Like Tree27Likes
Old 03-23-2014, 11:29 PM   #14041
Suspended
Trader Rating: 7 (89%+)
I have a dex210v1 81 tooth spur gear 8.5 motor. What would be the best pinion for indoor track. Also how much better is the newer version dex210v2???
ohiofun13 is offline   Reply With Quote
Old 03-24-2014, 07:02 AM   #14042
Dino_D's Avatar
24T would be a good start.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 03-24-2014, 11:54 AM   #14043
Originally Posted by Dal View Post
Stock motor problem
Im running a 17.5 with 30 t pin and 75 spur, mid mount 4 gear
am getting temps at 80 degC, running it for 5 mins on road.
It is stuttering from a standing start, LRP X12, horizontal timing slot.
Any suggestions to keep it cool and why is it stuttering?
Dal I noticed tonight when I was putting mine together that the rear axles would bind when I tightened the wheels, I am using the plastic hex's as I do not have alloy ones yet but found that by putting a 5mm id shim behind the outer bearing inside the upright problem solved.
Rutters is offline   Reply With Quote
Old 03-24-2014, 12:50 PM   #14044
rcjunky1's Avatar
That also sounds under geared. I ran 35/69 at motorama with a revtech killshot and still used like 65* of timing for it to get to 140*F
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 03-24-2014, 01:48 PM   #14045
fq06's Avatar
I also am at 33-35/69 (depending on the track I'm at) with a D3.5 17.5t and temp 135 to 145 depending on pinion. Mid to max can timing blinky class.
BCE SCT410 / Hobbywing 3656sd ~ RX8.2
DEX210 / Trinity 17.5 ~ RS.2
Westcoast Raceway (R.I.P.) | SMC | PowerLab
fq06 is offline   Reply With Quote
Old 03-24-2014, 09:30 PM   #14046
CarlCrocco's Avatar
Trader Rating: 88 (100%+)
Selling a nice DEX210.
Team Durango DEX210 Roller with V2 Upgrades, Parts , Avid Slipper Clutch Custom Body
Andrew Crocco "The Hammer"
Viper R/C
XB9E XSCT
CarlCrocco is offline   Reply With Quote
Old 03-26-2014, 08:11 PM   #14047
probably a really obvious answer to this but regarding the V2 ball studs the TD site says 2mm. What's 2mm on the new studs? How are they different to the V1's?
Serpent SRX-2 MM - Tekin Redline Gen2 10.5 - Tekin RS Gen2
Serpent F110 - Tekin Redline Gen2 21.5 - Tekin RS Gen2
Spektrum DX3S
ROB784 is offline   Reply With Quote
Old 03-26-2014, 10:33 PM   #14048
ekt
ekt's Avatar
The hex of the new ballstuds is 2mm, instead of the 2.5mm of the v1 version
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 03-26-2014, 11:22 PM   #14049
rcjunky1's Avatar
but the diameter is the same, so the dimecX ballcups will still work. They're just a bit thicker around the hex for durability.
Team Durango Canada
Old 03-27-2014, 12:03 AM   #14050
Ok that's what I was concerned about, so by making the hex smaller they made them stronger.
Spektrum DX3S
Old 03-27-2014, 08:00 AM   #14051
fq06's Avatar
Got confirmation yesterday that my +8mm V2 chassis and side pods have shipped, I would guess that means the kits should be soon or are on their way out the door as well
Old 03-28-2014, 11:34 AM   #14052
Race Everything's Avatar
Does anyone have a rear brass weight they would like to sell . I would like to give one a try.
Race Everything is offline   Reply With Quote
Old 03-28-2014, 11:38 AM   #14053
Dino_D's Avatar
Are you trying to get more grip from the mid motor?
Adding weight to the suspension hanger is more effective than putting the weight in the rear. Or adding weight near the rear axle.
You can also try 4 toe and 1.5 or 0 antisquat.
Another quick trick is adding a single 7g lead automotive weight to each rear hub. That instantly give you more rear traction.
Old 03-28-2014, 11:44 AM   #14054
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
I have the used the brass hanger on the RR and It's the best way to hang weight on that end but I always say better to add weight inside the wheels if possible. Such as a brass battery stopper or brass rear FR hanger.
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 03-28-2014, 11:52 AM   #14055
Dino_D's Avatar
+1
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
