Like Tree24Likes
Old 12-13-2013, 06:07 AM   #13066
Originally Posted by 8ight-e View Post
Mine are in the mail system, I'll post an update if you want. I have both front and rear ordered.
Thanks.
faifaisalfal is offline   Reply With Quote
Old 12-13-2013, 07:03 AM   #13067
rcjunky1's Avatar
I've got the rear and a Cream front, both have put up with a low of abuse. STRC makes good stuff (I work in a hobby store and have seem lots of sub par bling products, STRC isn't one of them)
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 12-13-2013, 02:48 PM   #13068
Lead-Lobber's Avatar
Location: Currently live in southern AZ, or closer to northern Mexico if your a realist.
Default Shock mounts
Hey guys,
I replaced my factory plastic shock mounts with the Ti RDRC mounts. The stock plastic ones had the pivot balls molded in. What part do I use to replace the pivot balls on the aftermarket shock mounts?
Jeff
Jeff R.
Tucson AZ
DEX210
SC10
Lead-Lobber is offline   Reply With Quote
Old 12-13-2013, 03:12 PM   #13069
Trader Rating: 520 (100%+)
Originally Posted by Lead-Lobber View Post
Hey guys,
Jeff
These
I found them on this site, I would bookmark it, as it has a ton of answers to many questions..durangofansite
flame56mx is offline   Reply With Quote
Old 12-14-2013, 07:54 AM   #13070
I installed the new type B gearbox and geardiff with no shimms between the bearing and diff. If i slowly rotate the spur with my hand i can feel a part of the turn where it's quite notchy and doesn't rotate really well. Any ideas?
jaank is offline   Reply With Quote
Old 12-14-2013, 12:48 PM   #13071
Mopar's Avatar
How did you assemble the diff? If you used a cordless drill to run in screws I you may have distorted the gear from heat or over tightened the screws. I ruined one gear from using a cordless and had to replace the gear.
Mopar is offline   Reply With Quote
Old 12-14-2013, 03:03 PM   #13072
RCNYWOLFTEAM's Avatar
What Will Be The Main Upgrades On A DEX210 RTR
Carlos C.
l (718-951-2500) Brooklynhobbies.com l
l (347-529-3862) LS Auto Body & Repair Shop l
RCNYWOLFTEAM is offline   Reply With Quote
Old 12-14-2013, 06:19 PM   #13073
Yep, what he said..Also, if its not the distorted gear diff, look inside the case where the 2 screws hold the trans to the chassis. I have seen more than one, where too long of a screw was used, and the bulge interferes with the main gear.
Old 12-14-2013, 06:41 PM   #13074
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
Could be one of the screws that go through the diff case and into the motor mount... the bold could be rubbing on the back of your slipper and causing it to bind a little. Just add a shim to the other side of the bolt if this is the case.
Fishhook
ewashburnaf is offline   Reply With Quote
Old 12-16-2013, 07:28 AM   #13075
chillindrdude's Avatar
I'm new to buggies so take this with a grain of salt..
I just got the DEX210 RTR. I think the must do's for durability are carbon fiber shock towers. I'd also get an extra set of front A-arms just in case.
Unless you get the STRC carbon towers with the Alu castor mounts, you will need 4 M3 button head screws, 2 M3 locknuts, and a couple M3 washers.
I drive:
Tekno SCT410 | Kyosho RB6 | TLR 8-ight T 2.0 E-Truggy | Axial SCX10
chillindrdude is offline   Reply With Quote
Old 12-16-2013, 11:10 AM   #13076
a couple of question about the rtr from me 2.
I have a 8.5t motor and a hobbywing v2.1 esc layin around and was wondering if i should just throw it in the car at once without trying out the electronics that are in it from factory. track is an hour away so havent driven the car yet...
how is the stock speed of the rtr?
and that servo saver arm was a dissapointment.. how is it? it screams "crap" at me everytime i look at it
these_savages is offline   Reply With Quote
Old 12-16-2013, 11:55 AM   #13077
Trader Rating: 38 (100%+)
Anyone using the JConcepts Finisher on a mid motor setup? I have the one off my RM and was trying to line it up with the Durango MM body and it looks like there needs to be a lot of cutting?
don't take it too serious, they are toys....
vw addict is offline   Reply With Quote
Old 12-16-2013, 11:59 AM   #13078
again, being new to buggies, the stock 13.5T motor seems plenty fast for me. the stock servo is indeed crap. i had an extra savox for an upcoming build so i stuck it in for the time being.
bear in mind the stock esc (cirtix club race) has NO reverse mode. so i bought an used speedpassion gt pro 2.0 esc and installed that.
i raced bone stock ('cept for new tires) out of the box this past saturday in mod 2wd buggy, and came in 6th out of 10.
I drive:
Old 12-16-2013, 12:03 PM   #13079
Thanks For The Advice
Carlos C.
Old 12-16-2013, 12:13 PM   #13080
thanks man. ill try out the stock setup first. im pretty new to buggys aswell.
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
05PSD
