Like Tree26Likes
Old 12-06-2013, 07:25 AM   #13021
fq06's Avatar
Looking to get a 2wd buggy and meaning towards the Durango... but the kit seems to be out of stock at most places. Local track can't order any... does that mean a new kit is on its way?
It would be my luck to find it somewhere and read about the new version that's coming out
BCE SCT410 / Hobbywing 3656sd ~ RX8.2
DEX210 / Trinity 17.5 ~ RS.2
Westcoast Raceway (R.I.P.) | SMC | PowerLab
fq06 is offline   Reply With Quote
Old 12-06-2013, 07:37 AM   #13022
Trader Rating: 57 (100%+)
Nothing official has been announced but it's no secret that the v2's are on the way. Are you willing to pay $300 vs the $150 or so now?
If you're willing to buy used, I'd suggest looking at flame56mx's rollers that he was for sale. I bought a ST from him and would gladly recommend him.
shagino is offline   Reply With Quote
Old 12-06-2013, 08:17 AM   #13023
fq06's Avatar
Than for the info shagino. What would you speculate the changes to be? What if any short comings are there to be fixed or refined?
I actually would drop $300 vs the $150 that it sounds like kits are going for if there are decent improvements.
Sounds like its all just going to be speculation, but your educated guess is valuable to me... thanx.
I will take a peak at flame's roller, might be cheap enough not to pass up
Old 12-06-2013, 09:16 AM   #13024
fq06's Avatar
OK, flames price was too good to pass up. I'll drive that till the V2 comes out, if its all that and a bag of chips I'll sell the V1.
Old 12-06-2013, 09:23 AM   #13025
The things that need to be upgraded on the 210 were things I was going to change anyways with a couple of exceptions. One is the steering rack. Get rid of it. I use the Exotek. It's good looking too! New ball cups and studs are apparently coming out which is nice. I however use Losi 22 ball studs and ball cups and Lunsford Punisher turnbuckles on all of my cars. That is my reference standard. Many people are excited about the LRC rear blocks. I intend to use those from Exotek as well. They are aluminum and are just plain stronger. The new gearbox case is stronger and offers an extra camber link hole. I intend to use it when it becomes available. I will probably also upgrade to the outer hubs which allow for vertical ball studs just for the added options. Those are my picks.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 12-06-2013, 09:47 AM   #13026
SUPERLOOPER's Avatar
The biggest change should be the new Type B rear of the car allowing better access to the transmission. The new type B transmission case has 2 holes as well. Not sure about the chassis but my guess is a +8 aluminum version. The new ball cups and studs are currently available and the new "B" stuff is soon available to upgrade your current ride.
Brian
2017 Sponsors:
Team SOARSEIKI * AKA * Reds * Sanwa * Nitro Pro fuel * LFR * On point graphics * Xpert * M2C * Daytona RC paint
Brian Looper
SUPERLOOPER is offline   Reply With Quote
Old 12-06-2013, 05:55 PM   #13027
tower just got rtr back in stock again.
I'm wondering if they now contains type B chassis in the RTR or not?
nicholasxuu is offline   Reply With Quote
Old 12-06-2013, 07:10 PM   #13028
I got mine from tower and it did
homershoots is offline   Reply With Quote
Old 12-06-2013, 07:18 PM   #13029
thank you, i remember someone in desc210 thread said they got type b chassis in RTR, want to confirm dex210 got it as well.
Old 12-06-2013, 07:37 PM   #13030
Oasis's Avatar
Trader Rating: 36 (100%+)
Arrow
Originally Posted by Lead-Lobber View Post
Hey guys,
More info please...
I broke the kick up on my one piece chassis. So I ordered a new one online, got it in and swapped all my parts over. When I did so, I noticed a few things.
1, I ordered the B style chassis. Evidently, my parts are not the new B style.
2, The front bulkhead did not sit flush with the bottom of the chassis. The chassis is sitting the thickness of the chassis below the bulkhead. New B style front bulkhead?
3, The rear of the B style chassis does not have the cut out for the rear motor guard. Two options? Dremel the chassis to fit, or is there a new B style motor guard?
Other than that, installing the new Diggity Design shock towers, steering drag link and RDRC shock stand offs went as planned. Just need some pillow balls for the shock caps...
Any help is greatly appreciated. Cheers.
Jeff
Do Not dremel the chassis. .if you do you'll end up with another broken chassis. .just buy the new B pivot set and the B motor guard. .and race on..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 12-07-2013, 08:06 AM   #13031
fq06's Avatar
What's a good starting point for 17.5 blinky gearing? Should have the buggy early next week and racing it on Wednesday, can't wait! (thanx for the great deal flame56mx)
Suggested gear diff oil for med-high bite indoor?
Thanx.
Old 12-07-2013, 10:46 AM   #13032
Trader Rating: 520 (100%+)
Thanx.
The gear diff I sent has 7k in it, and it was really good for blinky. Depending on the motor your using I would be somewhere in the 69/30---72/31---75/32 area. My car liked a 72/30 for the infield, and our straight isn't all the long, on med/high wet clay.
flame56mx is offline   Reply With Quote
Old 12-07-2013, 10:54 AM   #13033
fq06's Avatar
Great, thanx.
Old 12-07-2013, 11:56 AM   #13034
novice racer's Avatar
Does anyone know what wing bushings will work on the DEX210. I need some. The clips don't hold it tight.
Brandon Shaw
novice racer is offline   Reply With Quote
Old 12-07-2013, 04:09 PM   #13035
Put a extra layer of lexan between the wing and the clip.
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
