Like Tree23Likes
Old 03-11-2014, 07:41 PM   #14011
rcjunky1's Avatar
those molded diff gears are awesome, had them in my 210 with the lightweight outdrives for a super light diff for 17.5 at Motorama. I also have them in the 410 with the UJ's and it makes for much lower motor/esc temps. They're simply awesome, and reliability is no issue (I've heard of no issues yet, some team guys have had them for a year now)
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 03-12-2014, 12:15 AM   #14012
Cool Idler gear pi modification!
Hi all,
I have done a modification on my idler gear pins, that i would like to share with you!
As i had that kind of mod in my SC10 and also in my SC10 4x4, witch Associated sells as FT parts, i made some of these pins out of an 5mm aluminum rod, i bought in a garden centre for ~1$ per meter.
I had to sand the outer diameter a bit, so the bearings go easy over the shaft, but it was not a big deal and below i would like to show you the weight reduction against the steel shaft!
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 03-12-2014, 12:17 AM   #14013
Sorry, i just can upload 1 image per post with my ipad!
YZ-10 '94/'95 WCS/
Spectrum DX3R
Old 03-12-2014, 09:19 PM   #14014
Trader Rating: 14 (100%+)
Hopefully someone out there can help me with this question but I'm looking at trying to run b4 style rear wheels on my car but the stock rear plastic hubs are too tall and rub severely on the inside of the wheel. The car already has the front axles to run b4 wheels so I'm good there but was wondering if I were to use the Exotek rear hubs and or Team Durango aluminum rear hubs where the ball stud mounts straight out the top allows for extra clearance for the slightly smaller wheel that the b4 wheels are or not. Thanks
atrain1968 is offline   Reply With Quote
Old 03-13-2014, 07:44 PM   #14015
rcjunky1's Avatar
I'm going to be putting my Cream carbon fiber front tower (mounts anodized black) and STRC carbon rear tower soon, thought I'd give first dibs to those here. $50us shipped for the pair.
Team Durango Canada
Old 03-14-2014, 11:36 AM   #14016
re-do73's Avatar
I have been running the b4 pin style wheels on my durango for quite a while with no rubbing at all, just removed the stock hex and got the FT blue spacers and roll pin.
re-do73 is offline   Reply With Quote
Old 03-15-2014, 09:29 PM   #14017
Can anyone point me in the direction for a MM4 clay setup. My track tends to run golds/MC compound tires. I've got my sons RM dialed but the mid just isn't feeling right but I could be in left field on the setup as the only ones on line are for astro turf.
daveb is offline   Reply With Quote
Old 03-16-2014, 08:52 AM   #14018
Trader Rating: 29 (100%+)
http://www.petitrc.com/setup/durango...ngoDEX210.html
Scroll down past the astro setups there is the clay setups. There are MM4 from Lutz, Born, and a few more for clay.
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 03-17-2014, 09:23 AM   #14019
nissan240's Avatar
Trader Rating: 6 (88%+)
Anyone know what material TD603003 are made of?
Sponsored by myself and the good graces of my woman!
Our cars~Serpent Spyder SRX-2 RM, SRX-2 MM, SRX-2 SC, Team-C Ts2
Practice, Practice, Practice
nissan240 is offline   Reply With Quote
Old 03-17-2014, 10:02 AM   #14020
I believe they are just a steel diff ball.
Team Durango DESC 410V2,Team Durango DESC 210R
Team Durango DEX 410V5,Team Durango DEX 210V2
Mike Maniscalchi www.team-durango.com
knowitall156 is offline   Reply With Quote
Old 03-17-2014, 10:10 AM   #14021
Built my DEX210V2 kit the past few days and drove it yesterday. One word-planted. Well, three words-stable, predictable and planted. The new front arms, shock tower and shock length are a winner. Went with my previous 210 set up, added some more titanium and plastic versus aluminum to further lighten it for 17.5 class. The transmission is much easier to put in/take out, rear shock tower is beefier, rear arms allow for front and rear shock mounting etc. Great buggy.
Old 03-17-2014, 04:20 PM   #14022
Hey guys are stock springs what you recommend for dirt outdoor track hard but loose? Also does anyone use shock dust boots?
thefan is offline   Reply With Quote
Old 03-17-2014, 05:42 PM   #14023
platgof's Avatar
Has anyone tried the regular 1 inch wide front wheels on clay,or our most people staying with the skinny tire?
platgof is offline   Reply With Quote
Old 03-17-2014, 11:08 PM   #14024
Dino_D's Avatar
Stock springs are fine. On high bite you might want to go a little harder on the front spring to maintain a better corner speed.
I always use the shock boots. Makes the shock last longer. And I prefer to use the gold or tit-nitrate shafts. Once they start to fade you know its time to replace them. The stock silver ones its hard to see when they are worn. So far I raced a whole season with the boots and the shafts are still fine.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 03-19-2014, 12:18 AM   #14025
Dal
Dal's Avatar
Send a message via Yahoo to Dal
Stock motor problem
Im running a 17.5 with 30 t pin and 75 spur, mid mount 4 gear
am getting temps at 80 degC, running it for 5 mins on road.
It is stuttering from a standing start, LRP X12, horizontal timing slot.
Any suggestions to keep it cool and why is it stuttering?
Dal is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16562 Yesterday 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Speed Chaser
