Like Tree26Likes
Old 01-15-2014, 05:32 AM   #13351
Send a message via MSN to kúv!n
I also run 2k, start from there.
kúv!n is offline   Reply With Quote
Old 01-15-2014, 08:03 AM   #13352
Originally Posted by Walkman View Post
You can use it but 50k is way to thick the buggy will push like a freight train. I run 2k I would start with 5k if I were you.
Ohh i see... Thanks for the advice, I will get some 2k to try it...
Thanks!!
lovethebuggy is offline   Reply With Quote
Old 01-15-2014, 05:50 PM   #13353
TAMAK's Avatar
Trader Rating: 28 (100%+)
I got a parts/ tires lot! DEX210 parts, front tires/rims, gear diff, bulkheads, camber mounts
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 01-15-2014, 06:24 PM   #13354
RCNYWOLFTEAM's Avatar
What Are Some Good Carpet Tires For The DEX210 Or The DESC210
Carlos C.
l (718-951-2500) Brooklynhobbies.com l
l (347-529-3862) LS Auto Body & Repair Shop l
RCNYWOLFTEAM is offline   Reply With Quote
Old 01-15-2014, 06:30 PM   #13355
TAMAK's Avatar
dboots! I also like the proline wedge front for the DEX210
Old 01-15-2014, 06:37 PM   #13356
Carlos C.
Old 01-15-2014, 06:40 PM   #13357
RC10Nick's Avatar
schumacher yellow mini pins work like a charm on carpet.
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 01-15-2014, 06:44 PM   #13358
Trader Rating: 29 (100%+)
Fronts: dboots nanobytes in A compound, Schumacher low profile cut stagers in Yellow compound
Rear: Schumacher min pins in yellow compound. That's the best rear for carpet period. dboots nanobytes in A compound are good to but the min pins are the best!
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 01-16-2014, 01:13 AM   #13359
Is there any durable tire out there for a basher? The rear ones that came with the car lasted less than the battery lol, they are still usable but for no too long, I play on asphalt or in a rough dirt, I guess the tires weren't too good...
Old 01-16-2014, 07:44 AM   #13360
You run any tire for a buggy on asphalt and it will not last at all they are not made for that. If your going to run on asphalt find the hardest compound you can and that still won't last to long. If your running on abrasive dirt use Jconcepts orange or another company's equivalent. As for tread that depends on the dirt, loose , hard packed? If it's loose look at something with a lot of tread depth with pins and lugs.
Old 01-16-2014, 08:11 AM   #13361
Would the pro line dirt hawg be a good choice?? It is very rough abrasive and loose dirt...
Old 01-16-2014, 08:36 AM   #13362
It's a good all around bashing tire.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 01-17-2014, 09:22 AM   #13363
Does anyone here actually have the new gear case? I'd like to know the distance between the new camber link locations as measured from each other right to left. I know what I hope they are but I want to see if it matches reality. If not I'll just make my own plate and cut off the originals.
Old 01-17-2014, 09:53 PM   #13364
I'll get mine on tuesday or wednesday, then i can measure it for you!
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 01-18-2014, 07:34 AM   #13365
Send a message via AIM to zuki250
Hey guys...just finished rebuilding my buggy i just got...I have an 8.5 turn in it..what is a good starting point for a pinion..it has the 87t spur...i have a 25 in it now...am i in the range or do i want to go higher/lower?
zuki250 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16570 Today 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
