Like Tree27Likes
Old 01-05-2014, 12:57 PM   #13231
fq06's Avatar
Strange. I have the purple cap motor, maybe that's the difference. It is either angled forward to where the C tab is right below the slipper shaft (17.5 gearing) or way back to where I don't want my wires.
The shaft side cap only has 4 holes to thread into and they are on the bottom. The top is machined out and pretty, but I would have benefitted with more mounting holes.
It worked out though, I ran A & B below the tower straight in and C through the bottom center of the tower and turned it in to grab the solder post.
BCE SCT410 / Hobbywing 3656sd ~ RX8.2
DEX210 / Trinity 17.5 ~ RS.2
Westcoast Raceway (R.I.P.) | SMC | PowerLab
fq06 is offline   Reply With Quote
Old 01-05-2014, 01:34 PM   #13232
Trader Rating: 57 (100%+)
Rotate the end bell with the mounting screws. You need to unscrew the three screws then just lift a little and rotate.
I've had to do this on every D3.5 that I own.
shagino is offline   Reply With Quote
Old 01-05-2014, 03:56 PM   #13233
Trader Rating: 5 (86%+)
I need gearing for boosted 17.5 on small to med indoor carpet..tekin rs pro and trinity d3
catfat is offline   Reply With Quote
Old 01-06-2014, 08:31 AM   #13234
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
Thumbs up
Originally Posted by 8ight-e View Post
Are you searching the new "b type" with the new part # or the old one?
I'm having trouble finding the new or the old gearbox as well. Tower and Amain don't seem to have them. Anyone know of stock somewhere please post links!
I'm also looking for a used extra long alum chassis. Probably the RDRP. Anyone know of one? I did some searching already through the buy and sell section so I apologize for posting here just wanted to hit all the DEX210 guys.
Thanks!
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 01-06-2014, 08:59 AM   #13235
13Maschine's Avatar
Thumbs up
Originally Posted by re-do73 View Post
Had it out on the track yesterday for the first time, it ran decent... Still chasing the set up a bit. It got better all day though. I did like the saddle set up better than the shorty though, seemed more planted.
Love your custom Mid motor setup!
in your thumbnail I see graphite side rails, where did they come from?
Looks like you are using some B4 parts to attach the gearbox to the battery hold down?
Old 01-06-2014, 09:20 AM   #13236
fq06's Avatar
Thanx for the tip!
Old 01-06-2014, 09:50 AM   #13237
Thanks!
flame56mx has (had?) a +8 aluminum chassis for sale.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 01-06-2014, 09:55 AM   #13238
re-do73's Avatar
I made the chassis and carbon side plates, the brace from the trans to the battery hold down is off an 1/8 buggy i had in my spare parts bin.
re-do73 is offline   Reply With Quote
Old 01-06-2014, 11:01 AM   #13239
13Maschine's Avatar
Thumbs up
My new MM4 shorty pack setup. I'm liking the speed passion motor setup as it makes it cleaner and less protrusions on the top of the body.
I couldn't quite fit my ESC and fan under my rear bulkhead so I opted to go ESC in front of the battery. Of course wiring is shorter all the way around the other way but this way seems ok for now and I have some adjustment to move the shorty pack forward. I think the newer slim fan will fit however…..
Has anyone done a MM4 long chassis setup that fits everything down the middle with the full size battery? Post pics please!!
Durango DEX210 Thread-img_2501.jpg   Durango DEX210 Thread-img_2502.jpg   Durango DEX210 Thread-img_2503.jpg   Durango DEX210 Thread-img_2504.jpg
Old 01-06-2014, 11:16 AM   #13240
13Maschine's Avatar
Smile
With shorty
very very cool. Let me know if you think you might make more. I also thought it would be cool to have a small brace to connect the gearboxes up top where you added your tie rod stiffener. Is the battery brace you have available somewhere?
Thanks!
Old 01-06-2014, 01:04 PM   #13241
re-do73's Avatar
Thanks!
Made that also! It is all my design, it's convertable to run rear motor also. It can also run a full size lipo down the middle.
Plan to put it in production if there is enough interest in it
Old 01-06-2014, 02:49 PM   #13242
Send a message via AIM to zuki250
Hey all...i just picked up a used 210...thing is in great shape..but needs some love...first it is mid motor...do i want to keep it there or go back to mid...i run on a small clay and larger dirt in the winter... also ideas for pinion? ..I have been running 4wd sc so no real experience with the 2wd buggies....thanks for any help...forgot i think i am going to pick up an 8.5 turn? or should i go different?
zuki250 is offline   Reply With Quote
Old 01-06-2014, 03:13 PM   #13243
I'm a big proponent of mid motor but my initial thought is that you should set it up in rear first and then try mid later on.
Old 01-06-2014, 03:13 PM   #13244
I will have to see if he gave me the parts for it...he left some things out that should be here....
Old 01-06-2014, 07:35 PM   #13245
13Maschine's Avatar
This new exotek piece looks great!
http://www.exotekracing.com/dex210-r...ith-shims-lrc/ It allows you to shim for your kick up settings. No disassembly required!
I'm also considering their graphite chassis with aluminum front plate. Anyone else tried it?
The RDRP is a great option as well…does anyone make a skin/cover for it?
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
