Like Tree21Likes
Old 01-31-2014, 08:47 PM   #13576
ekt
ekt's Avatar
Originally Posted by lovethebuggy View Post
I can see it now, I didn't think about the connectors go wrong... Yo are right... I will use your method with the battery wires and all black ones
About the servo, I think the D771 looks quite good... I saw some testings on it and it looks pretty good... Just can't figure out what happened with the stock one... So little use...
I like to keep my leads a bit longer so that I can adjust the battery position and because I also have 2 packs that have the terminals on opposite sides.
Here's a pic of my wiring.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 01-31-2014, 10:14 PM   #13577
fq06's Avatar
You would probably be able to if you flipped the pack. With the adjustment range you have with the lipo to the front position you may be able to barely make the positive over to the negative (probably not though) but then when you grab the negative you would notice that its much longer and something does not compute. Pack to the back position would be the longest and the positive would not reach.
Your positive would be so much shorter though, I think you would be able to wire it that way and not be able to plug in cross polarity and still have the full adjustment range.
Anyway, many ways to skin a cat
BCE SCT410 / Hobbywing 3656sd ~ RX8.2
DEX210 / Trinity 17.5 ~ RS.2
Westcoast Raceway (R.I.P.) | SMC | PowerLab
fq06 is offline   Reply With Quote
Old 02-01-2014, 06:52 AM   #13578
Well, just placed the order with hobbypartz for the solar servo and for some wires and plugs... Just hope the 4mm connector are the correct lol, i didnt check that now that i think
lovethebuggy is offline   Reply With Quote
Old 02-01-2014, 07:12 AM   #13579
I've used the Solar servo in mine since May I absolutely love it
cripplethreat is offline   Reply With Quote
Old 02-01-2014, 07:21 AM   #13580
fq06's Avatar
You want bullet plugs like the ones in that picture a few pages back, or like these
http://www.smc-racing.net/index.php?...product_id=162
These will work with the low power demands of a buggy, they will work but they are not preferred.
http://www.amainhobbies.com/product_...ectors-10-Male
Old 02-01-2014, 07:27 AM   #13581
The ones from hobbypartz are like the amainhobbies ones so i didnt miss!!
Thanks a lot for all the help fq06 and all you guys!
I will be posting my finished work in like 3 weeks as it takes ages to get here xD and hopefully the car will be alive once and for all!
Old 02-01-2014, 01:17 PM   #13582
ekt
ekt's Avatar
What batteries are you planning to use? Most current packs use a 4mm bullet but some newer ones use a 5mm one.
Leo Lorenzen
Old 02-01-2014, 02:53 PM   #13583
Can someone tell if my idea is right? I mean, my idea is, with the mid motor configuration the motor is less exposed to the rocks and dust from where I can play... Would this be correct? And another thing, does the MM3 will impossible to drive on dirt? I mean, it won't have any grip? Or less grip? Will the car be stopped and won't go forward or is not like that its just come down to racing where it loses some grip?
I refresh everyone that I'm only playing around as I don't have tracks...
ekt: I have some geforce batteries, I guess is the 4mm connector...
Old 02-01-2014, 07:31 PM   #13584
Playing around I doubt you'll notice any performance issues with any configuration Some would claim that MM3 is undrivable on dirt but it's the only way I'll run MM. Even on dirt. Logic would dictate that in MM that the motor is more protected. For just bashing, run it any way you want.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 02-01-2014, 08:42 PM   #13585
Speedo711's Avatar
this is my new finnisher body for my dex210...done by stickit1 racing
this shows my electronics layout....shorty is in the "middle" position
Team Durango DEX210-Novak-Promatch Racing-Mid Motor
Team Durango DEST210-Trackstar-Novak-Promatch
E Olsen
Speedo711 is offline   Reply With Quote
Old 02-01-2014, 09:51 PM   #13586
kmvl81's Avatar
Default shock o rings
Whats up with the shock o rings not being available again till April?? Any one know of a place that has them in stock that's not overseas?
Kevin VanLeer
Mugen MBX7R, Mugen MBX7r ECO, Mugen MBX7TR
XRAY XB4 2016, AE B6D
Flashpoint Tekin savox mylaps
Ninja B03 and B04, O.S. B2101 and Spec2
kmvl81 is offline   Reply With Quote
Old 02-01-2014, 10:09 PM   #13587
EbbTide's Avatar
Trader Rating: 32 (100%+)
For bashing in very loose dirt/gravel the buggy won't have a whole lot of grip regardless of the setup. It's just very light, 2wd, and the usual buggy tires won't be able to dig any further than several millimeters of any dusty surface. You'd definitely want some sort of bashing tire, or else you will go through regular racing tires like there is no tomorrow if you are spinning your tires frequently. But even though you won't have consistent traction I don't see why you would get stuck in dirt unless you are attempting to run on something like silt or sand, then you may get stuck without paddle tires.
And the mid-motor will definitely be a bit better protected from bad rear-end landings which usually scratch up and ding motors pretty quickly. But like said above, the setup won't matter a whole lot for a bashing environment. These cars were made for a hard packed track.
::: Tekno EB48SL ::: HPI Blitz ::: Kyosho RB5 SP2 WC :::Team Durango DEX210 v2 ::: Team Durango ExoDex210 :::Tamiya TB03r/TRF418-ish :::
EbbTide is online now   Reply With Quote
Old 02-01-2014, 10:54 PM   #13588
rcjunky1's Avatar
Got most of the new parts ordered up today, most of then are showing late february. Not going to bother with the new chassis yet as I have one of my own that still strait enough (running on turf I had some negative experiences with solid objects, went WOT into a steel post right in the center, it un pluged that battery and bent the chassis bad, the stock one is also bent but don't know how) and now have a type b for dirt use.
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 02-02-2014, 12:51 AM   #13589
Thanks a lot!!
I guess I will try and see with this configuration for some time... For wheels, I got the pro line dirt hawg that every comment say they last forever... The stock rear tires lasted less than the battery pack xD
Old 02-02-2014, 06:48 AM   #13590
dirty & best!
syntex1 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16562 Today 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
