Like Tree43Likes
Old 01-08-2014, 07:20 PM   #13276
Trailing? In regards to steering?
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 01-08-2014, 08:14 PM   #13277
Speedo711's Avatar
yes the inserts in the steering knuckles
Team Durango DEX210-Novak-Promatch Racing-Mid Motor
Team Durango DEST210-Trackstar-Novak-Promatch
E Olsen
Speedo711 is offline   Reply With Quote
Old 01-08-2014, 08:40 PM   #13278
is there a place I can buy thumb nuts cheap? I am not paying 6 bucks for 2 plus shipping and I keep losing them..
cripplethreat is offline   Reply With Quote
Old 01-08-2014, 08:46 PM   #13279
Trader Rating: 520 (100%+)
Depends, track size, grip, driver preference will determine where you'll end up. I am usually in trailing 3 in Rm3 configuration, but it may not work for you or your track..
flame56mx is offline   Reply With Quote
Old 01-08-2014, 08:47 PM   #13280
I am assuming you're looking for the plastic ones if you lose them often-lol?
Old 01-08-2014, 08:48 PM   #13281
I bought the red ones but lost one of those and like 3 of the plastic ones.. is there something I'm doing wrong?
Old 01-08-2014, 08:50 PM   #13282
rcjunky1's Avatar
m3 lock nuts+washers should do the job, or mcmaster carr to the rescue, #91175A061 I think those will work, if they are captured you might need to play with the threaded rod length to get everything right
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 01-08-2014, 08:51 PM   #13283
Speedo711's Avatar
i made my own thumb screws out of old screw style wing mounts
E Olsen
Old 01-08-2014, 08:54 PM   #13284
I am using lock nuts now.. but it's hard to get them off in a hurry thumb screw would be much easier.. does anyone know what the rod size is? would I just look up m3 thumb screw?
Old 01-08-2014, 09:03 PM   #13285
novice racer's Avatar
So. factory aluminum chassis or Dimec+8? Which is better overall?
Brandon Shaw
novice racer is offline   Reply With Quote
Old 01-08-2014, 09:10 PM   #13286
idk, I haven't lost one yet, but I do put a little countersink in my battery plate, and add 1mm to the chassis post so they actually tighten and not just flex the plate. Not sure if that's why your losing them.?? The plastic ones usually thread on fairly tight..
Yeah, they are 3mm. I know that the HPI ones are metric, think for a firestorm or something, they are gunmetal in color.
Old 01-08-2014, 09:19 PM   #13287
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
Thanks Batman! I've been wanting to come to San Diego for some big track action anyway. for now I'm headed to Seattle and I will possibly check out Scott Browns track TRCR…my old home track!
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 01-08-2014, 09:27 PM   #13288
perfect thanks! I found 100 4-40 plastic thumb nuts that converts to 3mm for 11 bucks on ebay.. figured I will give them a shot. Plus I can dye them any color I want
Old 01-08-2014, 09:31 PM   #13289
Sounds like you got a plan..
Old 01-08-2014, 09:38 PM   #13290
I generally run them inline. This is typically best in low grip loose conditions. It is also good on higher grip surfaces with slower motors such as 17.5 blinky mode. The faster the motor and the higher grip the track, the more trail should be run. This is my general guide though and not any set in stone rule.
St Ives RC Club B4Bandit Australian Racing 16575 Yesterday 12:44 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
