Like Tree26Likes
Old 10-28-2011, 07:01 AM   #1291
sparkwraps's Avatar
Trader Rating: 34 (100%+)
I think I am missing something on the setup, because everyone is talking about so much steering and I have had none of that! I will give it a go little bit later today, but I have been having so little on-power steering in all of the setups.
The only cure I have found so far is gobs of toe-out (3!).
But that is masking the problem. Everyone that pushes down on the front is amazed at how stiff it is. So now I am back to being close to box stock setup and 25F/35R for shock oil.
This is the most stable car through the bumpy stuff out there. It out-handles just about anything and does it with style. If I can get rid of the on-power push, it will be stellar.
sparkwraps is offline   Reply With Quote
Old 10-28-2011, 07:04 AM   #1292
Matt Howard's Avatar
Originally Posted by sparkwraps View Post
I think I ma missing something on the setup, because everyone is talking about so much steering and I have had none of that! I will give it a go little bit later today, but I have been having so little on-power steering in all of the setups.
what vehicles have you driven before? a 2wd buggy will not have the onpower steering of a 4wd SCT. 2wd requires you to have a throttle finger, not trying to talk down to you, just trying to figure out if it's a vehicle setup problem or operator setup problem
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-28-2011, 07:18 AM   #1293
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
You have a problem then... my dex out of the box has a very very soft front end. If your front end is really stiff, and are running too much droop, you will have steering issues.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-28-2011, 07:41 AM   #1294
Here's a link on how to run 25deg of caster
http://www.team-durango.com/blog/?p=4622
just cut down a zero deg toe-in insert to use as a caster insert
RCTech #361
Old 10-28-2011, 07:42 AM   #1295
sparkwraps's Avatar
I know the difference between handling of 4wd vs 2wd. Have had B4 and 2 22's with no problem in the steering department.
I have adjusted droop and it has helped. It works OK, but I can't drive it like I was my 22, out of a corner. Hoping the lighter oil will tell me something good. Maybe I have a 22 driving style...
Look forward to a quick test today to see.
Old 10-28-2011, 08:01 AM   #1296
Ray Kindstrom's Avatar
Trader Rating: 147 (100%+)
Originally Posted by Bri from Chi View Post
If he isn't, I will be.
That came out wrong. I'll be there, with or without Jason. I'm not avoiding him.
LOL....sure it did! See you Saturday
Ray Kindstrom is offline   Reply With Quote
Old 10-28-2011, 08:08 AM   #1297
Trader Rating: 19 (100%+)
Better get ready to jump ship there Ray - this buggy is gooooooooooood. And we don't have much time on it yet, just wait til its dialed in and guys get used to it.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 10-28-2011, 08:22 AM   #1298
Might be tough to trade blue for orange.
Old 10-28-2011, 08:24 AM   #1299
Super Moderator
What anti-squat block are you running, and how much front droop?
- RCSpecialties -
Old 10-28-2011, 08:39 AM   #1300
sparkwraps's Avatar
I am running the 3 & 3 block in the rear. Less would mean less front grip, so I am thinking of leaving that alone. (correct me if I am wrong here)
Front droop is confusing to measure - from where to where? On the setup sheet it looks like you should measure the visible shock piston length, but there are no setup sheets with the numbers in there. So If I am to run 78mm of droop, where do I measure that?
Right now, I have about 7mm of droop from ride height. Basically, when the car is settled and you lift the front, the arms droop about 7mm before hitting the stops. Before I was running about 12mm of droop. Testing at lunch today to see what worked.
Old 10-28-2011, 08:41 AM   #1301
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
On power push can be a few things. The car has too much droop if you're not using the screws at all. It can also be hard to judge because of the swept arms.
Reduce front droop. Also don't be scared to add weight to the front. I added an oz behind the servo and it helped out huge. Also if your rear end is too soft this will transfer all of the weight to the rear under acceleration. Don't be afraid to go to a stiffer spring or stand up your rear shocks.
Toe is the wrong adjustment to get on power steering most of the time.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 10-28-2011, 08:42 AM   #1302
Team Tekin
Randy_Pike's Avatar
I measured mine shock eye screw to shock eye screw like an 1/8 buggy. Here's my setup:
Old 10-28-2011, 08:46 AM   #1303
sparkwraps's Avatar
Thanks Randy - I will measure what I have and adjust from there.
Appreciate the help guys! Like I said, if this car turn as well as it handles, it will be stupid fast!
Old 10-28-2011, 09:06 AM   #1304
Bad for good you mean? In all seriousness though, this thing has me thinking of getting a buggy. For anyone who knows me that's a heck of a statement...
Old 10-28-2011, 09:24 AM   #1305
Super Moderator
You are correct. 3 degrees of anti-squat will keep more pressure on the front tires under acceleration. You measure droop the way that I measure droop as well, which is how much the chassis rises before the tires lift the ground. I guess this stems from my onroad experience, which is how we all measure droop. Iv never measured eyelet-to-eyelet like Randy is showing here. However, it might be a good idea to start measuring it that way if everybody else is, so we can have some kind of consistency.
Randy, are you measuring from the very center of each eyelet?
- RCSpecialties -
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
