Like Tree24Likes
Old 04-14-2014, 01:50 AM   #14206
ekt
ekt's Avatar
Originally Posted by snowman_evil View Post
Thanks!!
Has anyone else had trouble with binding issues with the V1 casing? Ive tried replacing EVERY part in the casing including the gearbox housing and followed the build as per manual but still get binding. Anyone else had the same thing? Ive read elsewhere there was moulding issues with the V1 gearbox and they have tried to resolve this in the V2 Type B gearbox..
Any Help Appreciated!
Are you using a gear diff? There was a issue with one batch, that I remember.
Also does anyone know if you use the V2 Gearbox, if you require the new layshaft (TD210033) or if the standard V1 shaft will work fine??
The layshaft is the same between the 2 versions.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 04-14-2014, 02:42 AM   #14207
snowman_evil's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to snowman_evil
I am using a gear diff yes. What was the issue with the batch if you can recall? It is a RTR DEX210 if that helps at all!
DEX410V3 - Tekin - Spektrum - Panther
GCRC Raceway - "Lightning"
snowman_evil is offline   Reply With Quote
Old 04-14-2014, 07:22 AM   #14208
rcjunky1's Avatar
there was a batch they where too wide creating binding
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 04-14-2014, 04:29 PM   #14209
I just got my V2 rear arms installed. The rest won't be here until tomorrow. The design is much nicer than the V1. This is what the arms should have been like all along. I'm excited to see the rest of the parts. The V2 is going to be a really good car.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 04-14-2014, 06:17 PM   #14210
Trader Rating: 28 (100%+)
I sent Fred a PM but I thought I would get the rest of you to weigh in as well. Obviously the DEX210 market is flooded with V1s. Some of which are very highly upgraded. I received my DEX210 V1 and realized that I will be wanting to quickly add a variety of upgrades (mainly +8mm chassis). It appears that it may be better for me to purchase another DEX210 (sell my current one) rather than pay full price to upgrade this one.
Keeping that in mind should I go for the V2 bnib? I usually prefer to wait for a reputable seller and purchase used (more bang for my buck in most cases). So, there are several extremely well upgraded V1s (with the +8mm chassis) that I could slap some V2 A-arms on and essentially have a similar V2 but with more aftermarket parts. Any thoughts on these ideas? I realize it is primarily personal preference but I thought I would get a variety of opinions first.
SPFDheli is offline   Reply With Quote
Old 04-14-2014, 06:38 PM   #14211
Part of the fun of rc for me is trying things. I get bored with just one thing. I'm enjoying upgrading a V1 to a V2. The V2 kit really isn't all that expensive new though so if your goal is to have a V2, just buying one will be cheaper in the end.
Old 04-15-2014, 12:30 AM   #14212
I just ordered most of the v2 parts that i need to make my v1 to a v2. I forgot to get the new front shock body and shock shaft. I cant wait for my parts to get here.
Airtronics MT-4s
madmikegxp is offline   Reply With Quote
Old 04-15-2014, 01:37 AM   #14213
I had issues with binding in the gearbox too.
There are two washers on the idler gear pin on both sides of the bearing according to what the manual says.
Instead of using both of the washers I used it only on one side.
With only one shim there is no binding any more and the gears spin freely.
goszu is offline   Reply With Quote
Old 04-15-2014, 02:17 AM   #14214
Unfortunately mine has binding issues no matter what I do with it, tried 0 washers, tried 1, tried 2, replaced every part in the whole assembly including the gearbox itself and no luck. Must just be a bad batch of gearbox's and Ive got one of them. Got a V2 gearbox on its way to see how it goes. Fingers crossed it resolves the binding!
Old 04-15-2014, 02:29 AM   #14215
Does anyone know if any other brands pistons will fit in the Durango shocks?
Old 04-15-2014, 06:37 AM   #14216
fq06's Avatar
If I want to run the LRC RR hanger, do I need to pair that with a new LRC FR hanger? Or just the regular FR hanger?
I would think both would have to change the pick up points but couldn't find anything on the FR that's -2
BCE SCT410 / Hobbywing 3656sd ~ RX8.2
DEX210 / Trinity 17.5 ~ RS.2
Westcoast Raceway (R.I.P.) | SMC | PowerLab
fq06 is offline   Reply With Quote
Old 04-15-2014, 08:14 AM   #14217
white03's Avatar
Send a message via Yahoo to white03
are there any benefits to running the +8 chassis?
white03 is offline   Reply With Quote
Old 04-15-2014, 09:39 AM   #14218
Regular front 0 hanger.
Team Durango DESC 410V2,Team Durango DESC 210R
Team Durango DEX 410V5,Team Durango DEX 210V2
Mike Maniscalchi www.team-durango.com
knowitall156 is offline   Reply With Quote
Old 04-15-2014, 09:48 AM   #14219
fq06's Avatar
Thanx.
The +0 chassis will be better on a small track, shorter wheel base. The +8 will be better on bigger tracks with more open turns, the buggy won't be as snappy into turns
Old 04-15-2014, 09:51 AM   #14220
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
@fq06: I'd suggest looking at this exotek quick change rear hanger piece. It fits the Type B and the aftermarket chassis as well. It makes it super easy to adjust without dissembling the rear end, just loosen the screws. It will allow you to do High Roll Center and Low Roll Center settings with the appropriate RR hangers (exotek makes several options) I love mine!
http://www.exotekracing.com/dex210-r...ith-shims-lrc/
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
Doughty
