Like Tree24Likes
Old 12-18-2013, 09:28 AM   #13096
re-do73's Avatar
Originally Posted by RC10Nick View Post
interesting. is this a +8? what made you decide to make your own chassis? pretty curious as I've made my own custom chassis for the dex and I'd be interested to see if you are doing it for the same reasons I did.
this one is +10, chassis will be able to run mid or rear motor, saddle and shory centro style in mid, and a shorty or full size normaly in rear build
re-do73 is offline   Reply With Quote
Old 12-18-2013, 02:47 PM   #13097
Trader Rating: 38 (100%+)
Originally Posted by Walkman View Post
Here it is on my MM4. The only cutting needed is to cut out the motor plate. Top pic is with stock chassis, bottom pic is with +8 chassis.
Great pics thanks! I only hope i can cut out mine that cleanly
don't take it too serious, they are toys....
vw addict is offline   Reply With Quote
Old 12-18-2013, 02:51 PM   #13098
Trader Rating: 18 (100%+)
23/81 sounds good for a starting point with a Speed Passion MMM 9.5T? Not sure what size track yet because it's up in the air which one I'll be racing at in the coming weeks...
If you build it I will break it!
EB48.4 - B6 - B64 - TC7.1 - F6
iTz Nicholas72 is offline   Reply With Quote
Old 12-18-2013, 07:11 PM   #13099
re-do73's Avatar
Got most of the parts modeled up now
Old 12-18-2013, 07:14 PM   #13100
re-do73's Avatar
Posting from my phone, it will only let me attach 1 pic per post
Old 12-19-2013, 03:57 AM   #13101
RC10Nick's Avatar
Funny, I built my chassis to get a better battery layout in mid as well. Only mine is +8mm and g10/fr4, but still close enough. Yours also looks a little nicer. I'm guessing you have some machines at your disposal. Mine was all freehand with a dremel!
Over summer when I don't race as much I plan on updating it with 2mm CF. I like light cars
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 12-19-2013, 06:51 AM   #13102
Devin's Avatar
Nick,
I really have no idea. I did however use the gearing guide located at "Durango fansite" (just google it). And I plan on buying pinions in and around the gearing it recommended.
To piggyback Nick's question in-case anyone has experience on this:
The roller I bought came with 78t spur gears and I have a Viper 8.5T motor on a high speed long track with several banked corners (26second laps). The gearing guide recommends 22T.
Devin is offline   Reply With Quote
Old 12-19-2013, 07:09 AM   #13103
rcjunky1's Avatar
I for some reason though I ran my lrp x12 8.5 at 26/78 and it never got hot in blinky. I just got a viper 8.5 (never buying a lrp motor again, it self destructed during warm up before lining up my best start at the newest surface at the local track) so am I going nuts and should be running the stock spur? 22 will not fit with the 78, 26 is the smallest
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 12-19-2013, 06:59 PM   #13104
ekt
ekt's Avatar
I really need to get around to trimming out the combos that wont fit on that chart
The guide is really only to give starting point for gearing. Different motors, track conditions/size will change the ideal gear ratio.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 12-20-2013, 04:36 AM   #13105
Devin's Avatar
Wow great tip thanks. I'll change that before I complete my order.
Is there a listing somewhere of what pinions work with specific spurs to actually fit? I will be having the identical issue with the truck as well and would love to get the right gearing for both.
Old 12-21-2013, 06:02 PM   #13106
I ran mine 23/82 on mediumsmall carpet track.
jaank is offline   Reply With Quote
Old 12-21-2013, 11:12 PM   #13107
Trader Rating: 25 (100%+)
Is TD coming out with a new 2wheel drive? Amain has nothing listed anymore and my lhs can't even get them.
Thank You to Hobby Town Lake in the Hills/Timewarp raceway. Support your local hobby shops
AE B5M/HB D413
toughtrax is offline   Reply With Quote
Old 12-22-2013, 05:46 AM   #13108
8ight-e's Avatar
Trader Rating: 57 (100%+)
22,23 is the ticket w/ most 8.5 motors. I run a viper as well, love their motors, not a fan of their esc's but great quality motors. Yes go to the larger stock spur.
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 12-22-2013, 06:47 AM   #13109
Yes. The DEX210 V2 is coming out Feb/March 14'
Team Durango DESC 410V2,Team Durango DESC 210R
Team Durango DEX 410V5,Team Durango DEX 210V2
Mike Maniscalchi www.team-durango.com
knowitall156 is offline   Reply With Quote
Old 12-22-2013, 01:03 PM   #13110
Originally Posted by flame56mx View Post
Yep, what he said..Also, if its not the distorted gear diff, look inside the case where the 2 screws hold the trans to the chassis. I have seen more than one, where too long of a screw was used, and the bulge interferes with the main gear.
Originally Posted by ewashburnaf View Post
Could be one of the screws that go through the diff case and into the motor mount... the bold could be rubbing on the back of your slipper and causing it to bind a little. Just add a shim to the other side of the bolt if this is the case.
Originally Posted by Mopar View Post
How did you assemble the diff? If you used a cordless drill to run in screws I you may have distorted the gear from heat or over tightened the screws. I ruined one gear from using a cordless and had to replace the gear.
Now I have finally managed to find some time to work on the car lol.
I switched the main gear on the gear diff and rebuilt everything by the manual. The problem still exists, when i have the gearbox in my hand slowly rotating the spur gear then about 2/3 of the turn is still rotating hard. The only thing I can still think of is that the brand new gearbox is kinda tight. It isn't any of the reasons above then...
When I have it open and rotate the gears by hand I don't see any additional drag or rubbing and everything is smooth.
Also after the diff rebuild, when rotating one side of the diff it's all quiet, when rotating the other side it makes a cliking noise. Fuck, as they say, you shouldn't touch a working thing.
All help is appreciated.
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
