Like Tree23Likes
Old 12-26-2013, 09:19 PM   #13141
fq06's Avatar
Had fun with it today, flame56mx's setup was easy to drive and went where you told it to.
What shock oils did you have in it flame56mx? I want to copy this setup to a sheet and play with it from here. Will probably end up back at your setup, handled really well
BCE SCT410 / Hobbywing 3656sd ~ RX8.2
DEX210 / Trinity 17.5 ~ RS.2
Westcoast Raceway (R.I.P.) | SMC | PowerLab
fq06 is offline   Reply With Quote
Old 12-26-2013, 09:24 PM   #13142
Trader Rating: 520 (100%+)
Lol, I am not sure TBO..I have been trying so many different things as of late, that sometimes one car is too many.. We have 4 going atm..
flame56mx is offline   Reply With Quote
Old 12-26-2013, 09:29 PM   #13143
fq06's Avatar
Cool, will check out some setup sheets and start with the norm.
Old 12-26-2013, 09:41 PM   #13144
We have been flipping back and forth from RM3, to MM4 and now MM3 in blinky. So far MM4 is the safest feeling and easiest drive at our track, but nut not the quickest laps..Finding the balance is the key, and a few of the things we're trying now are a little off the page "so to speak"...
Old 12-27-2013, 12:19 AM   #13145
RCNYWOLFTEAM's Avatar
Were Can A Get A Good In Door Clay Set Up For The Buggy And What Are The Most Recommended Aluminum Or Carbon Fiber Upgrades
Carlos C.
l (718-951-2500) Brooklynhobbies.com l
l (347-529-3862) LS Auto Body & Repair Shop l
RCNYWOLFTEAM is offline   Reply With Quote
Old 12-27-2013, 09:56 AM   #13146
MikeR's Avatar
Trader Rating: 15 (100%+)
Hi All,
Now stocking 7075 Type B rear hangers;
http://www.exotekracing.com/latest-products/
Thx
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 12-27-2013, 09:57 AM   #13147
Don't suppose anyone could measure of a set of the DEX210 rear hubs?
I'm trying to figure out if I can use the DEX210 CVD and hub on my X6 Cubed so move to the big inner bearing with captured CVD pin.
Wondering if there is a geometry difference and if the driveshaft would be the right length.
XFactory X6^3, XFactory SCX-60CF, Durango DEX410v3
All Kyosho damped with Viper Power and SMC Juice
Serpent SRX-2MM, Serpent 811E
VBC Firebolt DM
Barge is offline   Reply With Quote
Old 12-27-2013, 10:02 AM   #13148
The B4 and 210 arms are the same length pin to pin and the Durango and AE cvd ends are both the same size on the outdrive side so I don't see why it wouldn't work. You could use the 210 front arms and/or steering hubs too.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 12-27-2013, 10:07 AM   #13149
I'm already using the DEX210 front arms actually after reading that from you earlier.
It actually narrowed the front end slightly though. Had some wicked +camber after I did the swap.
Converted to 3mm hinge pins and the inside and caster block and have an essentially zero slop front end.
VBC Firebolt DM
Old 12-27-2013, 11:01 AM   #13150
Trader Rating: 29 (100%+)
just curious if there has been anyone who has found a 12mm rear hex to work on the dex210. thanks
Jason Hack
madhammer is offline   Reply With Quote
Old 12-27-2013, 11:16 AM   #13151
Supposedly Raul Garcia used the Proline 12mm hexes.
http://www.petitrc.com/setup/durango...323/index.html
Old 12-27-2013, 03:12 PM   #13152
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I use the stock aluminum b4.2 ones. I just sand down the back lip on hex til its flat and it works perfectly. If you leave the lip on when you tighten the wheel it binds the bearing but when you sand down that back lip its perfect. You can tighten as much as you want with no binding.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 12-27-2013, 03:32 PM   #13153
GasGod's Avatar
+1 I use j concepts clamping alloy hex's for the 4.1-no bind
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 12-27-2013, 03:34 PM   #13154
GasGod's Avatar
Anyone know where to get the plastic outdrive caps that are on the rtr gear diff??
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
Old 12-27-2013, 03:45 PM   #13155
GregerL's Avatar
I belive they are included with a new gearbox set, haven't seen them available separately. Sadly this is one of the major drawbacks of the kit, sometimes you have to buy a lot of plastic to get the part you really want.
/Greger
GregerL is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16562 Yesterday 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
