Like Tree27Likes
Old 02-21-2014, 08:50 AM   #13831
So i had my first race ever on the dex210 and it was on carpet i used a setup from petit under the name Matt which is very similar to just about all other carpet setups i had read, anyway i could not stop the traction rolling i put the stock springs back in and it was better but still no fun to drive with the slow corner speed i had to use to avoid rolling over, i have since read about tire prep about gluing the outside tirewall and sanding the outer edge pins off do you think that alone will solve my traction rolling issues or is there any setup changes that will help? i was using scrubs on front holeshot2 rear
thefan is offline   Reply With Quote
Old 02-21-2014, 08:52 AM   #13832
tbaybucs's Avatar
Send a message via ICQ to tbaybucs Send a message via AIM to tbaybucs Send a message via MSN to tbaybucs
Swaybars ?
Serpent ~ Viper Esc's ~ Savox ~ Trinity Motors ~ Futaba ~ Jconcepts ~ Hakko ~ Dialed-Rc ~
VRC-Pro ~ protek ~ ip batteries ~ Revolectrix Charger
tbaybucs is offline   Reply With Quote
Old 02-21-2014, 09:10 AM   #13833
His setup was running on slicks. If you've got more grip, you'll flip. Hey, that rhymes!
I honestly don't know how his car drives but just by looking at his setup sheet I can tell I'd hate it. First, and this is a HUGE red flag to me, if the front shocks have more total piston hole area and the front oil weight is higher than the rear, it's crap. This is a very VERY common mistake. Even most pros make it. It is the result of a misunderstanding of how pack relates to piston speed and shock length.
He is clearly trying to run a very low roll center in the front with a higher roll center in the rear. He is running a shorty battery all the way back. With more weight rearwards, he is going to need more roll stiffness but there is a neat phenomenon with the greater front nose kick of 2wd cars that once you get too soft in the suspension, the front will unload on power out of corners no matter what. For carpet, grip isn't lacking. You are proving that with traction rolling.
I'd shift the battery all the way forwards and change to MM3. Run 0 rear kick. Move the front outer hole camber link location to #2. Leave the back alone. Reverse his pistons front to rear. You want the larger holes in back. Adjust the oil accordingly. You will need to balance the spring rates and shock oils. See the tuning with camber links thread for info. Reduce the front caster to 20 degrees. I have no idea why anyone would ever run 30 degrees except on loose dirt with inline steering. That's the only time.
That should get you closer but you'll still need to fine tune things.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 02-21-2014, 09:43 AM   #13834
EbbTide's Avatar
Trader Rating: 35 (100%+)
The fact that the V2 is announced officially on their site isn't much of a thing considering how long it will most likely take for people to get kits. Not to mention spare parts... yes I'm still on about it.
::: Tekno EB48SL ::: HPI Blitz ::: Kyosho RB5 SP2 WC :::Team Durango DEX210 v2 ::: Team Durango ExoDex210 :::Tamiya TB03r/TRF418-ish :::
EbbTide is offline   Reply With Quote
Old 02-21-2014, 10:17 AM   #13835
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
Originally Posted by fq06 View Post
Question... I have a lot of weight up front with RM and really like how it is handling and have got to where I have zero washers under the front inner camber links.
My question is, am I risking the ball stud tweaking over to the side and buggering things up? Or has anyone else run the inner links without the wide washer in there?
I wouldn't mind going to 0.5mm washer, but all I have found was a smaller washer that's the same circumference as the base of the ball stud so that's not doing anything for me. Is there a wide 0.5mm washer to space the camber links and give it a wider footprint with?
Couldn't you use these?
http://www.team-durango.com/part-inf...artNo=TD709043
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 02-21-2014, 10:19 AM   #13836
13Maschine's Avatar
@fq06
Hope you can see the washer under my ball stud….
I haven't tried running with no shim….might be ok. I've done it with other cars. I'll try it on mine on Saturday…
PS I invited you out to SCVRC….
Dave
Old 02-21-2014, 10:38 AM   #13837
I'm going to guess late March for all the distributors to have them.
