Like Tree36Likes
Old 02-07-2014, 08:41 AM   #13651
Obviously they went on the improve the original. My only issue is why since last Oct. did they basically abandon the V1? You couldn't find a kit if you had to but there was about a million RTR's available. I like their cars just think they could have done a better job at keep people's interest. Look at the DEXTC...that had a lot of hype and it took forever to get it out. In the mean time, I've purchased a 6.2 and B5 but my kids will run the Durango's as it's really good stuff.
daveb is offline   Reply With Quote
Old 02-07-2014, 09:00 AM   #13652
tbaybucs's Avatar
Send a message via ICQ to tbaybucs Send a message via AIM to tbaybucs Send a message via MSN to tbaybucs
Originally Posted by wyd View Post
Thanks. I will look into those. Its been the most frustrating thing about this car for me. No real universal setups like Associated and Losi have.
Craig Collinson - Generic Setup this basic setup works pretty well and like he says a few minor adjustments from track to track
Serpent ~ Viper Esc's ~ Savox ~ Trinity Motors ~ Futaba ~ Jconcepts ~ Hakko ~ Dialed-Rc ~
VRC-Pro ~ protek ~ ip batteries ~ Revolectrix Charger
tbaybucs is offline   Reply With Quote
Old 02-07-2014, 09:05 AM   #13653
rc_dude's Avatar
Trader Rating: 130 (100%+)
Default DEX210 gearbox fixes
So I'm curious to see what you guys have done to keep the camber link mounts from snapping off the gearbox and also figured some of you would like to see what I did.
I made this little graphite part, but it'll only fit correctly for a mid motor setup:
[URL=http://s101.photobucket.com/user/StevenTP/media/Team-Durangos/WP_20140207_01_13_41_Pro.jpg.html][/URL
They also have graphite and aluminum braces on eBay:
http://www.ebay.com/itm/Sumo-Racing-Durango-DEX210-DEST210-DESC210-Graphite-Rear-Tranny-Ear-Brace-/261392668636?pt=Radio_Control_Parts_Accessories&ha sh=item3cdc3797dc
So has anyone here done anything else to help solve the problem?
Please share if so, I'm curious
Engineering is my passion.
Team Durango ET48.3, EB48SL, & DEX408v2
One of a kind vehicle in progress
rc_dude is offline   Reply With Quote
Old 02-07-2014, 09:32 AM   #13654
Konich's Avatar
http://www.tresrey-usa.com/tresrey-a...est210desc210/
We've been running them for @3 years with no issues. Works RM or MM as well.
Tresrey Spec DEX410 - Yaiba Spec B5M
Konich is offline   Reply With Quote
Old 02-07-2014, 09:33 AM   #13655
You've got a couple of options. The aftermarket ones are exactly how you've done it. The new gearbox is stronger in this area and has another camber link location. Here are a couple of the fixes for those that broke them.
http://www.rcshox.com/durango-gearbox-fix/
http://www.tsrproducts.com/index.php...t-tytd105.html
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 02-07-2014, 09:42 AM   #13656
Dino_D's Avatar
They didn't abandon the V1. Just the setups were all for a plus +8 chassis. Meanwhile the plastic chassis was available for the Dex210 pro as well as tons of aftermarket companies making a +8, +10 and +11 chassis.
RTR which is basically the same kit minus the aluminum chassis, rear hanger and swapped the ball for a gear diff. And you don't really need a stiff chassis on low/med grip dirt. The V2 is a refinement of the V1.
If you look at AE B4, the different versions were just refinements of the original. Mind you the B5 was a complete redesign, with many adjustments features in the caster and rear toe blocks and spindles, similar to the 210. The 22 2.0 again was a refinement of the original.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 02-07-2014, 09:47 AM   #13657
I would argue that you always want a stiff chassis and that a softer one is a bandaid for a setup problem elsewhere.
Old 02-07-2014, 10:07 AM   #13658
SUPERLOOPER's Avatar
http://www.sumo-racing.com/DurangoDEX210.html
Here is another option. I like the Tresrey but they never have them in stock. I need one for my DEST210 and I am looking at the Sumo because of it.
