Like Tree26Likes
Old 02-12-2014, 12:08 PM   #13696
EbbTide's Avatar
Trader Rating: 34 (100%+)
Originally Posted by fredswain View Post
I run the Exotek gear cover.
I've tried the exotek cover as well. I thought the exotek cover was just poorly made, then I tried the stock cover too, and the same rubbing occurred. It looks like either the spur sits just a tad too far off the motor plate, or the spur is a tad too big. Or the gearbox gremlins are pushing the shaft forward. Idk, I just was hoping someone had an issue in the past and it was really just some simple thing I overlooked. I've rebuilt the transmission more often than I care to mention.
::: Tekno EB48SL ::: HPI Blitz ::: Kyosho RB5 SP2 WC :::Team Durango DEX210 v2 ::: Team Durango ExoDex210 :::Tamiya TB03r/TRF418-ish :::
EbbTide is online now   Reply With Quote
Old 02-12-2014, 12:20 PM   #13697
I only had rubbing issues with larger pinions on the stock cover. No problems now.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 02-12-2014, 12:29 PM   #13698
EbbTide's Avatar
I'm going to try a 5x8x2.5mm bearing like Avid recommends in their bearing kit, over the stock 5x8x3mm they include that the topshaft rides on in the gearbox. Crazy? Possibly, but I'm willing to try. If I am right, this should actually work by dropping the topshaft that .5mm I need to clear the cover. Something that shouldn't be necessary, but you gotta work with what ya got.
The pinion gear clears both gear covers, though I've only tried up to 35t.
Old 02-12-2014, 12:50 PM   #13699
Pittster's Avatar
I have run 36 pinion before but this was with a 69 RW racing Spur Stock cover no clearance issues.
Team Associated B6D, Speed Passion Reventon Pro 1.0, Hobbywing V10 7.5t
Team Associated B64D, Speed Passion Reventon Pro 1.1, Hobbywing V10 G2 6.5t
Team Associated B5M CE, Tekin Rs Gen2, Fleta ZX 17.5t
Pittster is offline   Reply With Quote
Old 02-12-2014, 12:55 PM   #13700
303slowdown's Avatar
Trader Rating: 24 (100%+)
On the setups that say 4 x 1.3 pistons are you guys drilling the blank ones that come with the kit or buying some ? If buying what brand and from where ? Thanks.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 02-12-2014, 01:00 PM   #13701
fq06's Avatar
Originally Posted by MichaelJ View Post
Still no word from Durango about my chassis problem. Not off to a good start with their customer service...
I would keep those pics of the chassis to provide them for an exchange and just use a countersink bit from the hardware store for now to run it. Or even a big drill bit.
Worse case scenario, they don't warranty it or maybe they never get back to you at all... but its not that big of a deal. They missed countersinking one hole, easy enough to fix and it will not affect the strength or longevity of the part.
If the hole wasn't there at all, now you have a problem.
BCE SCT410 / Hobbywing 3656sd ~ RX8.2
DEX210 / Trinity 17.5 ~ RS.2
Westcoast Raceway (R.I.P.) | SMC | PowerLab
fq06 is offline   Reply With Quote
Old 02-12-2014, 01:30 PM   #13702
T-BirdJunkie's Avatar
Location: Norwood, OH...and CCRCR and The OhioRCFactory
Send a message via AIM to T-BirdJunkie Send a message via MSN to T-BirdJunkie
I'm using 4 hole #56 pistons, using the blanks that came off the shock piston parts tree. I picked up some TLR machined ones, we'll see how those do next time I rebuild the shocks.
I've got 30F/27.5R in my car now, but I'll probably drop that to 27.5/25.
If you don't allow yourself to make mistakes, you'll never allow yourself to succeed
T-BirdJunkie is offline   Reply With Quote
Old 02-12-2014, 02:46 PM   #13703
Trader Rating: 520 (100%+)
I would take a calipers to the TLR pistons. If my memory serves me correctly they and other brand (Ae, Kyosho) pistons are slightly smaller in diameter than the Durango's. they all say 12mm, but Durango pistons measure 12+, and the others are 12- depending on tool accuracy, but there is at least a .15mm difference.
flame56mx is offline   Reply With Quote
Old 02-12-2014, 04:02 PM   #13704
EbbTide's Avatar
Durango, please, PLEASE make parts available soon. I can't replace the stock gearbox to see if it is warped; It's been out of stock for the month and a half I've been searching; even the shady RC websites I've checked in desperation. And all of the type b parts for the type B gearbox are out of stock everywhere, so even though I ordered 3 type b gear boxes, I am no better off than I was before without them.
If someone has a spare type B rear brace and type B rear top deck, I am willing to pay retail and shipping costs.
Old 02-12-2014, 04:16 PM   #13705
platgof's Avatar
I am running on an indoor track with a mid motor setup and everyone is going back to rear motors again, what gives??? They are also leaving me in the dust! I am thinking of going to a rear motor set up. Indoor, clay, tight course. The 22's are killing me as well as Dex 210's rear motor.
platgof is offline   Reply With Quote
Old 02-12-2014, 05:00 PM   #13706
Go back one page. A couple of us bought the new gear case from Tower yesterday.
Old 02-12-2014, 05:07 PM   #13707
EbbTide's Avatar
I was the one who posted about the type B gear case lol. I have those, it is the chassis brace and rear top deck I need in order to use the new gearbox. Which is why I still don't have anything to try because the stock gearboxes are not available, therefore I cannot try a new stock gearbox, and the Type B chassis brace/rear top deck are not available so I can't try the Type B gearbox yet either. Quite frustrating.
All I can try tonight is once again rebuild it, and wait for a new top shaft and slipper plate set to rule those out as possible culprits until Durango is kind enough to replenish their stock.
Old 02-12-2014, 05:12 PM   #13708
stinky cheese's Avatar
Trader Rating: 21 (100%+)
Smile
You might have to buy a DEX210 V2 to get the gear box parts you need.
My racing is supported by the following companies
AKA Tires. http://www.ryperhobbies.com.au/
TKO Competition Development. http://premiermodelsupplies.com/
Tornado RC Chargers
Schelle Racing Innovations.
stinky cheese is offline   Reply With Quote
Old 02-12-2014, 05:14 PM   #13709
The extra weight at the rear will help you rotate around those tight corners and then you can blast away on the throttle to the next corner.
Tornado RC Chargers
Old 02-12-2014, 05:24 PM   #13710
EbbTide's Avatar
That may be true sadly, but it doesn't stop it from being ridiculous. And I am no less distraught at the situation. Especially considering the only option may be to lay down ANOTHER $300. Awesome. Cool cool cool. That sounds reasonable for Durango's pockets at least.
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
