Like Tree23Likes
Old 03-31-2014, 10:42 PM   #14071
rcjunky1's Avatar
I think a bit of heat on the stocker will do just fine
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 04-01-2014, 06:26 AM   #14072
hacker's Avatar
Trader Rating: 140 (100%+)
anyone running more than 3 degrees of anti-squat?
hacker is offline   Reply With Quote
Old 04-01-2014, 06:38 AM   #14073
Why would you do that? I run 0.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 04-01-2014, 08:35 AM   #14074
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
I also run 0 degrees of Anti Squat, however I will run a little bit if the car starts to wheely. it helps to give the car a little less rear traction as it decreases the amount of weight transfer to the rear of the car. It can also make the car jump a little farther and/or steer a little more due to less rear traction.
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 04-01-2014, 09:30 AM   #14075
I'll run 3 degrees in rear motor but I'd never try to go with more. There are just too many other bad things going on with the suspension geometry.
Old 04-02-2014, 01:34 AM   #14076
0 degrees is fine if you have a "point and shoot" type driving style, it gives good traction but I cant drive like that so always run anti-squat, it aids maintain cornerspeed, I can apply throttle early before the car is squared up around the corner as it stops the front wheels becoming light and the car washing out wide. Also helps over bumps.
Bb
bucketboy is offline   Reply With Quote
Old 04-02-2014, 05:17 AM   #14077
13Maschine's Avatar
Anyone running the new AKA EVO style wheel on their buggy? Front or rear? both? Love em or hate em?
Old 04-02-2014, 05:52 AM   #14078
hacker's Avatar
more off power steering.
took the droop screws out, but the cvd's disagree haha
I've also seen on one of the factory guys had a prototype forward rear pivot block that seemed to give more than 3 degrees.
Old 04-02-2014, 07:24 AM   #14079
I'm not a point and shoot driver. 0 degrees is almost mandatory when running MM3 and somewhat so for MM4.
Antisquat isn't a steering aid and shouldn't be treated as such. Camber links, caster, and weight distribution are.
Old 04-02-2014, 09:19 AM   #14080
Trader Rating: 29 (100%+)
I believe you are gaining "off power steering" because with more antisquat you are loosing "off power rear traction" giving the feeling of gaining steering.
I use antisquat to fine tune the car depending on the track. On a smooth high grip I may add some antisquat. If the track is bumpy I want 0 antisquat so the shocks will do what they are suppose to do. As a rule I always start with 0 antisquat and the majority of the time I run 0 as I prefer what I call a neutral feel in the car. Also I always run 0 in a MM configuration. That's my $.02
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 04-02-2014, 09:59 AM   #14081
RC10Nick's Avatar
I don't know about you, but I ALWAYS want the shocks to do what they are supposed to do. Why have them otherwise?
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 04-02-2014, 11:31 AM   #14082
Of course everyone wants the shocks to work. What I'm saying is running a lot of anti-squat on a bumpy track causes the rear suspension to stiffen up onpower so it does not absorb the bumps as well.
Old 04-04-2014, 01:27 AM   #14083
snowman_evil's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to snowman_evil
Does anyone know what shock oil is standard in the RTR Dex210?
DEX410V3 - Tekin - Spektrum - Panther
GCRC Raceway - "Lightning"
snowman_evil is offline   Reply With Quote
Old 04-04-2014, 01:43 AM   #14084
Doughty's Avatar
should be built with 450cst shock oil and 3000cst diff oil
Chris Doughty - Team Durango - LRP - BETA Tires - Nibbo Design
Doughty is offline   Reply With Quote
Old 04-04-2014, 03:30 AM   #14085
Really? The shocks front and rear definitely feel softer then that and the diff feels like 1000cst
St Ives RC Club B4Bandit Australian Racing 16564 Today 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
