Like Tree23Likes
Old 02-22-2014, 09:08 PM   #13861
Originally Posted by Walkman View Post
I see you used my old setup from Petitrc. The link is to my current setup. I have not experienced traction roll with it at all. With the Staggers on you get just a little slide before it hooks at the end of the straight then it hooks up and your gone.https://dl.dropboxusercontent.com/u/...2014_setup.pdf
Thanks, do i need to glue the sidewalls on the staggers and also on the rear mini pins?
thefan is offline   Reply With Quote
Old 02-22-2014, 09:17 PM   #13862
Trader Rating: 29 (100%+)
If its the low profile staggers no, if not low profile its up to you but i don't really see the need.
I glued the side walls when I ran dboots Nanobytes on the front and that worked really good. I have never glued the sidewall on rears.
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 02-24-2014, 01:12 PM   #13863
The problem is all the carbon fiber chassis break at the kick up. This is why Exotek makes a aluminum nose for the carbon fiber chassis. Now I had the 8 Racing +8 carbon chassis and I absolutely loved it up until the nose snapped off.
I'm pretty bummed about this. Wish I would have known sooner before dishing out 150.00 on a 8 Racing +8 CF chassis. Chassis had 3 runs on it -- I came short of clearing a small double jump and snapped it. All done.
I am thinking of going Exotek +8 chassis due to the innovative and reinforced front nose area. I feel this is where the 8 Racing chassis fell short in the durability department. Any reviews out there on this chassis? Sure looks like a winner.
All this raving about longer chassis may have gotten the best of me. I race at a small indoor clay track and may benefit from the original shorter stock chassis anyways. I never gave it a chance. I just wish they would make a standard length aluminum chassis that flexed a little bit more in the right areas.
Vincent_Diesel is offline   Reply With Quote
Old 02-24-2014, 01:35 PM   #13864
Dino_D's Avatar
You could have picked up a dimec +8 chassis for indoors. It's pretty cheap, or you can wait a little longer and get the +8 aluminum chassis that comes on the v2.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 02-24-2014, 01:44 PM   #13865
EbbTide's Avatar
Trader Rating: 32 (100%+)
+1 on the plastic +8mm Dimec chassis. It may not have the same bling or sitffness as CF or aluminum, but is still lightweight and so far has taken countless nose-first crashes without chassis breakage.
::: Tekno EB48SL ::: HPI Blitz ::: Kyosho RB5 SP2 WC :::Team Durango DEX210 v2 ::: Team Durango ExoDex210 :::Tamiya TB03r/TRF418-ish :::
EbbTide is offline   Reply With Quote
Old 02-24-2014, 06:09 PM   #13866
Thanks for the tips. I will try the Dimec +8 chassis after I give the stock alloy chassis a fair chance for our small track. I figure shorter wheelbase will help rotation.
Old 02-25-2014, 05:36 PM   #13867
psl
Default Dimec+8
Does anybody have a good starting set up for the Dimec+8 chassis? Right now the rear of my buggy is real loose coming out of the corners and has a bad push. Does anyone use any added weights when using this chassis? I am using 4 hole pistons 1.4 hole size. Shock oil is 35 front and 30 rear, using Associated shock oil. ESC is mounted in the rear of the battery tray. Shorty battery pack is right after ESC, middle of buggy.
Durango DESC 410v2 4wd SC
Durango DEX 210 Exotek MM
Durango DEX 410v5
Kyosho SC6
Radiopost
psl is offline   Reply With Quote
Old 02-25-2014, 05:46 PM   #13868
EbbTide's Avatar
I'm running 30wt in the front and rear shocks with the white -series yellow springs in the rear and stock springs up front. that seems to give me plenty of grip for our clay track. The pushing however, I had to use about 50 grams of weight toward the front, plus losing the servo saver to get my steering how I like it. And also, push the shorty as far forward as you can. I run mine just behind the servo.
