side, and cut 3.5mm from the axel.
Durango DEX210 Thread-12mm-hex.jpg   Durango DEX210 Thread-12mm-hex-1.jpg   Durango DEX210 Thread-12mm-hex-2.jpg
Team Durango DEX210
Avid | AKA | Exotek | Jconcepts | KO Propo | Lunsford | Tekin | Turnigy Nano-tech
Azagar is offline   Reply With Quote
Old 05-02-2014, 08:55 AM   #14369
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
Just to confirm on the Xray conversion, what hex out there requires no mods?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 05-02-2014, 09:05 AM   #14370
I would also like to know this.. I'm tired of stripping hex screws.. This mod will make me stick with durango I want to run evo wheels
cripplethreat is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
