Like Tree23Likes
Old 01-28-2014, 05:13 PM   #13501
I made my own chassis so scratch that and all associated parts off the list. I'm probably not touching the shocks so scratch that. I despise cab forward bodies so scratch that. I may play with the arms but not convinced I need to. The only thing I see that I definitely want is the gear case.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 01-28-2014, 05:38 PM   #13502
ekt
ekt's Avatar
Originally Posted by flame56mx View Post
Where are you getting the specs?
Parts are listed on Tower http://www3.towerhobbies.com/cgi-bin...2+++&search=Go
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 01-28-2014, 05:41 PM   #13503
Trader Rating: 520 (100%+)
Originally Posted by ekt View Post
Ok, whizzed through that page too fast, must need pictures I guess..lol
flame56mx is offline   Reply With Quote
Old 01-28-2014, 05:51 PM   #13504
Konich's Avatar
Arms for me and that's it. Hello V2!
Tresrey Spec DEX410 - Yaiba Spec B5M
Konich is offline   Reply With Quote
Old 01-28-2014, 06:13 PM   #13505
Speedo711's Avatar
i will probably buy the revised rear shock tower and a-arms... i have had no issues with my gearbox
Team Durango DEX210-Novak-Promatch Racing-Mid Motor
Team Durango DEST210-Trackstar-Novak-Promatch
E Olsen
Speedo711 is offline   Reply With Quote
Old 01-29-2014, 02:25 PM   #13506
ekt
ekt's Avatar
Pics of the v2 from the 2014 Toyfair can be found here http://www.area52.cc/news/4593-toyfa...m-durango.html
Leo Lorenzen
Old 01-29-2014, 02:53 PM   #13507
Team durango dex210 my tires are wearing on the inside not on thr outside could this be from toed out or need more negative camber. Im racing on carpet with mid motor which rear suspension blocks should I try
poston is offline   Reply With Quote
Old 01-29-2014, 03:14 PM   #13508
I want to see underneef it..
Hard to say w/o seeing the car, but more than likely too much camber. As far as suspension blocks go,there is no "universal best", its more of a try and feel thing for you at your track. Without knowing what the car is doing right or wrong, or where more is needed it tough for us to tell you what to try. Let us know what you want out of your car, and maybe even what blocks you are using etc and we should be able to dial it in a little better..
Old 01-29-2014, 04:29 PM   #13509
Dino_D's Avatar
Durango Hex Mod
I didn't like using the threadlock method. Aftermarket clamps are great, but I thought maybe a DYI mod would do the trick.
Thought I might share it with you guys. You just need part #704046
Test to make sure the screw sits flush in the hex or the wheel can't fit on.
You need to shorten the pin slightly so that the screws can clamp onto the hex and not protrude out. If you can't put the wheel on, either the pin is too long or the holes for the counter sink is not deep enough.
Trim any flashing so that the pin can slide in easily.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 01-29-2014, 04:31 PM   #13510
Originally Posted by Dino_D View Post
Durango Hex Mod
very cool..I like the transparent links also.
Sorry Dino, was just giving you a hard time..nice work, i was thinking of doing a similar mod to my alumi hexes but lost interest (lazy) way through the first one, and used a drop of CA instead..lol
Old 01-29-2014, 04:45 PM   #13511
Dino_D's Avatar
very cool..I like the transparent links also..
Sorry I was trying to figure out why the links didn't post. Its up now.
Old 01-29-2014, 11:02 PM   #13512
Mopar's Avatar
Durango Hex Mod
A simpler easier fix is use a spot of thread lock on the pin. That's what I did when I got tired of the pin falling out b4 I got clamping hubs. Now I run 12mm hexes so I can use the lighter AKA universal wheel. B4 that I switched the front to truck hubs using cut TC axles and 12mm hexes to use the universal fronts. Mostly cause I hated taking bearings out to clean tires.
Mopar is offline   Reply With Quote
Old 01-30-2014, 02:05 AM   #13513
I use a thick teflon grease on the pin. Works for me.
goszu is offline   Reply With Quote
Old 01-30-2014, 06:07 AM   #13514
Khador12's Avatar
Pictures of the new V2.
Billy Stewart
Xray T4 17
Khador12 is offline   Reply With Quote
Old 01-30-2014, 07:06 AM   #13515
Bigrigger's Avatar
These race-winning features are now standard equipment:
■ 8 mm-longer hard-anodized aluminum chassis for more straight-line stability and better post-jump recovery
■ New, straight front arms for more ground clearance and better aerodynamics
■ New, interchangeable rear arms for front or rear shock mounting options
■ Redesigned rear chassis brace for easier access to gearbox and power system
■ New side pods provide more mounting space for electronics and better dirt and water protection
■ New front shock tower design and material for faster,
easier access to camber links and superior crash resistance ■ Improved, low-profile rear shock tower for better post-jump
handling and more shock tuning options
■ New v2 cab-forward body for greater downforce and
■ More shock piston choices, including blank pistons for
custom setups
■ Updated DIMEC X ball cups for better crash resistance and
faster adjustment
■ -2 mm rear low roll-center suspension hanger for improved
(forward) traction and smoother cornering on low-grip tracks ■ All Team Durango Type “B” upgrades
C4.2 B5 B44.2 LRP FLOW Airtronics M11x
Bigrigger is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
