Like Tree27Likes
Old 02-16-2014, 10:08 AM   #13756
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
Also, what bladders are we using in the Durango Fat Shocks? I've seen a Tresrey kit...
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 02-16-2014, 10:10 AM   #13757
13Maschine's Avatar
Here's one I found as we'll:
http://www.tsrproducts.com/index.php...074-desc.html/
Old 02-16-2014, 10:52 AM   #13758
RCNYWOLFTEAM's Avatar
what shock oil can i use for a desc210r kit to begin
Carlos C.
l (718-951-2500) Brooklynhobbies.com l
l (347-529-3862) LS Auto Body & Repair Shop l
RCNYWOLFTEAM is offline   Reply With Quote
Old 02-16-2014, 10:57 AM   #13759
Speedo711's Avatar
13mashine.......i dont run bladders.
what is the the advantage of bladders?
Team Durango DEX210-Novak-Promatch Racing-Mid Motor
Team Durango DEST210-Trackstar-Novak-Promatch
E Olsen
Speedo711 is offline   Reply With Quote
Old 02-16-2014, 11:33 AM   #13760
Help Again What Shock Oil For A DESC210R Thats Common On Clay Track That Need To Run Slicks On Med-High Traction
Carlos C.
Old 02-16-2014, 06:48 PM   #13761
EbbTide's Avatar
Trader Rating: 35 (100%+)
I run 30wt in front for my SC. But I am running an HPI Blitz. You may want to check the DESC210 thread for some setup tips or check out Team Durango's setup sheets. They do work. I used one of Lutz's setups for med/high bite as a base and did the minor adjustments as I drove it.
::: Tekno EB48SL ::: HPI Blitz ::: Kyosho RB5 SP2 WC :::Team Durango DEX210 v2 ::: Team Durango ExoDex210 :::Tamiya TB03r/TRF418-ish :::
EbbTide is online now   Reply With Quote
Old 02-16-2014, 06:50 PM   #13762
thanks
Carlos C.
Old 02-16-2014, 08:20 PM   #13763
I run Losi bladders in mine.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 02-16-2014, 09:05 PM   #13764
13Maschine's Avatar
Thanks Fred….are you using just bladders or also foam?
@speedo711: Bladders help keep air from getting into your shock oil and give you more consistent action.
Old 02-16-2014, 09:08 PM   #13765
Speedo711's Avatar
Originally Posted by flame56mx View Post
They are not a direct bolt on, the B4 uses smaller inner pins, so using them requires some work..
So today i went to practice at my local track and i bought a set of B4 front arms......i had to dremel out the area around the inner hinge pins and the slot where the shock ball end goes into the shock. i also had to drill the hinge pin holes larger.....over all it took me 20 minutes to get them working on the car.... other than that they have the same dimensions "length, width"
After a day of testing i was amazed. THEY WORK BETTER then the stock gullwing arms. They seem less twitchy in the center of the steering travel but they still have the same amount of steering. Over all it just felt smoother....i wonder if the new "v2' durango arms will feel the same.
E Olsen
Old 02-17-2014, 06:50 AM   #13766
The problem is that you did more than just change from a gullwing arm to a straight arm. You also changed the angle of the shocks. I know you probably didn't move them on the tower but a gullwing arm mounts the bottom of the shock lower. This means that if you drew a line from the shock bottom to the inner hinge pin, you'd have more of an angle with the gullwing arm at full travel than you would the straight arm. In order to get the straight arm to have the same effective leverage over the shock, you'd have to move the top of the shock outwards on the tower. This is why the B5 and B5M have different towers for each arm setup. You may have changed only the arms but you didn't only change one thing.
Old 02-17-2014, 09:05 AM   #13767
Speedo711's Avatar
that is probably true. But i tried all the shock positions with the stock arms and they never felt like this........i was not saying anything in particular made them better.....i was just saying they felt better.
E Olsen
Old 02-17-2014, 03:17 PM   #13768
rregl0612's Avatar
Trader Rating: 33 (100%+)
So I have a few questions, I'm not new to rc, raced just about every class, but mainly was a 1/8 buggy guy, I have a few questions regarding the rango,
In the beginning it seemed parts support was hard, has this gotten better since they have a larger distributor now?
I'm really not a losi, or associated fan. The cars do win but there molds and parts suck! I always ran X-ray, n Mugen 1/8. My reasons for looking at buggy are to have the ability of picking up a car I put down a month ago and it still be the same. And locally 1/8 is 45+ minutes away, just don't want the travel anymore. It's just something to have fun with on any given Sunday.
All of that said at its price point this is my favorite car, the parts availability just being the clencher, as I'm used to mail order that's not such a deal breaker, but if the online vendors aren't well supplied, well that could be a different story?
Also if someone could touch on differences between the original car and the V2 I would greatly appreciate it
Thanks to my sponsors, My Wallet, endorsed by Some crazy pharmaceutical corporation!!!
Member of "The White Wheel Mafia!"
Bumps and Jumps, Pitstop Hobbies, LCRC!
rregl0612 is offline   Reply With Quote
Old 02-17-2014, 09:18 PM   #13769
T-BirdJunkie's Avatar
Location: Norwood, OH...and CCRCR and The OhioRCFactory
Send a message via AIM to T-BirdJunkie Send a message via MSN to T-BirdJunkie
rregl0612, wait for the v2. They basically fixed all my gripes with the old car (time consuming transmission service, stupid gullwing arms that dig into the track)...if only they were going to release a DEST210V2.
The diff in the 210 likes to be tighter than the AE or old Losi ball diffs I've run, but that's pretty much it. It's a beautiful car that builds beautifully and it doesn't slop out like the Losi or AE cars. I've got stacks and stacks of spares that I've had for almost 2 years that I haven't needed (JUST replaced my arms; never broke one, the bottoms were just scraped up, just upgraded my shock towers to CF despite never breaking them).
I have a V2 on preorder and it should be even better. I love the car, but it rewards somebody that's not afraid to tinker and tune; it is not for the people who say I'M GONNA FIND THIS SETUP ONLINE AND RUN ONLY THAT.
If you don't allow yourself to make mistakes, you'll never allow yourself to succeed
T-BirdJunkie is offline   Reply With Quote
Old 02-17-2014, 10:15 PM   #13770
rc_dude's Avatar
Trader Rating: 130 (100%+)
So, speaking from an engineering point of view, what exactly is the purpose of the 3 vs 4 gear transmission?
It obviously changes the direction of rotation from the motor to the wheels but that's really the only use I can see for it.
If someone has a technical/theoretical explanation, I would love that lol
Engineering is my passion.
Team Durango ET48.3, EB48SL, & DEX408v2
One of a kind vehicle in progress
rc_dude is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