Old 02-25-2014, 06:29 PM   #13869
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
Thumbs up
Hey Vince…I've done some testing back and fourth with different chassis lengths and the shorter alum chassis or regular length dimec chassis (I like the alum) does seem better on the smaller tracks. I do plan to upgrade to the V2 probably this summer but if I was racing on a smaller track all the time I might still try the shorter original chassis. It all depends on how many option parts you wanna have lying around. Changing a chassis is a lot of work as usually this means new wires and remounting the electronics.
I'm currently testing the +11 from RDRP. I'll let you know what I think about it on a small indoor track as that's where I'm headed on saturday.
PS, I have an original alum chassis if you need it. PM me if you do.
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 02-26-2014, 08:11 AM   #13870
Dino_D's Avatar
+1
my setup is similar. But a little lighter. 27wt front, 25wt rear. You can try using 1.5x3 pistons. 3 antisquat, Stock Light blues front and rear and running +8 dimec with 42g up front, shorty battery forward, running RM4, and no servo saver.
If the track is really bumpy, sometimes I prefer the TLR low frequency springs instead, as it seems to glide over the bumps better.
If you need the grip, try running RM4, and 4 toe, and 3 antisquat. That will give you the most grip out of the corners. You will need to run softer springs and add weight in the front to stop the push. Or you can try moving 1 shim in front of the caster block with 3 shims in the rear. That generally gives you lots of steering.
Old 02-26-2014, 08:16 AM   #13871
Thank you that would be super helpful 13. I'd love to hear about your progress.
As I mentioned before the "extended chassis" craze hit and the owners of DEXs in our area rushed out to get one -- including myself. Soon everybody had +8s, +10s and now +11s running in our relatively small track. It didn't make sense to me at the time to go longer. Once I put one on I wasn't blow away by the results, although I didn't give it enough time since my 8 Racing +8 chassis broke on me. REALLY UPSET. First impression was that it was stable as y'all seem to claim but it sure felt like driving a limousine on our smallish track. The rear traction had seemed to have diminished and could not rotate into turns. I thought to myself this isn't how a buggy should feel, c'mon this is supposed to be a surgical knife as opposed to a steak knife -- bad analogy but you get the point.
So for now the original aluminum is back on. Standard length and still brand new : ) And thanks for the offer -- I love this forum.
Stay tuned.
Old 02-26-2014, 08:36 AM   #13872
13Maschine's Avatar
awesome Vince. Glad to have you. I'll let you know about my testing after this weekend.
I realized later you probably still had your alum…..I ran that quite a bit on the small track and it was pretty wicked. I run mid motor as most of my favorite tracks here in SoCal are clay and high bite. We run slicks sometimes. Or Barcodes, and Ions. So you get the idea of what kinda of surface it is. OCRC from the Reedy race is one of my tracks. I've even run the original chassis at OCRC and with a good balanced setup (see fredswain! ) it's pretty dialed. I'm also running a shorty pack.
Are you also mid motor?
Old 02-26-2014, 08:40 AM   #13873
13Maschine's Avatar
@Vince: Have you also messed with the wheelbase via changing spacers in the front and rear hubs? This is a bit finer adjustment but moving the back around a bit can get more weight over the axles or less.
Old 02-26-2014, 08:48 AM   #13874
All of your setups are jacked. You should never be running a heavier oil in front than rear. Your pack is uneven if you are.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 02-26-2014, 08:53 AM   #13875
fq06's Avatar
Wouldn't you have more pack in the rear with the same pistons and oil front to rear because of the longer shock in the rear traveling faster than the front for the same travel?
I would think that with the same pistons you would have to be lighter in the rear or go with bigger holes in the rear with the same oil f&r.
BCE SCT410 / Hobbywing 3656sd ~ RX8.2
DEX210 / Trinity 17.5 ~ RS.2
Westcoast Raceway (R.I.P.) | SMC | PowerLab
fq06 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
