Like Tree23Likes
Old 10-30-2011, 11:18 PM   #1366
old-man's Avatar
Originally Posted by x7tristan View Post
The manual is wrong, I followed the manual and my diff unscrewed itself when you held one wheel. All other classic RM3 have the NUT on the spur side
You might have the trust washers installed incorrectly.
old-man is offline   Reply With Quote
Old 10-31-2011, 03:25 AM   #1367
Bman's 3XNT's Avatar
Trader Rating: 70 (100%+)
O.k I have the adjustment side on the spur side (RM3)and the dogbone hits the plastic locknut on the left side now when i compress the suspension(plunge). It binds almost like it isn't in far enough. Diff is built right, nice and smooth and the diff gear does not spin when I hold the outdrives. Anyone else find this? Please let me know your thoughts,Thanks......
Team Durango DEX410 w/3 Diffs ;) The original
Xray Xb2 CE
www.rchr.biz------www.Wolcotthobby.com
Bman's 3XNT is offline   Reply With Quote
Old 10-31-2011, 03:55 AM   #1368
TeamDurango's Avatar
Have you got a photo of the setup? There shouldn't be enough plunge to hit the nut if the diff is correctly tightened.
Team Durango
TeamDurango is offline   Reply With Quote
Old 10-31-2011, 04:30 AM   #1369
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 39 (100%+)
I spent the day yesterday cobbling together a RB5 to run for the next little bit until the next shipment of dex 210's hit the states
*Vandal 4wd Late model*XXX-T sprinter*Micro scale specialties 1/24 'rock monster' crawler*MSS Micro-Rail*MSS Micro-Funny*MSS Micro-Outlaw*
2wdMod is offline   Reply With Quote
Old 10-31-2011, 06:19 AM   #1370
Jmuck69's Avatar
Has anyone tried the other springs available or are the kit springs on the money?
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 10-31-2011, 06:32 AM   #1371
onekiwi's Avatar
Losi 22 spring fit fine and are not far off the dex compression rates
onekiwi is offline   Reply With Quote
Old 10-31-2011, 08:03 AM   #1372
Bri from Chi's Avatar
I used the kit springs with Randy's set up from page 81 on this thread and they were awesome. The only part of the set up I didn't have at the time was the 4 hole pistons. When I put them on, the car pushed kinda bad. First I tried some front camber adjustments and ride height lowering to get my steering back. Helped a little. Then I went down one spring rate. (dark green) Helped a little more, but still not quite right so I think I'm gonna put the original pistons back on because I feel like I'm getting too far off of the set up and just "band aiding" the piston change.
Short version...Yes, the kit springs are good!
Team Durango**Hobbico**Futaba**Trak Power
Leisure Hours Raceway-Joliet, IL www.Leisurehoursraceway.com
*****ELECTRIC FOREVER*****
Bri from Chi is offline   Reply With Quote
Old 10-31-2011, 08:07 AM   #1373
Jmuck69's Avatar
I was just assesing if I needed to purchase additional springs immediately. I like to have one stiffer and one softer spring than stock.
B6D | B64D
Old 10-31-2011, 08:17 AM   #1374
Matt Howard's Avatar
kit springs are usable, I went one rate softer in front and slightly stiffer in the rear but that's just me.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-31-2011, 09:03 AM   #1375
x7tristan's Avatar
whats the proper order of the thrust assembly, given that the two raced washers are different sizes?
TJ
DURANGO DESC410R
x7tristan is offline   Reply With Quote
Old 10-31-2011, 09:26 AM   #1376
onekiwi's Avatar
outdrive *smaller washer *thrust balls *larger washer
Old 10-31-2011, 09:45 AM   #1377
hopsing's Avatar
Trader Rating: 13 (93%+)
Are the two thrust washers actually a different diameter? And how much of a difference? I put all mine together with no issues not knowing they are/were? The instructions dont specify different sizes and in the 1:1 pic they are the same as well. The only way I can see you "putting them in wrong" is if it affected the fit in the outdrive, in which case the snap ring shouldnt fit. Otherwise, having one washer or the other in place of each other shouldnt change how the thrust works.
The diff nut should be on the "left" or "drivers side" of the car in RM configuration with the adjusting screw on the "right" side. My axle does not hit the diff nut either.....
The 210's diff is NOT assembled like a "traditional" ball diff, so if someone tries doing it without (or not really paying attention) to the instructions then I imagine it wont work like it should. One example is the washer that gets sandwiched between the two small bearings in the center of the diff.
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 10-31-2011, 09:49 AM   #1378
x7tristan's Avatar
ok thanks. And how tight should the screw/nut be? How do I know when to stop trying to tighten the assembly?
TJ
DURANGO DESC410R
Old 10-31-2011, 09:56 AM   #1379
onekiwi's Avatar
one is about .3 mm larger not a huge difference but with the larger one pressing on the c clip it might make a difference.
Stop screwing when you get tired.... sorry, check out the diff built and run in vids here on the foum, under the stickies I think I saw it.
I tighten mine till you can hold the 2 outdrives with tools and not turn the gear.
Then maybe a 1/4 more but that you can do when you are running it in.
There will always be a few adjustments you need to do as in running it in and how you like yours set to your track.
Old 10-31-2011, 10:14 AM   #1380
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Guys I too am confused as to how you're assembling the diff and trans with problems. The diff is easy to assemble if you follow the instructions.
The only way you could incorrectly assemble the thrust is to not have the race side facing the thrust balls. Even if the washers are different thickness's which I don't believe they are this would not change the overall size of the thrust assembly. The thrust retaining clip should slide right into place as long as the assembly is fully seated.
A standard trick when assembling the diff is to take a pair of pliers and compress the diff spring a few times. This will quicken the break in time and lessen the chance of having a diff that is initially too loose.
Your rear dog bone should be no where near hitting the adjustment screw. If this is the case you've put the diff together wrong. Again make sure you're putting the diff screw in the out drive with the female end. The spring and thrust nut go into the male ended out drive.
The only thing I've seen a few guys miss is the single thin shim between the two inner bearings.
The way I preset my diff is to tighten it fully in small amounts while working the diff a bit. This will prevent any chance of flat spotting the balls. Back it off 1/3 of a turn and use 2 allen wrenches to make sure I can't slip it by hand. Install.
To break it in make 100% sure your slipper is loose! Hold one tire on the ground and work the throttle at low speeds for say 5-10 seconds. Repeat on the other side. Tighten up the slipper and make sure your diff doesn't bark at all.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,KoPropUSA,JConcepts,Avid RC,MIP,SikLidz,ImagineItGraphx, FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
