Like Tree24Likes
Old 01-14-2014, 11:52 AM   #13336
Dino_D's Avatar
Originally Posted by tfrankito View Post
I wasn't knocking the RTR. That is why I was asking. Sometimes the RTR of other brands you end up having to dump money into them before you can drive it properly. Example is the b4. I had one and it was horrible until I upgraded shocks, +8 chassis etc... I wanted to make sure if I was going to have to do anything to it which it sounds like I won't to be able to be competitive out of the box. My desc210 was not an rtr and people were saying to get the kit not the RTR.
Well you can always swap out the ESC, Motor and Radio from the RTR and sell it. I would assume most people would change it anyways if they are running anything but a blinky spec class. But between the RTR and the PRO kit, there isn't much difference. I prefer the +8 plastic chassis on dirt and low bite clay anyways. Shocks are the same. So I don't get the aluminum rear hanger but that's ok. Upgrading to a ball diff would be a nice option though, and it would probably be one of the few upgrades. The type B hangers are much stronger. If you break your existing ones, just replace with type B.
Also shim the shock tower 1mm away from the gearbox. It helps save the rear shock tower from cracking due to the flex. Cause there is almost no clearance between the motor mount and rear shock tower. Upgrading the front shock tower is another good investment until they make type B front towers.
For carpet, I still think the heavier aluminum chassis is better.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 01-14-2014, 12:18 PM   #13337
Hi!! I have a couple of questions, i just received the DEX210 RTR version, i must say, im really impressed, i didnt know what to expect...
I would like to know a couple of things... First, what is those two things that come in the bag of the wing?? i just do not know where to put them lol
Second, it has a good amount of leak on the rear arms, i think is from the differencial, how can i check if it is from inside or if it is from outside or if it is normal...??
It is super fast for me, im just playing in the streets and is amazing, i cant imagine how fast a 7.5 motor would be!
Thanks!!
mrs1986 is offline   Reply With Quote
Old 01-14-2014, 02:20 PM   #13338
Dino_D's Avatar
Thanks!!
Also in the bag, is it 2 black flaps? If that is what you are talking about, its something that you can attach to the sides of the wings to increase straight line stability. But a few flips or crashes, and those things are gonna come off anyways.
Best way is to spray some simple green and wipe it clean and see where the leak is coming from. But normally you will see the leak from the underside of the transmission if it is the diff. Also check your shock caps and shock bottoms to see if the caps are loose.
Sometimes some RTR kits have leaky diffs. I just swapped out the oil, which was almost empty to thicker silicon grease. Also if you are planning on running the gear diff, is to upgrade or add 2 more spider gears and 1 axle. as the RTR only comes with 2 spider gears, instead of the 4 gears that is normally found in the 4wd cars.
Old 01-14-2014, 03:09 PM   #13339
novice racer's Avatar
so is 35 in the front and 30 in the rear a good starting point for shocks? I put that in my two XXX cars and to be able to do it to all three would be awesome.
Brandon Shaw
novice racer is offline   Reply With Quote
Old 01-14-2014, 04:19 PM   #13340
psl
Default Help!
I could use your help. I just changed the steering knuckles and c hubs on my 210. My tie rods all match up. I have the steering mod on my buggy. Here is my problem. Front wheels are straight when the buggy is at rest. When I compress the front end the back of the front tires both turn in, the fronts turn out. Think of both front tires in a V shape. My sons buggy does not do this. I am having problems downloading a picture at the moment. I cannot figure out what is going on. The reason that I replaced the items is that my son noticed this during a race. Any ideas would be great.
Durango DESC 410v2 4wd SC
Durango DEX 210 Exotek MM
Durango DEX 410v5
Kyosho SC6
Radiopost
psl is offline   Reply With Quote
Old 01-14-2014, 04:48 PM   #13341
psl
Default pictures
Help with front end.
Durango DEX 410v5
Kyosho SC6
Radiopost
Old 01-14-2014, 04:50 PM   #13342
Trader Rating: 520 (100%+)
When you say steering mod, what are you referring to? What you are noticing is called bump steering, did you change your front axle location?
flame56mx is offline   Reply With Quote
Old 01-14-2014, 04:58 PM   #13343
Thanks a lot, I have 50k traxxas differential oil, will it work??
lovethebuggy is offline   Reply With Quote
Old 01-14-2014, 05:02 PM   #13344
RCNYWOLFTEAM's Avatar
Whtas Wrong with the front end
Carlos C.
l (718-951-2500) Brooklynhobbies.com l
l (347-529-3862) LS Auto Body & Repair Shop l
RCNYWOLFTEAM is offline   Reply With Quote
Old 01-14-2014, 05:03 PM   #13345
psl
I kept the axles the same. By steering mod I meant that I flipped the steering rack. I checked my other trucks. When I compress their front ends the front wheels move in parallel. My buggy does not.
Durango DEX 410v5
Kyosho SC6
Radiopost
Old 01-14-2014, 05:07 PM   #13346
Does The Mod Make Your Kit Better Than Now Or What Because If The Mod Isnt Working Out Maybe You Should Keep The Kit Stock Or Not Another Member Of The Forums May Help
Carlos C.
Old 01-14-2014, 05:12 PM   #13347
You probably need to add a shim or 2 to the outside ballstud on the steering link. That mod works well, but there are a few different ways of doing it, and most require shims depending on where the axles are located (inline vs trailing). If you just flipped the rack, then shims will still be needed, but its hard to say where unless I could see it in person..When I did mine, I shimmed the whole steering assembly up 1mm, and have the rack mounted on top, instead of underneath, and still need 2mm shims on the steering hub.
Old 01-14-2014, 05:46 PM   #13348
ekt
ekt's Avatar
What you are experiencing is called Bump Steer, depending on what castor insert you are using, you need to change how many spacers are under the steering knuckle ball studs.
Originally Posted by Matt Howard View Post
4mm of spacers gives you zero bump steer when running 30 deg of castor, factory setup is 3mm spacer. As you move the castor either up or down you'll have to adjust accordingly to maintain zero bump steer.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 01-15-2014, 01:28 AM   #13349
Can someone give me a hand about the differential oil if I can use 50k traxxas in the RTR differential??
Thanks.
Old 01-15-2014, 04:22 AM   #13350
Trader Rating: 29 (100%+)
Thanks.
You can use it but 50k is way to thick the buggy will push like a freight train. I run 2k I would start with 5k if I were you.
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
