Like Tree23Likes
Old 01-25-2014, 01:30 PM   #13486
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
So... DEX210 v2 parts?!?! http://www.amainhobbies.com/index.ph...ango-DEX210-V2
Looks like just option parts from the v1
Fishhook
ewashburnaf is offline   Reply With Quote
Old 01-25-2014, 05:00 PM   #13487
Mopar's Avatar
Originally Posted by RCNYWOLFTEAM View Post
Amain Hobbies Ha All Team Durango Kits On Sale Price Is Unbelievable Must Check It Out
Amain does not show any kits or RTR for the 210, unless they are in the clearance section.
Mopar is offline   Reply With Quote
Old 01-25-2014, 06:20 PM   #13488
Trader Rating: 18 (100%+)
ROCCK Run for the Riches
Got stepped on by a marshal in sub freezing temperatures and was lucky enough to not break and finish 5th after qualifying 7th!
If you build it I will break it!
EB48.4 - B6 - B64 - TC7.1 - F6
iTz Nicholas72 is offline   Reply With Quote
Old 01-26-2014, 10:43 AM   #13489
fq06's Avatar
The shorty pack shifting the weight forward gave me the exit steering I was looking for without sacrificing much rear grip. Drilled new holes for the rear battery stop and used foam in the front to take up 10mm of gap.
Slight change in rear RC and now it's dialed.
That also opened up some real estate behind the pack to move my rx and esc to the center of the chassis
Can't wait to take it out next weekend
BCE SCT410 / Hobbywing 3656sd ~ RX8.2
DEX210 / Trinity 17.5 ~ RS.2
Westcoast Raceway (R.I.P.) | SMC | PowerLab
fq06 is offline   Reply With Quote
Old 01-26-2014, 11:38 AM   #13490
In RM mode that's exactly how I'd recommend running a shorty or nearly so.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 01-26-2014, 08:12 PM   #13491
Speedo711's Avatar
how do you guys run your shorty in your MM4 car?
i've been running it all the way back for the local indoor clay track.
Team Durango DEX210-Novak-Promatch Racing-Mid Motor
Team Durango DEST210-Trackstar-Novak-Promatch
E Olsen
Speedo711 is offline   Reply With Quote
Old 01-26-2014, 08:32 PM   #13492
Trader Rating: 520 (100%+)
I ran mine all the way back, but that was in blinky. Mm4 will create a ton of weight transfer, especially with a mod motor, so shock oils/pistons will really come into play. I went 5wt lighter in the rear, and the lost on power steering almost altogether.
flame56mx is offline   Reply With Quote
Old 01-27-2014, 08:24 AM   #13493
Dino_D's Avatar
Originally Posted by thefan View Post
Its weird that durango have gone from gullwing arms to straight arms while assoc went from straight arms to gullwing coz they said it was better, also to the guy building the side pods to allow saddle packs, i thought keeping all the weight down the centre of the car was better for handling so what advantage does your chassis design offer?
Gullwing arms give more steering and makes the front end sit a bit lower, which also alters roll center. (better for smooth and high bite tracks) Straight arms are less sensitive and has less steering which is great for low bite / blown out tracks.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 01-27-2014, 08:30 AM   #13494
rcjunky1's Avatar
I'm looking for TD330599 (type B aluminum LRC -2mm RR pivot block), I'll be at Motorama and ideally want it before then if anyone has one they'll part with. PM me if you got one.
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 01-27-2014, 08:52 AM   #13495
Gullwing arms don't change roll center at all. The only thing that matter is the location of the inner and outer hinge pins in relation to the camber link. That doesn't change. A gullwing arm only affects the shock mounting location. A change to the shock tower can negate that as well. I honestly don't see how one can handle any differently than the other except for the effect that a slightly lower mounted shock has.
Old 01-27-2014, 08:57 AM   #13496
Trader Rating: 57 (100%+)
I have access to a few of them. All NIP. A friend from Scotland carried them over but it's expensive. The GBP rate was just higher and shipping to him added costs as well. I'll PM you details but if anyone else is interested, PM me.
shagino is offline   Reply With Quote
Old 01-27-2014, 09:46 AM   #13497
EbbTide's Avatar
Trader Rating: 32 (100%+)
It's not the Durango part, but it has the same LRC -2mm characteristics and is much cheaper.
http://www.exotekracing.com/dex210-r...ype-b-chassis/
::: Tekno EB48SL ::: HPI Blitz ::: Kyosho RB5 SP2 WC :::Team Durango DEX210 v2 ::: Team Durango ExoDex210 :::Tamiya TB03r/TRF418-ish :::
EbbTide is online now   Reply With Quote
Old 01-28-2014, 02:45 PM   #13498
rcjunky1's Avatar
http://lutzinator.com/?p=1448
this confirms they where in fact using the v2. The eta has been pushed back some more, mid march now
Team Durango Canada
Old 01-28-2014, 04:44 PM   #13499
Konich's Avatar
Dex210 to DEXV2 conversion. Just looks like a couple parts? Since I run a +10mm chassis all I really need is the arms and front shock body and shaft?
BALL DIFF OUTDRIVES
GEARBOX SET
CHASSIS SIDE POD SET (+8mm)
MOTOR GUARD
MAIN CHASSIS PLATE (+8mm)
REAR CHASSIS BRACE SET
SUSPENSION ARMS FRONT: 1 pair LEFT & RIGHT
SUSPENSION ARMS REAR: 1 pair LEFT & RIGHT
BIG BORE SHOCK BODY: 21.5mm STROKE
SHOCK SHAFT : FRONT
SHOCK TOWER SET
RR SUSPENSION HANGER -2mm LRC (3 Degree)
BIG BORE SPRING RETAINER
DEX210v2 Cab-Forward Body
Tresrey Spec DEX410 - Yaiba Spec B5M
Konich is offline   Reply With Quote
Old 01-28-2014, 05:05 PM   #13500
BALL DIFF OUTDRIVES
GEARBOX SET
MOTOR GUARD
SHOCK SHAFT : FRONT
SHOCK TOWER SET
Where are you getting the specs?
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