Brian
2017 Sponsors:
Team SOARSEIKI * AKA * Reds * Sanwa * Nitro Pro fuel * LFR * On point graphics * Xpert * M2C * Daytona RC paint
Brian Looper
SUPERLOOPER is offline   Reply With Quote
Old 02-07-2014, 10:15 AM   #13659
Dino_D's Avatar
Some people like it Stiff, but not everyone can handle it stiff.
I am with you that a stiff chassis will show you any setup issues on your chassis so that your can tweak and get your suspension dialed. A flexible chassis can mask inefficiencies in suspension. On an indoor track where the conditions remain consistent, stiff is good.
If you are outdoors, where the temperatures can change during the day, sometimes its just more forgiving with a plastic chassis. Because the chassis absorbs some of the flex and shock, its suspension range is slightly larger, thus you don't need to chase setup as much. Having a chassis that doesn't give them any leeway in terms of suspension setup being off isn't the best situation for them. Well not for a beginner anyways. I personally run the Dimec20 indoors and on med/highbite, and Dimec outdoors on blown out tracks and "cratered to the moon" type tracks.
Old 02-07-2014, 12:47 PM   #13660
Ya I would agree but TLR and AE didn't stop making the 22 and B4.2 kits prior to the release of the 2.0 and B5. I'm just saying they've got a great product but could do a better job in keeping people on the wagon.
Old 02-07-2014, 01:00 PM   #13661
I ditched my DEX210 and got me a Schumacher KF.
Solved the problem as well
Regards,
David
niemand is offline   Reply With Quote
Old 02-07-2014, 01:14 PM   #13662
They should have done what Losi did way back in the day with the JRX2 and it's constant upgrades. The original car came out and many of us ran it. I still run mine! As the team changed over from the 5-link suspension to the H-arms, Losi offered them as option parts and they were at hobby shops. As the team drivers started using longer chassis and front shocks and different shock towers, Losi offered them to the public too and even packaged all of it together in the form of the Proformance kit which upgraded the original JRX2 to the new specs. They also released an updated car based on this setup and called it the JRX-Pro. They didn't stop making one to offer the other. They just added it. As they developed more improvements, they were again on the shelves at hobby shops to be purchased by people wanting to try them. They again released another car based on further mods called the JRX-Pro SE. They also had the spinoff's from the series such as the Junior 2 and the JRX-T and it's variants. This was all very smart as they always had product available. There was always something new to play with. This was over 4 years. No one complained that there wasn't a new car since we essentially always had it. It was always being improved and we could decide what parts we wanted to use.
In 1991 they really started changing things. They did the 3 gear transmission and sold it as an option called the Double-X. Team drivers were running radically different front ends to the standard JRX cars and with the new gearbox and other options, they just released a whole new car called the XX. It too went through several iterations with all of the option parts available to the public. When the car got sufficiently different again, they released the XXX which too went through variants. This was how it was done for about 15 years. Durango should follow that lead. It worked.
Old 02-07-2014, 01:33 PM   #13663
I've been drilling an additional hole in the gearbox case similar to what you see in the new version for the past year and a half. Even prior to that I never broke one, but wanted the added assurance that I would not have a breakage.
Team Durango DESC 410V2,Team Durango DESC 210R
Team Durango DEX 410V5,Team Durango DEX 210V2
Mike Maniscalchi www.team-durango.com
knowitall156 is offline   Reply With Quote
Old 02-07-2014, 02:34 PM   #13664
Hi guys, i just got my RTR and plan to bring it to the local track tomorrow(loose dirt). I've done the slipper tuning and throttle setup per the RTR Tech Tips vids on the TD website but still not sure about the esc tuning, what should i set the brake strength and drag brake strength for a loose dirt track? Also just need some advice on the do's and dont's and basic set up as this is my first R/C car.
rydan86 is offline   Reply With Quote
Old 02-07-2014, 08:10 PM   #13665
hacker's Avatar
Trader Rating: 140 (100%+)
Default +8mm chassis
I've just restarted driving this car again....have never gone to a different chassis, as I'm quite happy with it.
What can I expect going to the dimec or any other longer wheelbase chassis?
the tracks I drive have sharp corners, and quite bumpy.
hacker is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
