Like Tree26Likes
Old 12-29-2013, 08:16 PM   #13171
re-do73's Avatar
Originally Posted by re-do73 View Post
With shorty
Another
re-do73 is offline   Reply With Quote
Old 12-29-2013, 08:20 PM   #13172
re-do73's Avatar
Originally Posted by fredswain View Post
That's pretty much how I'm doing mine except I'm not using aluminum.
Im thinking about doing a CF version, debating molding the kick up or machining a front kick plate to bolt to the CF
Old 12-29-2013, 11:21 PM   #13173
rcmania74's Avatar
Trader Rating: 55 (98%+)
Originally Posted by RC10Nick View Post
turn the wheel on your radio.
make sure your steering endpoints are set correctly. make sure there is no bind in your steering rack. make sure you're using the proper front tires for your track. make sure your ride height is set properly. make sure your servo doesn't suck. If you're racing the RTR, take out the servo saver.
couple things you could try (not all at once); move your battery forward, lower your front ride height a mm or two, softer front spring, less castor, shorter front links, angled front links, more toe-out.
find a good tuning guide and learn how to figure it out yourself.
And next time, ask a little nicer. You're not entitled to a response from anybody here so don't sound like a spoiled kid when you ask.
Im Not New To This .... Had Done All Your Mentioned Items ... And I Dont Beleive I Sound Like A Spoiled Kid ... I Sound Like A Frustrated Racer.... And I Did Say Please... So Thanks
Scott chilson... ..smac track. ...dirtburners..hrp checkered flag hobbies ...Alpha engines..nitro pro fuel. ...SAVOX SERVOS HOBBYWING ELECTRONICS. ...wanna know why i dont have a perfect trader rating anymore...feel free to ask because i will definitely tell u!!!
rcmania74 is offline   Reply With Quote
Old 12-30-2013, 03:49 AM   #13174
RC10Nick's Avatar
if you look at mine, I got around this by cutting off the nose section of a type b chassis and using that at the front. It worked out pretty well. Pretty easy to do if you have a type b chassis sitting around, which is what I had before I built my own chassis.
I must say, yours is quite an excellent build. The machining is very nice and the layout is a bit better thought out than mine for sure. Now for the important part, how does it drive?
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 12-30-2013, 04:43 AM   #13175
Anyone have the rtr version of this car?? I'm thinkinking of getting one and just wondering if they are any good-durable? Wondering if the stock servo is good because almost every rtr I've ever bought I had to replace the servo with in the first couple of weeks!! Also any other upgrades that are a must? Thanks for any input
brandon1116 is offline   Reply With Quote
Old 12-30-2013, 05:39 AM   #13176
I have seen alot of these sold and raced at my LHS. have not heard of too many failures. I built the kit (same as rtr without electronics) super durable and great quality. Fast car with tons of adjustment it was a great buy IMO
"Drew Q."
~Team Durango~RCAmerica~Futaba~Trak Power~Murnan Modifieds~REDS Racing USA~Hot Race Tyres
automagic302 is offline   Reply With Quote
Old 12-30-2013, 08:05 AM   #13177
Pics of my RM & MM
syntex1 is offline   Reply With Quote
Old 12-30-2013, 08:40 AM   #13178
Does anyone know when the new gear case will finally be released? I need one!
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 12-30-2013, 12:48 PM   #13179
Originally Posted by Barge View Post
I'm already using the DEX210 front arms actually after reading that from you earlier.
It actually narrowed the front end slightly though. Had some wicked +camber after I did the swap.
Converted to 3mm hinge pins and the inside and caster block and have an essentially zero slop front end.
I finally had a chance to directly compare them side by side. As you probably noticed with the front arms, you had to grind away a little from the arms or the bulkhead to make the arms work since the Durango arms are so much beefier than the AE. The hinge pin sizes are also different so that had to be modded as well.
At the rear the same problems exists. I'm not entirely sure the rear Durango hub will fit on the AE arm. If they do, drilling out the arm for the larger hinge pin may weaken it. I was actually looking into integrating the 210 arms onto my B44.1.
Old 12-30-2013, 06:27 PM   #13180
RCNYWOLFTEAM's Avatar
Did The Dex210 RTR Buggy Get Discontinued I Cant Find It Anywhere
Please Reply
Carlos C.
l (718-951-2500) Brooklynhobbies.com l
l (347-529-3862) LS Auto Body & Repair Shop l
RCNYWOLFTEAM is offline   Reply With Quote
Old 12-30-2013, 07:04 PM   #13181
fq06's Avatar
Kit did the same thing a little while ago, if the rtr is hard to find now too their probably weeks from releasing the V2.
Once their sold out, they haven't been shipped from the manufacturer to the retailers for a few months.
That's a good sign for those waiting on the new kit. 2 out of 2 places that I checked they are discontinued or not found.
BCE SCT410 / Hobbywing 3656sd ~ RX8.2
DEX210 / Trinity 17.5 ~ RS.2
Westcoast Raceway (R.I.P.) | SMC | PowerLab
fq06 is offline   Reply With Quote
Old 12-30-2013, 07:09 PM   #13182
So Of To The TLR 22 Buggy Then
Carlos C.
Old 12-30-2013, 07:24 PM   #13183
fq06's Avatar
You should find smoking deals on V1 rollers and a few with electronics once the V2 is up for pre order though. Not a bad way to go.
Old 12-30-2013, 07:34 PM   #13184
Yes I'm running them currently on my cubed.
I had a chance to compare the rear hubs. The biggest problem is that they are roughly 5mm wider going off memory due to the large diameter bearing that captures the cvd. I'm hoping I can mill down the hinge pin area far enough but its a lot of material.
The hinge pin changes from ae's fake 3mm to a true 3mm. Its not much material. The xfactory carbon rear arms are very strong.
XFactory X6^3, XFactory SCX-60CF, Durango DEX410v3
All Kyosho damped with Viper Power and SMC Juice
Serpent SRX-2MM, Serpent 811E
VBC Firebolt DM
Barge is offline   Reply With Quote
Old 12-30-2013, 08:35 PM   #13185
Can someone tell me if the ESC in the rtr version can handle 3s lipo?? What would be better with this battery??
lovethebuggy is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
