Like Tree23Likes
Old 01-04-2014, 09:16 AM   #13216
thisismyusrname's Avatar
Originally Posted by Mopar View Post
I am using the +11 chassis w/ the std Jcon body, all I did was make a new front hole. And yes stock side guards fit all of the extended chassis.
Excellent, thanks for the response bud.
thisismyusrname is offline   Reply With Quote
Old 01-04-2014, 10:40 AM   #13217
Question, somebody knows what kind of motor can I use with the stock ESC from the RTR version?? Can I use a faster motor without changing the ESC??
lovethebuggy is offline   Reply With Quote
Old 01-04-2014, 01:08 PM   #13218
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
The Cirtix Stock Club Race ESC can "Support up to 9.5T motor with 2 cell lipo" per Speed Passion website.
Fishhook
ewashburnaf is offline   Reply With Quote
Old 01-04-2014, 01:09 PM   #13219
Originally Posted by fq06 View Post
Scratch in my head on this one, anyone running the D 3.5 rear motor configuration that has a tip on this?
The hole count on the can is low so not many options on fitting it.
Can't really rotate the cap as that moves it way too far to the other side since there's only 3 screws holding it together.
This is putting the solder tabs either way inboard under the slipper adjustment nut or way outboard but not in a vertical position.
I run the 3.5 motors and have just put the solder tabs under the slipper adjustment. there is enough clearance just not real fun soldering the motor in.
fanfor18 is offline   Reply With Quote
Old 01-04-2014, 02:02 PM   #13220
fq06's Avatar
Thanx, that's what I ended up doing. And yeah, not fun getting the iron in there.
BCE SCT410 / Hobbywing 3656sd ~ RX8.2
DEX210 / Trinity 17.5 ~ RS.2
Westcoast Raceway (R.I.P.) | SMC | PowerLab
fq06 is offline   Reply With Quote
Old 01-04-2014, 02:17 PM   #13221
And what difference in speed should I see? Or I should change the gears first??
Old 01-04-2014, 02:30 PM   #13222
I assume you have the stock Sportsman 13.5 motor in it currently? You will see marked improvements in speed with a 9.5T motor... especially one with timing adjustments. It may not feel as "smooth" as the 13.5 is because of this..
but I would need more information about your track before making any adjustments. Track type, size, traction level, how are you on pace with others on the straights? are you having difficulty getting enough speed for jumping correctly?
Have you tried a larger pinion yet? It will make a small difference in speed, but if you're looking at being able to dial in your speed better on multiple tracks and surfaces... I'd go up to the 9.5T... Most 2WD buggy racers are using an 8.5T, and it really depends on the surface. So you can get pretty close with a correctly geared 9.5.
Fishhook
Old 01-04-2014, 11:31 PM   #13223
Tried searching but didnt find the answer, what does adding spacers under the steering link ballstud do? The manual shows 2mm spacer but most carpet setups im copying have 5-6mm under it? Can anyone explain why please?
thefan is offline   Reply With Quote
Old 01-05-2014, 12:22 AM   #13224
Mopar's Avatar
Spacers are under either inner or outer ballstud to eliminate bump steer. # of spacers depends on whether you run the steering link plate under the bellcranks or on top.
Mopar is offline   Reply With Quote
Old 01-05-2014, 01:52 AM   #13225
Desperately trying to get my hands on a replacement gearbox.
November 30th:
December 16th:
January 6th:
Are these things ever coming back in stock!? Are there any US retailers that have them? The only place I've found them in stock are online retailers in the Netherlands.
"Speak only if it improves upon the silence."
http://goo.gl/MFfbzr - My ever-updating comprehensive spring rate chart
Bracket is offline   Reply With Quote
Old 01-05-2014, 06:34 AM   #13226
8ight-e's Avatar
Trader Rating: 57 (100%+)
November 30th:
December 16th:
January 6th:
Are you searching the new "b type" with the new part # or the old one?
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 01-05-2014, 08:28 AM   #13227
I have never seen the new gearbox case in stock. Been waiting for months.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 01-05-2014, 09:03 AM   #13228
RCNYWOLFTEAM's Avatar
You Guys Should Try On Other Sites. Aftermarkets Have Many Team Durango Parts In Stock
Carlos C.
l (718-951-2500) Brooklynhobbies.com l
l (347-529-3862) LS Auto Body & Repair Shop l
RCNYWOLFTEAM is offline   Reply With Quote
Old 01-05-2014, 12:02 PM   #13229
This is the new Type B gearbox, but I'd be happy to have either one at this point.
Old 01-05-2014, 12:33 PM   #13230
Why not? I did. Works like a champ.
shagino is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 Yesterday 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
dikke hond
