Like Tree17Likes
Old 12-07-2013, 06:29 PM   #13036
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I gear my 17.5 at 33/69 or 34/69 with the Trinity Kill Shot.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 12-07-2013, 08:41 PM   #13037
novice racer's Avatar
Where are you finding 69 tooth spurs?
Brandon Shaw
novice racer is offline   Reply With Quote
Old 12-07-2013, 08:43 PM   #13038
Durango offers them. You can even find them on eBay. Search for Durango 69T.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 12-07-2013, 10:02 PM   #13039
rcjunky1's Avatar
What mechanical timing do ya run on the killshot?
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 12-07-2013, 10:16 PM   #13040
ekt
ekt's Avatar
#TD310442 for Team Durango's 69T spur
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 12-07-2013, 10:25 PM   #13041
Trader Rating: 57 (100%+)
Originally Posted by nicholasxuu View Post
Put a extra layer of lexan between the wing and the clip.
A very good option. The tresrey wing washers work well also. Not sure if they still make them.
The RW one is a really good one also.
shagino is offline   Reply With Quote
Old 12-08-2013, 01:55 PM   #13042
Are there any alternative slipper pads that fit?
I'm running on carpet track and they seem to get glazed super fast.
jaank is offline   Reply With Quote
Old 12-08-2013, 02:21 PM   #13043
Trader Rating: 519 (100%+)
ae pads are said to work, have to trim a small amount from what I have seen/heard..
flame56mx is offline   Reply With Quote
Old 12-08-2013, 02:28 PM   #13044
fq06's Avatar
I've used the Garodisks in two different AE kits and they were better than the felt pads in both cases. Not positive if these are the correct match for the slipper setup in this buggy as I don't have mine yet but I would guess so.
http://www.rcshox.com/durango-garodisc/
Glazing is nonexistent. Over a year and never had to freshen them up.
BCE SCT410 / Hobbywing 3656sd ~ RX8.2
DEX210 / Trinity 17.5 ~ RS.2
Westcoast Raceway (R.I.P.) | SMC | PowerLab
fq06 is offline   Reply With Quote
Old 12-08-2013, 02:31 PM   #13045
If you guys want to use the AE pads, you should get the Tresrey slipper hub set. It's a direct fit and you can use AE pads and spurs.
Old 12-08-2013, 02:31 PM   #13046
Potoczak's Avatar
Trader Rating: 111 (100%+)
I run the associated high torque slipped pads in mine. They fit no problem.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 12-08-2013, 02:33 PM   #13047
They look nice, but it would cost over 30$ to get em where I am
Old 12-08-2013, 02:39 PM   #13048
fq06's Avatar
Didn't notice your location, too bad. Sounds like AE may be a solution.
Old 12-08-2013, 02:59 PM   #13049
GregerL's Avatar
I can confirm that the AE pads are a direct fit, no trimming needed with the standard pad (have heard that the HT ones work if you ream out the center a little bit).
Have been using the standard AE pad in this buggy for almost two years now.
GregerL is offline   Reply With Quote
Old 12-08-2013, 04:52 PM   #13050
Konich's Avatar
I prefer the AE slipper pads, they are a direct fit and slightly thicker than the Durango. I also prefer the RW machined spur gears over the Durango.
Tresrey Spec DEX410 - Yaiba Spec B5M
Konich is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16561 Today 03:54 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
