Like Tree24Likes
Old 03-04-2014, 08:47 AM   #13966
Originally Posted by Dino_D View Post
(mm) 2 hole 3 hole 4 hole 5 hole 6 hole
1.0 1.571 2.356 3.142 3.927 4.712
1.1 1.901 2.851 3.801 4.752 5.702
1.2 2.262 3.393 4.524 5.655 6.786
1.3 2.655 3.982 5.309 6.637 7.964
1.4 3.079 4.618 6.158 7.697 9.236
1.5 3.534 5.301 7.069 8.836
1.6 4.021 6.032 8.042
1.7 4.540 6.809
The lower the ratio number the more pack, the higher the number is less pack
Also, given the same ratio eg. (using the same ratio of lets say 5.3 the 4x1.3 will pack more over larger jumps than 3x 1.5) More smaller holes is better on larger jumps, bigger holes are better for bumps.
Dino D thanks for this information. This table will definately be going into my setup book. Also, I used your mid motor setup on my DESC210 this weekend. I have to say it has never rotated that well before. I have a couple tweeks to make to it but qualified 3rd out of 21 in stock truck. Thanks for your help
Brandon Smith
fanfor18 is offline   Reply With Quote
Old 03-06-2014, 09:13 AM   #13967
Trader Rating: 1 (67%+)
Default Looking for m4 scrubs
Looking for m4 scrubs for the dex210. Would rather have new but if you have them mounted that's fine. Send me a message if your willing to sell them.
F1AZURE is offline   Reply With Quote
Old 03-06-2014, 03:04 PM   #13968
Trader Rating: 520 (100%+)
Shouldn't be much longer..
flame56mx is offline   Reply With Quote
Old 03-06-2014, 03:13 PM   #13969
Trader Rating: 89 (100%+)
Attachment 1174385
Teaser.... I am waiting for mine.
dan-o is offline   Reply With Quote
Old 03-06-2014, 04:38 PM   #13970
Sorry, couldn't help it..
Old 03-06-2014, 04:51 PM   #13971
Attachment 1174385
I'm expecting one of those to be sitting on my porch when I get home.
Team Durango DESC 410V2,Team Durango DESC 210R
Team Durango DEX 410V5,Team Durango DEX 210V2
Mike Maniscalchi www.team-durango.com
knowitall156 is offline   Reply With Quote
Old 03-07-2014, 04:44 AM   #13972
Cant wait for the v2
Team Durango - DNX8 - DEX8 - DEX410v4 - DEX210v2 - Alpha Lutz WE - VP PRO - Futaba - Hudy - Orion
av4625 is offline   Reply With Quote
Old 03-07-2014, 07:00 AM   #13973
I may have found a situation where MM4 works for me. Our track was just redone and the new layout is quite old school. No huge ultra super mega jumps but tons of whoops and rough sections. You only get full throttle on the front straight which is about 1/4 of the track. This is how a track should be! The layout itself is fairly simple. It is a U shape with only 180's. It is an outdoor dirt track that will pack in quite nicely over time but will retain a slick top layer of dust off line when dry. There aren't any high speed sweeping turns. In reality MM may have no advantage here which removes any MM3 cornering advantage. Then again if there is no real advantage with MM here, RM3 may be the way to go. Acceleration is needed and throttle modulation over the jumps. There are 9 consecutive jumps in the whoops section! MM4 may actually be the ticket here. At least in MM. The last layout was better for RM3 and the previous MM3. I love variety and a car that will allow me to adapt!
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 03-07-2014, 07:41 AM   #13974
Dino_D's Avatar
+1 Welcome to the 4 gear club
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 03-07-2014, 07:51 AM   #13975
I might just go back to RM3 but I'll try MM4. I've always hated it before.
Old 03-08-2014, 05:55 AM   #13976
Im trying to setup my car for dirt and carpet so i have it in mm4 and dont want to swap to rm, does more or less antisquat give better rear grip coz i have read it both ways and now im confused which way to run it, dirt track is hard but loose any tips would be great
thefan is offline   Reply With Quote
Old 03-08-2014, 06:00 AM   #13977
I had better luck with less anti-squat (0) in MM. Its going to be a tough job trying to use the same set-up on dirt and carpet, unless the dirt is the highest of bite IMO..
Old 03-08-2014, 06:51 AM   #13978
RC10Nick's Avatar
I've had better luck everywhere, in any config, with 0 anti-squat. Maybe I'm just weird like that. I've always felt it makes the car more neutral and a bit more predictable to drive.
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 03-08-2014, 06:57 AM   #13979
Yeah, 0 feels good in most cases, but a few times I have went up to 3 on our track to sacrifice a little side bite so I could get a tick more forward. We had a quick little double right out a corner, and the difference was measurable, 0 wouldn't get you over it, 3 made it easily. It really depends on what the track (grip) will let you get away with..
Old 03-08-2014, 09:16 AM   #13980
VenturaDC's Avatar
Trader Rating: 32 (100%+)
Just picked up a super clean 210 used to run mod with. A friend was telling me that amezcua won chi town in rear motor? Anyone know where that setup might be posted?
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