By the way I weighed my buggy last night and it was 1,611 grams with wheels and tires and the body on. Dimec chassis, shorty pack, all plastic spacers and hubs, standard servo, stock turnbuckles, aluminum cvd's.
When I build my V2 I will get it into 1520-1550 range with titanium turnbuckles, screws, a lighter battery and lighter wheels.
Team Durango DESC 410V2,Team Durango DESC 210R
Team Durango DEX 410V5,Team Durango DEX 210V2
Mike Maniscalchi www.team-durango.com
knowitall156 is offline   Reply With Quote
Old 02-21-2014, 10:44 AM   #13838
13Maschine's Avatar
Smile
Originally Posted by fredswain View Post
I like the changes. At first I didn't see the point but now that I see a direct comparison I understand them. I think the standard 210 is a great car but the V2 is going to be nicer. I "might" be able to tolerate the body (at night, with my eyes closed) if a big fin is added from the back of the cab to the shock tower like on LeMans or older F1 cars.
Hey Fred….I know you hate cab forward bodies, but how do you feel about the JConcepts finisher? I hate most cab forward designs as well and I have really grown to like the JC Finisher….Here's mine… I can do a full side view too if you like. This is before I mounted the +11 chassis, which the body still fits pretty well. I"ll post comparisons if anyone wants to see.
Don't worry fred if you don't like it! I won't let my feelings get hurt :P
Cheers and happy friday!
Dave
Old 02-21-2014, 10:57 AM   #13839
EbbTide's Avatar
That is quite promising man. I think I should be in the sub-1600 gram range with my titanium turnbuckles at the moment. Only just though.
As for parts, Tower still says early april for the spare parts, and mid-march for the kit itself.
Old 02-21-2014, 11:19 AM   #13840
13Maschine's Avatar
are you guys running stock class ? is that why you want to lighten the car as much as possible?
I like to run mod so I usually opt for more durable parts. Steel drive shafts, and steel diff hubs etc. I have the alum hubs now too. I've found they keep the bearings in better alignment so they tend to last longer. Only time will tell. I will try to weigh them in comparison to the plastic so we have a reference point.
Thanks for sharing…
Dave
Old 02-21-2014, 11:32 AM   #13841
EbbTide's Avatar
Thanks for sharing…
Dave
I run stock 17.5 class so I am trying to lighten my car as much as possible with the stock weight being so hefty. And I like running aluminum hubs and shock parts so I have to shed weight in other areas to make up for it.
It's a never ending battle lol. Right now I'm pricing out titanium screws for the rear end of the car to even out the weight a bit more. It's burning a hole in my pocket, but I love this little car.
Old 02-21-2014, 12:09 PM   #13842
fq06's Avatar
@fq06
Dave
Yeah, that's it. Thanx.
That may move RC more than I want so I may be going back to no washer but I guess worst case is I have to buy a new tower if I wreck and tear up that hole. I will try it though, I would think having that extra width would help distribute the side load in a crash. I did run t like that for the last few hours of a practice day and no issues but I didn't really have a good wreck to know.
Don't ruin your tower for me
Thanx for the B-Day at the track invite! I will be making that... and probably racing the next day.
BCE SCT410 / Hobbywing 3656sd ~ RX8.2
DEX210 / Trinity 17.5 ~ RS.2
Westcoast Raceway (R.I.P.) | SMC | PowerLab
fq06 is offline   Reply With Quote
Old 02-21-2014, 12:18 PM   #13843
13Maschine's Avatar
Plastic towers are cheap! and you are welcome!
I bet you could find a washer that was like .25, or just use the small black durango washers. I think they are less than .5 mm. I will measure.
Old 02-21-2014, 12:19 PM   #13844
13Maschine's Avatar
seems the durango small black washers are .55mm
Old 02-21-2014, 12:22 PM   #13845
Thanks for sharing…
Dave
The mod class has all but disappeared at our track and there are 18-20 Blinky 17.5 buggies each week shooting for a spot in the 11 car A main. It is not uncommon for 1st through 10th to finish on the same lap after 8 minutes separated by a few tenths each buggy. It's nuts, so lightening up the buggy as much as possible makes a big difference.
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
