Like Tree24Likes
Old 10-28-2011, 11:51 PM   #1336
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by mjealey View Post
1. What gearing would be a good place to start? I will be running a Tekin RS Pro and a 13.5 Redline to start.
Originally Posted by Jason Snyder View Post
87/22
87/22 is WAY WAY under geared for a 13.5. For a 13.5, you are going to need to be around 87/29-30, which will not fit in the buggy. The largest pinion you can run with the factory spur is 25, which is under geared for even my 9.5 turn. Your best bet would be to carefully ream out a 78 tooth AE spur, and run a 28 pinion.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-29-2011, 12:15 AM   #1337
T-BirdJunkie's Avatar
Location: Norwood, OH...and CCRCR and The OhioRCFactory
Send a message via AIM to T-BirdJunkie Send a message via MSN to T-BirdJunkie
x2, that's undergeared for an 8.5, let alone a 13.5.
If you don't allow yourself to make mistakes, you'll never allow yourself to succeed
T-BirdJunkie is offline   Reply With Quote
Old 10-29-2011, 05:42 AM   #1338
Matt Howard's Avatar
I ran boosted 13.5 last weekend and ran 79/28, just reamed out a B4 spur until the RW spurs are available.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-29-2011, 03:23 PM   #1339
Bman's 3XNT's Avatar
Trader Rating: 70 (100%+)
Guys when installing the diff in the gear case,which side does the plastic nut go on? I run RM 3 gear setup. It looks in the book that the adjustment side is on the pinion side. Is this correct? Thanks guys.
Team Durango DEX410 w/3 Diffs ;) The original
Xray Xb2 CE
www.rchr.biz------www.Wolcotthobby.com
Bman's 3XNT is offline   Reply With Quote
Old 10-29-2011, 04:24 PM   #1340
you're correct, the adjustment side is on the right with the RM3 setup
RCTech #361
Old 10-29-2011, 05:06 PM   #1341
x7tristan's Avatar
Really? Won't that make the screw unscrew itself when you apply power?
TJ
DURANGO DESC410R
x7tristan is offline   Reply With Quote
Old 10-29-2011, 05:15 PM   #1342
hi guys im putting together my 210 with rm4 now what side does the motor go on. i already put it together and its seems like the motor goes to the right side of the car is this right ,, please help
thanks ,,,brian
BRIAN77 is offline   Reply With Quote
Old 10-29-2011, 05:26 PM   #1343
look at the pics in the manual, the adjustment screw head goes on the right side
RCTech #361
Old 10-29-2011, 05:27 PM   #1344
thanks ,,,brian
RM4 the motor will be oppposite from what your used to, the solder tabs will be on the right side
RCTech #361
Old 10-29-2011, 05:44 PM   #1345
x7tristan's Avatar
The manual is wrong, I followed the manual and my diff unscrewed itself when you held one wheel. All other classic RM3 have the NUT on the spur side
TJ
DURANGO DESC410R
Old 10-29-2011, 05:58 PM   #1346
two weeks racing and my diff is fine, built per the manual.
RCTech #361
Old 10-29-2011, 06:24 PM   #1347
thank you matt .. how do u like the rm4 over the rm3.
thanks again ,,,BRIAN
Old 10-29-2011, 06:27 PM   #1348
I've only run RM3 so far. I run on a pretty high traction indoor track so I don't need the extra rear traction from the RM4 setup.
RCTech #361
Old 10-29-2011, 06:42 PM   #1349
ChEmDoCtOr's Avatar
I was playing with an out of box Durango yesterday, man, this thing handles pretty good, and pulling out the diff takes all of 5 seconds! They need a buggy!
ChEmDoCtOr is offline   Reply With Quote
Old 10-29-2011, 08:29 PM   #1350
FastPete's Avatar
Trader Rating: 44 (100%+)
+1
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
