Like Tree33Likes
Old 01-08-2014, 10:44 AM   #13261
Send a message via AIM to zuki250
Guys ball diff or gear?
zuki250 is offline   Reply With Quote
Old 01-08-2014, 11:03 AM   #13262
Trader Rating: 29 (100%+)
Depends on what type track your running on. I would go with the ball diff on dirt. I run the gear diff on high bite carpet. Throw the Bfast diff set in it and you should be set for a long while.
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 01-08-2014, 11:05 AM   #13263
I run on clay and packed dirt (almost clay like) in the winter....and loose outside in the good weather...also i have to learn how to set one if i use it...haha
Old 01-08-2014, 11:08 AM   #13264
Ball
Wraith
Gelande II D90
Losi 8ight Mini T
Vintage RC10 Worlds Car
Surgetek is offline   Reply With Quote
Old 01-08-2014, 11:08 AM   #13265
Gear
Wraith
Gelande II D90
Losi 8ight Mini T
Old 01-08-2014, 11:18 AM   #13266
You can just go with the gear diff. It is the easiest and a lot less to maintain. If you go with the ball diff check this thread out on how to break it in.
"How To Properly Build And Break In a Ball Differential and Slipper Clutch"
Old 01-08-2014, 12:21 PM   #13267
Mopar's Avatar
Originally Posted by 13Maschine View Post
Does anyone know where to find gearboxes for the 210? I'm dead until I get one.
I also had no luck finding one on-line. Called my LHS and they had it in stock. If you want give them a call. El Cajon Hobbies in San Diego county, SoCal, 619-449-9990. You might try our local indoor track, they carry Durango too. SDRD Raceway in San Diego, 858-831-0477. Maybe Ampdraw Hobbies, have been there but they carry some stuff, they're in Encinitas, 858-205-9267. Hope this helps.
Mopar is offline   Reply With Quote
Old 01-08-2014, 01:30 PM   #13268
Speedo711's Avatar
http://www.tresrey-usa.com/tresrey-a...est210desc210/
its probably been brought up before but i just found this. If your gearbox is broken on the camber link hole this could fix it.
Team Durango DEX210-Novak-Promatch Racing-Mid Motor
Team Durango DEST210-Trackstar-Novak-Promatch
E Olsen
Speedo711 is offline   Reply With Quote
Old 01-08-2014, 02:06 PM   #13269
Here's another option: http://www.rcshox.com/durango-gearbox-fix/
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 01-08-2014, 02:30 PM   #13270
Speedo711's Avatar
that rcshox one is cool cause it comes in blue
and cheaper
E Olsen
Old 01-08-2014, 02:41 PM   #13271
Hey guys i am now converting my car back to rear motor....the gearbox is together, i am putting on the motor plate...I cant get the bearing to sit flush before i put the plate on. The layshaft spacer keeps pushing the bearing out...I am pretty sure i am using the right bearing....it's step 17 in the manual..anyone had this happen
Old 01-08-2014, 03:09 PM   #13272
I just installed the rc shox fix and it looks great.
metal head is offline   Reply With Quote
Old 01-08-2014, 04:44 PM   #13273
Pittster's Avatar
Sumo racing does a nice Camber link also goes in rear or mid and dosen't get in the way of anything and replaces the shims you run under the ball stud
http://www.sumo-racing.com/DurangoDEX210.html
@ Zuki250 should work OK just make shaw there isn't a stray washer or something in there, bearing should measure 5x11x4mm
Team Associated B6D, Speed Passion Reventon Pro 1.0, Hobbywing V10 7.5t
Team Associated B64D, Speed Passion Reventon Pro 1.1, Hobbywing V10 G2 6.5t
Team Associated B5M CE, Tekin Rs Gen2, Fleta ZX 17.5t
Pittster is offline   Reply With Quote
Old 01-08-2014, 05:03 PM   #13274
Thanks i figured it out...like an idiot i put an extra bearing in the case, where there is a spot for it but not needed....All good now!!
Old 01-08-2014, 05:51 PM   #13275
Speedo711's Avatar
so what do people run for trailing on a rear motor car?
E Olsen
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
