Like Tree24Likes
Old 03-03-2014, 03:37 PM   #13951
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
@Fred: Thank you for your input I'm not sure I agree with you however. Motor placement makes a huge difference in the application of it's torque. I think that the "in air" control is important in off road. This was the change I was looking for when switching to MM4 as well as increasing forward traction. You can't bring the nose down with brakes in the air with MM3 or RM4. The torque of the motor will also be fighting the natural weight transfer to the front end of the car upon braking as well as fighting the inertia of the wheels.
Here's what Durango has to say on the subject:
http://www.team-durango.com/blog/201...onfigurations/
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 03-03-2014, 05:04 PM   #13952
I bought my durango to run on carpet but if i wanted to run it mm4 on dirt what setup would work for hard packed dusty track?
thefan is offline   Reply With Quote
Old 03-03-2014, 05:15 PM   #13953
Nothing Durango says disagrees with me. Well, except for the fact that they don't know how to make MM work on anything other than high bite of course.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 03-03-2014, 05:18 PM   #13954
13Maschine's Avatar
Gosh I hope there's some humour I seem to be missing in here somewhere. bleh.
Old 03-03-2014, 05:24 PM   #13955
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
What would you guys use for gearing on a outdoor track with about a 90ft straight. Its my dads car and it will have a traxxas velenion motor in it, so no boost or anything. It has the stock spur as well, Thanks.
Blitzrockey is offline   Reply With Quote
Old 03-03-2014, 06:06 PM   #13956
Fredswain I need some help. I am currently running 1.6x3 pistons front and back with 35wt front and 30wt reat. I am having an issue with the chassis slapping the ground on larger jumps. I am thinking about going to 1.6x2 pistion with 30 wt front and 1.7x2 25wt in rear. Am I going the correct direction. Also, I am running (hate to tell you this. LOL) MM4.
Brandon Smith
fanfor18 is offline   Reply With Quote
Old 03-03-2014, 06:28 PM   #13957
Yes there was a bit of sarcasm in that post.
I'd try the 2 x 1.3's in back with the 2 x 1.2's in front. Each will give you more pack than the 3 hole you are running so yes you are headed in the right direction.
Most people run MM4 so I can't call it wrong. I just personally don't like it. It is conceivable that I'll give it a try again someday but I have no desire to right now.
Old 03-03-2014, 06:34 PM   #13958
Brandon Smith
Old 03-03-2014, 06:44 PM   #13959
I meant 1.6 and 1.7 not 1.2 and 1.3. Sorry for the confusion.
Old 03-03-2014, 08:57 PM   #13960
Originally Posted by ekt View Post
The +8mm chassis, new side pods, front/rear arms, shock towers, front shock bodies/shafts and LRC RR suspension mount would be the main performance changing things that I can think of.
There are also a few type B parts that offer more tuning, easier maintenance or durability increases too.
I got the +8 type b plastic chassis so just need the other bits.
KarlB is offline   Reply With Quote
Old 03-03-2014, 09:49 PM   #13961
ekt
ekt's Avatar
The v2 comes with an aluminium +8 chassis
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 03-04-2014, 03:32 AM   #13962
Trader Rating: 89 (100%+)
Fred - you are not alone...mm is not for me either, maybe someday when I have hours and hours to spend by the track. But right now the rm3 is solid for me.
dan-o is offline   Reply With Quote
Old 03-04-2014, 06:53 AM   #13963
I like mid motor just fine. I prefer it. I just don't like the 4 gear setup. I like 3 gear better but even it is a compromise. They both are. I just find that MM3 has less of them. I personally would prefer a layout like the Team C TM2. I go back to that car a lot since it's the only one laid out that way. It makes way too much sense to me. I may pick one up a some point but I'll probably end up building a similar car out of either Associated or Durango parts.
Old 03-04-2014, 07:12 AM   #13964
rcjunky1's Avatar
a UK company called cobra racing products makes a chassis to run a 210 front with the 410 back called the 4210 and a different UK company makes the bodies. Works out to about $80 then you just need a battery strap and stand offs. I'm tempted to get one once they are caught up and have international shipping figured out.
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 03-04-2014, 07:41 AM   #13965
Dino_D's Avatar
(mm) 2 hole 3 hole 4 hole 5 hole 6 hole
1.0 1.571 2.356 3.142 3.927 4.712
1.1 1.901 2.851 3.801 4.752 5.702
1.2 2.262 3.393 4.524 5.655 6.786
1.3 2.655 3.982 5.309 6.637 7.964
1.4 3.079 4.618 6.158 7.697 9.236
1.5 3.534 5.301 7.069 8.836
1.6 4.021 6.032 8.042
1.7 4.540 6.809
The lower the ratio number the more pack, the higher the number is less pack
Also, given the same ratio eg. (using the same ratio of lets say 5.3 the 4x1.3 will pack more over larger jumps than 3x 1.5) More smaller holes is better on larger jumps, bigger holes are better for bumps.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
