Like Tree23Likes
Old 02-15-2014, 10:42 AM   #13741
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
Smile
Originally Posted by Dino_D View Post
Why do you need the rear weight? More grip? Adding weight in the back will make the rear swing more. Are you running RM or MM. If RM,, try RM4. if MM4, then I suggest you add 7g lead weight to each rear hub. Its way better to get grip from there than from the back. Just attach it with a double sided sticky
I've tried running a few different kinds of rear weights, the brass rear suspension block and also the 50 gram bolt on. Mostly it just makes the rear end swing around like a pendulum. That being said If I was to add weight to the car, I would place it in between the wheels. Or inside the wheelbase as they say. I like using brass battery blocks for this as it keeps it really close to CG but gives you a bit of bias in the front or back. You can make them easily with a dremel tool or buy the aftermarket versions.
As Dino D said….Chances are you will have much greater success by working on your setup to improve your rear traction. Have you read through the Fred Swain tune with Camber links thread yet? It's probably one of the best tuning methods I've seen to date and Fred is there still answering questions after 3 years. Having a balanced car with the right tires makes all the difference in the world.
Let us know what your setup is like and we'll try to help!
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 02-15-2014, 12:49 PM   #13742
Speedo711's Avatar
Originally Posted by Speedo711 View Post
On a different topic, has anyone tried the b4 a-arms on the dex210? I have heard of people running the durango ones on the b4/ b4.2 and i was wondering if it would work the other way around. I wondered because the dex210 v2 has straight arms......
another thing i noticed was that the early prototype dex210's used b4 a-arms
Anyone?
Team Durango DEX210-Novak-Promatch Racing-Mid Motor
Team Durango DEST210-Trackstar-Novak-Promatch
E Olsen
Speedo711 is offline   Reply With Quote
Old 02-15-2014, 01:05 PM   #13743
13Maschine's Avatar
May I ask why you want to do this? Durango will have two sets of arms for the DEX210 once the V2 arms are available…(maybe they are now). What don't you like about the stock arms?
Thanks!
Old 02-15-2014, 01:13 PM   #13744
Speedo711's Avatar
i was wondering because AE arms are easily available. If i broke my durango ones and had no spares i could easily find a set for the b4 and my track, i would have to order ones for my durango. I might just have to buy a set of b4 arms and try it out.
E Olsen
Old 02-15-2014, 01:14 PM   #13745
13Maschine's Avatar
maybe a local will let you borrow a set to see if they fit? Where do you race??
Old 02-15-2014, 01:15 PM   #13746
13Maschine's Avatar
PS, I totally understand. Durango is NOT the most popular around california.
Old 02-15-2014, 01:17 PM   #13747
Speedo711's Avatar
i race at Mikes Rc World in Washington.....160+ entries a race...i should be able to find someone with a extra set of AE arms
E Olsen
Old 02-15-2014, 01:18 PM   #13748
Trader Rating: 520 (100%+)
They are not a direct bolt on, the B4 uses smaller inner pins, so using them requires some work..
flame56mx is offline   Reply With Quote
Old 02-15-2014, 01:19 PM   #13749
B4 arms would have to be modified to fit. The hinge pin holes would have to be enlarged a little. The Durango arm mount would have to be shaved to let the arms fit. The B4 arms are also much weaker.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 02-15-2014, 03:43 PM   #13750
EbbTide's Avatar
Trader Rating: 32 (100%+)
This may not be useful to many but to some with gear diffs, instead of using the plastic diff gears to lighten things up, just use one less set of spider-gears and one less cross-shaft. Or of course go with a ball diff. I like my gears though :-) I saw no difference in grip with the same weight oil going to a two spider-gear setup. Maybe the diff will wear quicker? Wouldn't know from how well it drove today. Oh yes, i did, I FINALLY got it on the track. Great way to spend a Saturday when the Durango is working as it should. :-)
::: Tekno EB48SL ::: HPI Blitz ::: Kyosho RB5 SP2 WC :::Team Durango DEX210 v2 ::: Team Durango ExoDex210 :::Tamiya TB03r/TRF418-ish :::
EbbTide is online now   Reply With Quote
Old 02-15-2014, 04:27 PM   #13751
ekt
ekt's Avatar
Even with all 4 gears the gear diff is lighter than the ball diff
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 02-15-2014, 04:52 PM   #13752
EbbTide's Avatar
Shut the front door seriously? I was wrong about ball diffs I guess.
Old 02-16-2014, 09:04 AM   #13753
Speedo711's Avatar
have you gotten it to work?
E Olsen
Old 02-16-2014, 10:02 AM   #13754
13Maschine's Avatar
Thumbs up
Awesome, I'm from Seattle originally. Transported to LA! I used to race at TRCR in Tacoma
Old 02-16-2014, 10:04 AM   #13755
13Maschine's Avatar
Who's running bladders in their durango shocks and who's not? Taking a poll here?
Please do share why if you don't mind
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
